Old 07-03-2009, 10:52 AM   #1 (permalink)
Chemist's Avatar
The Chemist is off-center! (with his license plate)
I've finished the working model of my offset license plate bracket. I'm headed out on an eleven day trip through the southwest states , so it will get a good "shake-down" over the next week and a half.
Here's the hardware:
1) 1/8" x 2" x 18" steel bar, with two bends and six holes.
2) Two Plasti-dip coated u-bolts.
3) 1/16" x 6" x 12" plate backer.
Sorry, forgot to get a pic of it assembled, off the car. When I get back, I'll try to get some under car pics as well.
Head on shot installed:
Side view and close-up:
NASSOA Founding Member
Old 07-03-2009, 11:29 AM   #2 (permalink)
KappaKadet's Avatar
Are you sure that is street legal? City cruisers might be OK with it and county mounties probably wouldn't bother you; but am guessing some black & white TxDPS skunkcar will pull you right over and say it's not legible... therefore... cha-$-ching. Good luck and have a safe fun trip!!
KappaKadet is offline   Reply With Quote
Old 07-03-2009, 01:03 PM   #3 (permalink)
Chemist's Avatar
I'll find out. I'm planning on carrying my stock hanger with me just in case.
Being on the driver's side, it faces the oncoming traffic pretty well. It's legible in _my_ estimation, but I don't work for TxDOT.
Old 07-03-2009, 01:50 PM   #4 (permalink)
...no offense meant so don't take this wrong...ok. Being honest about it
and being a stickler for detail, I have to say that I think the front tag,
which I don't like either, would look better mounted in the stock position
rather than on the side where you have it....it just looks out of place
there and looks like an afterthought position...I think it looks that way
because it's not in a true vertical position?? Have you tried it mounted
straight up and down on the side where you have it??
I'm from Colorado so we do the 2-tag thing too....but I confess, I've had
my car for 5 months....and have not ran the front tag yet....so far, no
tickets....knock on wood!
2007 GXP, mean-yellow, 5-spd, sat-radio, Magnflo
cat-back, K&N filter, Superchips tune, windscreen,
ASAP slotted bkup light covers, VansDesigns side
vent covers, blinker lights mod, dual horns, stubby
antenna, side accent striping, JPM Console/Door
Pads, Lil'Chromies, color-keyed splash guards, B&I
wood dash kit.
http://s234.photobucket.com/albums/ee190/mistergib/
mistergib is offline   Reply With Quote
Old 07-03-2009, 02:58 PM   #5 (permalink)
Carpe Diem's Avatar
IMO, if you have to have a front plate, the stock position looks better.
So, Chemist, I am wondering . . . is this to be a permanent installation, or a temporary 'preventative measure' for use during your planned trip?
I was slightly concerned about not having a front plate on my recent trek to NASSM'09. There is no place to mount a plate anywhere when I have my bra installed. I went without a plate, but kept it behind the front seat. I rigged up a method using a couple of small black bungee cords that hook on the edge of the facia under the hood, and under the facia underneath. I'll carry it with me all the time now. But (Knock! Knock! on wood), I haven't had a front plate since the car was new (Aug. '07). Lucky, I guess.
Carpe Diem
'Mysti' - '08 Mysterious 5-spd GXP, BSR tune, Hahn I/C, K&N drop-in filter, DDM ProBeam & Backbone, splash guards, and a few other things.
Old 07-03-2009, 04:31 PM   #6 (permalink)
I think that oddball plate position is more likely to attract attention than no plate at all. But I suppose you are thinking you would rather have a warning for improper position rather than a citation for no plate. Maybe so.
I would go with no plate showing but have a plate and broken bracket to show the officer. "It broke when you hit a parking lot bumper and you were going to fix it when you get back home."
rallyracer is offline   Reply With Quote
Old 07-03-2009, 05:22 PM   #7 (permalink)
KappaKadet's Avatar
If you get pulled over for no front tags in Texas, you get a ticket. No excuses... not behind the seat, not on the dashboard, not stuck in a side window, not banged up in the trunk. Plate has to be mounted on the front of the vehicle. Sad, but true.
Old 07-03-2009, 05:32 PM   #8 (permalink)
Bosch's Avatar
Hmmm I am still waiting for that ticket been almost 8 years..
Run somewhat human speeds out of state you will do fine.. What I've learned in years of playing down in AZ, NV, CA, TX NM...
Bosch is offline   Reply With Quote
Old 07-03-2009, 05:34 PM   #9 (permalink)
Chemist's Avatar
No offense taken. Opinions are opinions.
I ran the plate at the angle I did to minimize the work to produce the bracket. I'm only running a front plate because (1) it's the law, and (2) I don't want to pay the $110-120 fine.
Again, opinions are opinions.
Nope, I'm going to keep it there, I think. I like it better than stock.
As long as it is visible. legible, and "in the front." In State v. Losoya, 128 S.W.3d 413 (Tex. App. - Austin 2004, pet. ref'd) the Texas Court of Appeals ruled that if the plate could be seen and read from the front of the car that it met the requirements of the law (Texas Transportation Code section 502.404(a) ).
KappaKadet, see the court case I referred to above. Losoya in that case had the plate in his front window. The Court of Appeals ruled that that WAS legal, meeting the intent of the law.
I appreciate all of the replies.
Old 07-03-2009, 06:03 PM   #10 (permalink)
KappaKadet's Avatar
That's good to know. Guy must have had an expensive lawyer. So, we might get away with having the plate under the seat and then tossing it up on the dash if we get pulled over? Still, isn't there some law restricting stickers, signs, placards, etc on the windshield, regarding obstruction of driver's view?
Do you have some stickyback felt attached to the rear of the holder plate to protect the paint?
... just in case the bracket gets bent by wind pressure at certain uhh umm high speeds ...
Old 07-03-2009, 06:14 PM   #11 (permalink)
Gizmo's Avatar
Well, you're almost right. I've been stopped three times for no front plate in Texas. The State Patrol gave me a verbal warning, sent me on my way. The two Houston police each gave me a ticket. The judge in each case dismissed the charge.
SCOREBOARD:
MariSOL 3
Police 0
Her name is MariSOL
In Spanish that means The Sea and The Sun.
VIN 6Y101319, delivered 10/15/05. 83,519 miles.
Old 07-03-2009, 10:03 PM   #12 (permalink)
Chemist's Avatar
Silicone baking mat between bracket and fascia along the bottom and silicon rubber "bumpers" between the plate backer and front fascia, also rubber grommets around the upper plate screws.
Old 07-03-2009, 10:38 PM   #13 (permalink)
liveaboard74's Avatar
Bad Idea
YES SIR I fully understand a broken plate holder so send in your bond money with pictures of your plate where it should be and lets hope the judge is in a good mood today. They can write tickets for no plates. If you don't have one on there, you'll already guilty with or without a reason. Feel for you guys. NC has one plate no more inspection stickers in the windows now. but TX DOT are real cracker heads when it comes to you guys laws and there twice as tough on use as they are you locals. If we are pulled over in TX you can almost bet they are going to find something to write us up for and they do random inspections of us all the time. If you have to try something and its tearing at your gut to NOT RUN A PLATE,, I think he might have a idea there on the off set. Least he has a fighting chance cause the plate is on there. Don't think 95 in a 70 has a chance either cause the speed-0 was broke but if ya had to put your money on something or nothing I'd go with the off set.
When you think your plate looks bad,, look at the guys plates from Europe. 4x8 billboard and they might as well add LEDs to dress them up.
DDM Stage III LT Headers
261whp Dyno Tuned
Twin amp Kicker system
Ultimate Assault Offshore Fishing
liveaboard74 is offline   Reply With Quote
Old 07-03-2009, 10:56 PM   #14 (permalink)
Send a message via AIM to sprz31
I tried making something kind of like this. I took it front the bottom grille to the grille for the fog lights. If i spent a little more time I think could make something much better. I probably should do some measurements, but I think I am just going to remove it and hope no cop gives me a ticket.
2008 GXP Brazen
1)Dejon Intake
2)Dejon Intercooler
3)Dejon I/C piping and TB elbow
4)PCMforless Tune
5)Solo Street Race Exhaust
6)Trunk Spring "Mod"
7)T-bolts
8)Dashhawk
2.094 60 foot
13.365 1/4 @ 104.32 mph
sprz31 is offline   Reply With Quote
Old 07-04-2009, 08:56 AM   #15 (permalink)
Bagpypr's Avatar
I think it looks nice. Great design, low profile. It has that old British roadster feel to it. Nice job!
Please check out Norma Jeane @ Car Domain
PacificNWRoadsters member
Bagpipes are loud!
Bagpipes... the missing link between music and noise.
Bagpypr is offline   Reply With Quote
