Old 01-10-2009, 04:56 PM   #1 (permalink)
Having problems connecting wires: Side Marker Lighting
Hey guys, i need some help. I'm trying to connect 12V LEDs to the side marker. Connecting it to the Blue and Black Wire however no light. I also tried connecting it to the purple and black still no success.
I first tried connecting through the connectors and then stripped the wire and wrapped the wiring still no success.
I know my LED works since I tested it through a AA battery. Please help me what am I doing wrong.
Is there a coating on the wire or something else??
mminhas is offline   Reply With Quote
Old 01-10-2009, 07:36 PM   #2 (permalink)
The wires to the side marker lights are Brown and black.
If you look at the post about modifying the marker lights into signal lights there is a drawing.
Hope that helps.
Team Solstice
Mysterious 2008 GXP
JPM center console, center handle, door handles
tinted windows
shorty antenae
Dark Mahogony Dash
Aftershock smoke/black marker/turn signals - modded
Laminex darkened rear tail lights
chemist garage door opener
black painted/decaled calipers
LED red interior lighting
GM Performance tune
Krelubot is offline   Reply With Quote
Old 01-10-2009, 08:37 PM   #3 (permalink)
Gunnys GXP's Avatar
Hey mminhas,
Not sure why it's not working for ya. I have this done to mine and they worked first try. I did have to add resisters into the blinker possitive line to stop the rapid flash but it worked either way.
I didn't do a DIY thread and with the car all tucked in for the winter can't run out and look at the wire colors but the thread Krelubot mentioned "How To" Convert Side Marker Lights into Marker/Turn Signals a good one and should help. How many LED's are you puting in?
I did three per side above the side marker lights.
"BLUE DEMON"
Old 01-10-2009, 08:57 PM   #4 (permalink)
Hi Gunnys GXP
I actually got the idea from your post. Its a very good idea, I am trying with 2 red LEDs on each side. I saw your post and the pictures show light blue and black.
Does it matter which position of the wire I connect them to. Basically I have tried connecting them after they split off and before. At a point the wires split off and connect into this "white thing". I don't know what that is. Where should I be connecting the wires or does it not matter at which length I connect them at as long as its the right color.
Old 01-10-2009, 09:10 PM   #5 (permalink)
Gunnys GXP's Avatar
Originally Posted by mminhas View Post
Hi Gunnys GXP
It shouldn't matter where in the line you splice it (current doesn't care) and the blue and black wire should be the right ones. I spliced in right behind the bulb plug for the signals. Are the two wires for the LED's both copper or is one silver? If there is a built in resister in the LED the current will only flow in one direction so it may be wired backwards. You asked about a coating on the wire. Does one of them have like a red tint to it? If it does then it is coated and you'll need to melt that off with a lighter before you connect it or it won't work.
"BLUE DEMON"
Old 01-10-2009, 11:25 PM   #6 (permalink)
i doesn't matter where the resistor is (before or after led) but i know polarity matters.
LazyEye is offline   Reply With Quote
Old 01-11-2009, 09:59 PM   #7 (permalink)
kdasilva's Avatar
Hey mminhas,
Just got your PM about living in mississauga as well ... I've done this and if your not to far we can meet up somewhere and I can take a look...
kdasilva is offline   Reply With Quote
Old 01-12-2009, 10:12 AM   #8 (permalink)
Thanks Guys,
I followed your advice and used a lighter to burn away the coating on the LED wire. Then plugged to the brown and light blue. So now every time I turn on my fog lights the RED lights turn on and also blink when using the turn signal.
I've only completed the right side putting in 4 LEDs. Once I complete the left side marker I will be posting pics very soon.
The right side looks awesome.
Once again thank you everyone.
Old 01-12-2009, 10:17 AM   #9 (permalink)
Kdasilva plz check your pm
