Old 08-26-2008, 03:57 AM
Go-N Def's Avatar
Originally Posted by lil goat View Post
People were flashing at the meet and I missed it, story of my life! I still flash alone.
Thank God!!!
Pics on MySpace
Go-N Def is offline
Old 09-08-2008, 07:59 PM
crappa's Avatar
Installed my relays and I too now flash on the side.
Thanks for the mod.
My Mods Post
What do I want to be when I grow up? In denial.
crappa is offline
Old 09-08-2008, 09:11 PM
Chemist's Avatar
Thanks for the mod.
I also flash.
This is an easy, useful, and way-cool mod.
"Muirne" --- Envious, ebony leather, LSD/ABS/AC/Monsoon w/6CD changer, mats, splash guards, DDM Stage II S/C, DDM stainless headers/cat/exhaust, DDM 4-piston brakes/slotted rotors, Probeam, Backbone, black "stubby" antenna, Lil' Chromies, K-sphere pedals, Kazera KZ-L wheels, the TWEETY door unlock/lock button, Garmin nuvi 750 GPS, High Note horn, Brushed Al door sills, etched/lighted WindRestrictor, white LED map/footwell lights, 3rd brake light pulser. --- She moves!
NASSOA Founding Member
Chemist is offline
Old 09-22-2008, 10:13 AM
Deepbluegxp's Avatar
A member of the sky forum had a GTO with simular wiring and blinked with out a relay. they use the GTO wiring guide and did the mod on the Sky and it works. I did it to my Solstice this weekend and it works great.
This is what you need to do.
Open the harness to the side marker, pull out the black wire up to the point of the harness where the fog lights split off. Cut the black wire close the split and (using the end that comes from the side marker)then apply a wire tap to the blue wire in the bundle going towards the fog lights.
I stripped back some insulation off the blue wire and soldered the black one to it. Then re-taped the harness for a nice clean look.
Team Solstice 2008
Click My modifications
See my car on cardomain.com
NASSOA Founding Member #48
Deepbluegxp is offline
Old 09-22-2008, 10:40 AM
duckSol's Avatar
All fine and good, but what happens to the other end of the black wire or did I miss something?
Pics and diagram?
Transformer SLY
FOUNDING MEMBER NASSOA
Where SLY? SLY Tiki Man miss SLY
"It's a Family Affair" Sly & the Family Stone
"Okolemaluna"
duckSol is offline
Old 09-22-2008, 10:52 AM
Luv2BGrrl's Avatar
Pics and diagram?
The other end of the black wire gets taped off and hid in the harness. It is no longer used.
I did this mod yesterday. It was SOOOOO easy!
Linda Ann
North Beach, MD
07 Silver Graphite with red/black
plate "SKYGRRL"
Mods:
VectorSports ECM
Third brake light, sequential rear and sidemarker turn signals
DMV Solstice and Sky Meetup Group
IMSaturn
MySpace
Luv2BGrrl is offline
Old 09-22-2008, 11:47 AM
Hoosier GXP's Avatar
So am I to assume that there is no need for a relay just a simple wiring connection from the black wire to the blue does it? This is just way to easy not to do
Hoosier GXP is offline
Old 09-22-2008, 12:45 PM
What a great mod!
SCISOLSTICE is offline
Old 09-22-2008, 01:02 PM
Pics and diagram?
See how easy this mod is!!!
Team Solstice 2008
Old 09-22-2008, 01:21 PM
Skyman-CT's Avatar
Great Mod -
Sky Redline
Chili Pepper Red with Black Trim
5-SPD, 6-CD/MP3, XM, Polished Alloy, LSD, Spoiler
Deposit 06/10/06
Order # KGNMQ4
3800 02/09/07
Delivered 02/28/07!!!
Skyman-CT is offline
Old 09-22-2008, 01:28 PM
Perhaps this mod in conjunction with swapping the side markers with LEDs will not add to the voltage draw.
Team Solstice 2008
Old 09-22-2008, 02:12 PM
Skyman-CT's Avatar
Good idea Deepbluegxp, the current draw on LED’s are much lower for sure, however I went back over to Sky site and have been reading the post and looking at the GM schematic that was posted in the thread. Convert your side marker lights into turn signals - Page 3 - Saturn Sky Forum
I'd be surprised if they would work with this mod as they don't respond to reverse current flow. (voltage polarity matters)
It looks like the (black) Marker lamp ground wire is being cut and tapped back to the low turn signal return (blue) so it doesn't change any supply current being pulled through the 10 amp fuse or any wires in the circuit under normal operation and after further investigation I'd say this is most likely a safe mod because that fuse would have blown if it was drawing too much current, that being said it's still a mod and if something goes wrong and they find it?
What it does do however is to cause the 12Volts to buck each other while the parking lamps are on which is why I believes it alternates because the current flow thought the bulb is actually reversed in that state, as was mentioned elsewhere it should work fine with any Park/Turn Signal incandescent bulbs but LED’s or HID’s most likely won’t work due to reverse current flow. (just a guess at this time?)
I removed my first caution so as not to confuse anyone.
Sky Redline
Deposit 06/10/06
Order # KGNMQ4
3800 02/09/07
Old 09-22-2008, 02:23 PM
Originally Posted by Skyman-CT View Post
Great Mod -
I also did this mod over the weekend, using 2 vampire taps to connect the black and blue wires, and electrical taping the whole thing back up. I know soldering is better, maybe i'll do that in the new future.
By the way, Great picture explaining the wiring! Wish I'd seen it last weekend
dallas32822 is offline
Old 09-22-2008, 08:38 PM
duckSol's Avatar
Now I feel like a DOOB! girlz
Thanks for the diagram Deep, that WAS SIMPLE.
Have not done it yet and I have the relays DOH! so I might as well try LEDS and see what happens but with my schedule who knows when the next mod will be
Transformer SLY
