Old 09-08-2009, 08:27 PM   #16 (permalink)
shabby's Avatar
I got the projectors/ballasts/shrouds/bulbs from the retrofit source(do a search on google), they pretty much have everything needed for a retrofit.
Old 09-09-2009, 07:04 AM   #17 (permalink)
Originally Posted by shabby View Post
Gonna have to give this a try over the winter, just picked up a pair of headlights from ebay.
Any reason why you used sealant rather than nuts+bolts to hold the projector?
Think the tl projector will fit in there?
I have used bolts and nuts before, and I had them go loose before. With the sealant I haven't had that problem. Some people feel better using bolts and nuts. I guess it is a preference thing.
Originally Posted by AMO View Post
GregAV do they charge the same if you want to do it like you did (DIY) or are you still paying the 700? If its less then I will consider it to do it myself but if the same not sure about that then. I dont want to buy new headlights and have to send them to a shop and then wait.
I PMed you
GregAV is offline   Reply With Quote
Old 09-09-2009, 12:54 PM   #18 (permalink)
cartmann32's Avatar
What type of sealant are you using/where do you get it?
I got another retro coming up soon, and might as well try it!
My system: http://www.solsticeforum.com/forum/s...ad.php?t=22157
Team Solstice 2008
Trax Customs
"If we can't do it, you don't need it"
www.traxcustoms.com
cartmann32 is offline   Reply With Quote
Old 09-09-2009, 05:48 PM   #19 (permalink)
shabby's Avatar
Good point, although how difficult is it to remove in case you botch the aiming or wanna switch projectors?
Old 09-09-2009, 07:18 PM   #20 (permalink)
BLK GXP's Avatar
I used nuts and bolts on mine. then I coated the nuts and remaining threads sticking out the back with silicone or JB weld. I used both, but not on the same screws. I also used the standard ballasts and bulbs from TRS.
I wish I would have taken more pics during the build.
NASSOA founding member
St. Louis Area Activities
BLK GXP is offline   Reply With Quote
Old 09-09-2009, 11:01 PM   #21 (permalink)
I am using ProGrip High Viscosity Polyurethane Autoglass Adhesive. I buy it from the local shop that replaces windshields.
The first couple day it is easy to take apart, but after that, cutting the sealant is the only way you will take the projector apart from the reflector. I use sharp blade.
Old 09-10-2009, 11:39 AM   #22 (permalink)
goofyboy65's Avatar
Send a message via AIM to goofyboy65 Send a message via Yahoo to goofyboy65 Send a message via Skype™ to goofyboy65
Imma try doin it to the Fog Lights 1st using the Dual Fog Lights with the Signals and Fogs instead of the plain Signal housing
2007 Sly Solstice Manual
--GXP Dual Exhaust
--GXP Rear Fascia
--4500K HID Headlights
--4300K HID Fog Lights
--K&N Air Filter
--Removed Resonator
--Blinker/Sidemaker Conversion
--Red Footwell Lights
--Red Bottom Door Lights
Is A Funkateer....Ya Dig?!?!?!
"One Nation Under the Groove
Getting Down Just for the Funk of it
One Nation and We're on the Move Nothin' Can Stop us now......I Promise to Funk, the Whole Funk and Nothin' but the Funk!"
goofyboy65 is offline   Reply With Quote
Old 09-21-2009, 12:51 AM   #23 (permalink)
Tierra del Sol's Avatar
Greg AV - BRAVO!
That was the best DIY video I have ever seen. You put "This Old House", 4X4 Garage and all the showes on TV to shame. It might be so good, I try this one at home!
What really amazed me what your ability to apply exactly the right amount of sealant EVERY time! When I use that stuff, I get it everywhere! I don't know how many times you have done that, but it looks like that was your 1,000,000th time.
Nice work,
Any Pics of them on the car? Perhaps a drive by video? and a drivers seat veiw video?
Tierra del Sol
07 Deep GXP
Stock - for now
Tierra del Sol is offline   Reply With Quote
Old 09-21-2009, 07:32 AM   #24 (permalink)
sebast007's Avatar
Originally Posted by Tierra del Sol View Post
(...)Any Pics of them on the car? Perhaps a drive by video? and a drivers seat veiw video?
Yeah, that would be great!
-2008 Red Pontiac Solstice GXP (14-07-2008)
-1981 Red Pontiac Firebird Trans-Am (420 hp)
-2002 Red Hyundai Sonata
sebast007 is offline   Reply With Quote
