Old 11-26-2007, 11:57 AM
   End all, be all: Curt Trailer Hitch (and accessories) Thread
rlhammon's Avatar
MODS - Can we please sticky this? Also if any of the links are violations, please PM me and I'll fix them as you desire. If you delete the links, all the work and effort is gone. I check this site daily and can fix them quickly if needed. Thank you.
Ok.. so this is my attempt at pulling all of the Curt Trailer Hitch information together in one spot and hoping we can get a sticky made out of this post. I'm not making claims for any of the products on this thread, and imply no such support. None of the links generate anything for anyone (they are not referral links of any kind). This thread is simply a collection of information from other threads and my own searches online for information.
I'm going to break up the thread like this:
First post (this one) announcing this thread.
Second post (next one) information on the Curt Hitch itself.
Third post (you get the idea now) information on carriers.
Fourth post information on trailers.
Fifth post information on cargo boxes.
Sixth post information on weather proof / resistant bags.
Seventh post reference links from past threads on this subject
Post 8 - 10 are placeholders for now.
rlhammon is offline
   Information on Curt Hitch
rlhammon's Avatar
Q: "Is there a trailer hitch that can be used on the base (NA) Solstice?"
A: Yes. Curt Manufacturing currently makes a hitch which bolts up to the Solstice (base model) without modification to the hitch or the car.
Q: "Is there a trailer hitch that can be used on the turbo (GXP) Solstice?"
A: Yes. Curt Manufacturing currently makes a hitch for the base model, which can be modified to fit the GXP (in stock form). No modifications to a stock GXP is required to mount the hitch.
Q: "What kind of modifications are required to fit the Curt Manufacturing hitch on the GXP?"
A: Here is a few pictures of the hitch installed, with the cutouts required to fit around the second exhaust pipe (additional pipe when compared to the NA model).
Q: "Is there any trailer hitch for the GXP that does not require modification?"
A: Currently the answer is NO. However, if you have an aftermarket exhaust on your GXP you might be able to mount the Curt Manufacturing hitch without modification to the hitch.
Q: "How do I find the Curt Manufacturing hitch?"
A: Curt Manufacturing hitches can be found online at various retailers. The model number you need is: 11119. Here is a Google link to a search for the hitch. http://www.google.com/search?q=curt+hitch
Q: "What does the Curt Manufacturing hitch look like?"
A: Here is a picture of it installed.
Q: "What size receiver / class hitch is the Curt 11119?"
A: The hitch is a Class I (1 1/4" square receiver opening)
Q: "How hard is this to install on the Solstice?"
A: Minus any modification required for the GXP, the manufacturer states 30 mins. to install, and it requires four bolts to be attached to the car and hitch. The install instructions can be found here: http://www.etrailer.com/instructions.aspx?pn=11119
Q: "Any tips for installation?"
A: Well yes... now that I've got mine installed. I would suggest the following.
1) Make a template of the passenger side vertical support, and cut the driver side to match. This will provide more room for install than the above "C" cutout pictures. Also, it provides less of a stress point. I would also suggest you drill a hole where the two cuts will meet (I did mine with a 1/2" bit, starting with a 1/8", then a 1/4" and finally the 1/2"). This will improve the stresses at the transition.
2) Also, after you thread in the bolts via the fishwire tool they give (great tool BTW, worked perfectly!), put the nuts on just a few threads. Trust me... you don't want to accidentally knock your bolts out when you are pushing up on the hitch to get it into place. Don't ask how I know that can happen.. trust me, it's hard to get the loose bolts back out and start over!
3) I added a piece of vacuum hose around the exhaust hangers because there was very little clearance between them and my hitch support. I then secured these with some cable ties. Now, if the exhaust moves around a bit, the vacuum hose sits between the two pieces of metal and won't give that annoying high pitch "ding, ding, ding" noise!
4) Install with two people, and move the exhaust side to side to give the clearance you need. There was no need to remove anything from the GXP to install the hitch.
rlhammon is offline
Old 11-26-2007, 11:58 AM
   Information on carriers for Curt hitch
rlhammon's Avatar
This section is concerning carriers (commonly found via online searches as Cargo Carriers).
Since the hitch is a Class I hitch your best bet is to find a Class I cargo carrier. These seem to be less common, and more expensive than other classes of hitches. If you use a Class II hitch you will need to find an adapter in order for it to work with the Curt Hitch (11119).
Some Class I cargo carriers are:
http://www.prolineracks.com/Masterbu...o-carrier.html
http://www.discountramps.com/receiver-hitch-carrier.htm
http://www.hidden-hitches.com/basket_carriers.htm
http://www.cabelas.com/cabelas/en/te...equestid=26203
Other cargo carriers which will require an adapter are:
http://www.prolineracks.com/Masterbu...m-carrier.html
http://www.discountramps.com/hitch-m...go-carrier.htm
http://www.discountramps.com/cargo-hitch-carrier.htm
http://www.dickssportinggoods.com/pr...=20 485458141
http://www.reese-hitches.com/categor...o_Carriers,472
http://www.hitchcarriers.com/prodinf...=15&mite m=40
http://www.northerntool.com/webapp/w...6165_200316165
(These last two models are nice as they have a built in rise to it to move the carrier up off the ground more)
http://www.basspro.com/webapp/wcs/st...&currentPage=0
Search link for adapters and risers:
Riser search:
http://www.google.com/search?hl=en&q...ch&btnG=Search
Adapter only search:
http://www.google.com/search?hl=en&q...&btn G=Search
A forum member is using this adaptor:
http://www.northerntool.com/webapp/w..._133752_133752
rlhammon is offline
   Information on trailers for Curt Hitch
rlhammon's Avatar
Whitefang PM'ed me this information:
Originally Posted by Whitefang
Company that makes Them: http://www.adventuresportsproducts.com/automobiles.htm
Both whitefang and idahobob have trailers that match their Sols. You can see pictures of my trailer at the 2006 National Meet and 2007 North American Meet and my signiture photo. GO_DRVN has a nice photo of my car and trailer in front of the KC Train station from the 2007 Meet.
Also, I found this online from Harbor Freight:
http://www.harborfreight.com/cpi/cta...emnumber=90153
http://www.harborfreight.com/cpi/cta...emnumber=42708
Harbor Freight usually runs discount coupons in their advertisements or e-mail coupons. If you have a store near you, this would be an inexpensive setup.
rlhammon is offline
Old 11-26-2007, 11:59 AM
   Information on cargo boxes for Curt Hitch
rlhammon's Avatar
Cargo boxes can be used on top of the cargo carries to hold all of your items. The main purpose is to keep things clean (inside the box), not damage your current set of luggage or upset the misses, and sometimes people like to lock up their items and this is a great way to do this.
Not all boxes are weatherproof, not all can be locked, so take a look and let me know if you have more to add.
http://www.cabelas.com/cabelas/en/co...er&noImage =0
http://www.montanajacks.com/index.as...ROD&ProdID=365
http://www.custom-cover.com/details....b1b5247c68513f
http://www.coverbonanza.com/7517/234...argo-Pack.html
http://www.cabelas.com/cabelas/en/te...con&hasJS=true
rlhammon is offline
Old 11-26-2007, 12:00 PM
   Information on weater proof / resistant bags for Curt Hitch
rlhammon's Avatar
Some bags are waterproof, some are weather resistant. Pay attention to not only what you are getting, but the size as well, as you'll want to maximize the size of your bag to your cargo carrier to get the most use out of your entire system.
http://www.prolineracks.com/Everther...argo-bags.html
http://www.prolineracks.com/SportRac...organizer.html
http://www.prolineracks.com/Masterbu...cargo-bag.html
http://www.amazon.com/Rola-59102-Exp...93186&sr= 1-4
http://www.cargogear.com/shop_by_bra...e=2&brand=Rola
http://www.sportsmansguide.com/net/cb/cb.aspx?a=275612
http://www.etrailer.com/p-59102.htm
rlhammon is offline
   Reference threads used in the making of this "all-in-one" thread
rlhammon's Avatar
Hey! Wanna see my rack??
Hitch Mount Cargo Carrier
Trailer Hitch
Trailer Hitch
Finally, A Real Bike Rack!
http://www.skyroadster.com/forums/sh...ad.php?t=19917
Trailer Hitch help
Trailer Hitch help
rlhammon is offline
   Placeholder
rlhammon's Avatar
rlhammon is offline
Old 11-26-2007, 12:01 PM
   More to come
rlhammon's Avatar
rlhammon is offline
Old 11-26-2007, 12:02 PM
   Yet more to come?
rlhammon's Avatar
Maybe even more to come...
rlhammon is offline
