Joe, if you don't already have one you are going to have to set up a Paypal account
Do you need any jingle to cover the cost of ordering?
NOT WAITING ANY MORE!
I went on a mission today to find the relays, I hit 3 auto parts stores and a Radio Shack, all had horn relays none had the right horn relays. I guess I will have to be patient and order on line. Thanks DBG!
Update, if you order 6 from Parts Express the shipping is the same as if you order 2 ($3.70), at $1.99 each order some for your friends. Shipping goes up to $6.90 when you order 8.
Solo Mach and High Flow Cat
Wester's Garage RACE tune II
JPM custom shifter.
Barney Juice with Militec-1
DDM Works PINK Breastplate
One more question-did you look at swapping the mini wedge bulb & socket to accommodate the turn signal 3157 bulb?
Not needed, that type of mod would require an additional wire added to the circuit and the connector would have to change to allow for the extra contact needed for the blinker. The relay was the simplest way to do this.
I checked Advance Auto parts and they only had a normally open relay with only a #87 on the side label, no 87a. That relay will not work.
Yep, that's all that I found locally, but my supply of proper relays arrived yesterday, and the rest of the paraphenalia arrives today, so I may just get my butt out there after work and get 'er done
I am hoping mine show up today, I will be out there with you and we can "flash together"
JPM custom shifter.
Way to go, DeepblueGXP. An awesome mod!
I've always wanted to change out the assembly with a clear lens and make it a turning lamp. In other words, when the turn signal is activated, a non-flashing light on that side lights up enough to cast a strong light to that side. I've always had a fear of hitting a person, animal, or object that I couldn't see in the darkness.
Her name is MariSOL
I'm flashing I'm flashing. thanks so much DBG, the instructions are dead on! Very nice mod!
JPM custom shifter.
