HID lights - where to mount ballasts? - Pontiac Solstice Forum
post #1 of 13 (permalink) Old 04-01-2017, 12:03 PM Thread Starter
I'm rebuilding one of my HID headlights at the moment. I've never been happy with the ballast mounting scheme I have - double-sided 3M super-sticky-probably-made-from-Happy-Fun-Ball-taped to the underside of the hood.
Where have y'all mounted the ballasts? I have the Morimoto XB55 kit. The ballast boxes are roughly 4" x 3" x 0.5". The ground wire from the harness is pretty short which limits my options unless I want to extend the harness. I'm fine with doing that if necessary but, if anyone else has a good solution that doesn't involve a bunch of wires taped to the bottom of the hood going everywhere, I'd love to see it.
Blue-ish 2006 2.4, Werks stage 1 turbo, GMPP cat-back, TCE Wilwood 6 piston front brakes, 4-piston rears , Stainless brake lines, slotted and drilled rotors, DDM braces, BR Racing coilovers, Spec aluminum flywheel, Spec stage 2 clutch, Werks aluminum radiator, DDM oil catch can, Autometer boost, water and AFR gauges, RKSport hood, Morimoto FX-R HID headlights, GReddy Profec boost controller @ 13PSI, custom A-pillar gauge pod.
In progress: custom fiberglass trunk lid.
Currently on engine #4!
post #2 of 13 (permalink) Old 04-01-2017, 02:17 PM
This is where I mounted mine:
(More detail at: Solstice Projector HID Install - a Show'n'Tell and How-to)
post #3 of 13 (permalink) Old 04-01-2017, 02:19 PM
You are using projectors right? Because if you've ever been headon with a Solstice with HID and no projectors, it's brutal!! They are worse then normal high-beams....
post #4 of 13 (permalink) Old 04-01-2017, 04:24 PM
Mine are the same as TomatoSoup's I extended the harness to plug into the OEM light harness down beside the hood hinge.
A.J.V is online now
post #5 of 13 (permalink) Old 04-01-2017, 04:37 PM Thread Starter
Is considered that, wasn't sure if there was enough clearance for the wheel well liner. I guess there is! Thanks.
And, Ghost, yes, I have the projectors.
post #6 of 13 (permalink) Old 04-01-2017, 04:56 PM
CRiggleman's Avatar
I made a little bracket and mounted mine down by the hinge.
CRiggleman is online now
post #7 of 13 (permalink) Old 04-01-2017, 06:51 PM Thread Starter
Attachment 67457
Attachment 67465
That's slick.
post #8 of 13 (permalink) Old 04-03-2017, 03:20 PM
cartmann32's Avatar
I have extension harnesses on the output of my ballasts (since I take my headlights on/off more than most owners :-D
My ballasts are down by the fog lights and they run up into the hood....all other wires have been removed.
These helped:
https://www.theretrofitsource.com/am...ons-48598.html
Trax Customs
www.traxcustoms.com
cartmann32 is offline
post #9 of 13 (permalink) Old 04-04-2017, 04:06 PM Thread Starter
These helped:
Any pictures? I have a second-hand set of lights that I think you worked on.
post #10 of 13 (permalink) Old 04-06-2017, 10:55 AM
cartmann32's Avatar
Nope....there is nothing special about my engine bay, so i've never taken a pic of it
What lights do you have?
I'd be interested in seeing how they've held up or if they've been modified by previous owners
Trax Customs
www.traxcustoms.com
post #11 of 13 (permalink) Old 04-12-2017, 09:29 AM Thread Starter
I'll send some pics. I had to open one up do to a broken adjustment screw and a bad shroud.
post #12 of 13 (permalink) Old 04-19-2017, 07:21 AM
I'm still in the shopping for a car mode but have a relevant question. Who would you suggest getting projectors done by? And can they black them out like the coupes?
hfd419 is offline
post #13 of 13 (permalink) Old 04-19-2017, 04:33 PM
CRiggleman's Avatar
Contact Cartman that posted in this thread. He can do pretty much anything you want done to your lights and his work is top notch. He did mine and they turned out great.
