Old 02-08-2008, 07:57 PM   #1 (permalink)
Deepbluegxp's Avatar
[How to] Custom Guage Cluster
Well, with the crappy lighting that the dash has for the guage cluster I decided to update it to be brighter and a color theme to match the Deep. I give credit to Gunny's GXP for the find. I expressed to my son what I wanted for my birthday and he got me the white face place with blue lettering and upgraded white LED kit from blackcatcustom dot com.
Sorry, some of pics are a little blurry, I didn't notice until after I had completed the install.
I started by removing the chrome ring and then pulling the black tunnel, I thought I could remove the 4 screws to the guage cluster and pull it through the hole but I couldn't reach the back to disconnect the plug.
So I had to pull up the surrounding dash and of course to do that I had to pull the passenger O-Shi% grip and shift boot/shifter. Once that was off I was able to pull the dash up the dash surround. I only disconnected the 12v outlet and then supported the dash up to the latch for the convertible.
I then removed and disassembled on the top covers of the guage cluster, I reinstalled the power connection and as I turned on the car (without starting it) while counting the seconds it takes for the guage needles to stop moving (write this time down, you will need that to install the needles) and then marked the location of the needles. Then I removed the guage and opened it up the rest of the way on the table.
To take of the needles, you carefully turn them counter-clockwise while lifting and set them aside.
The circuit car on the right has three white areas where I de-soldered the LEDS in the center of each and added the brighter LEDs according to their instructions. I plugged it in to the car to verify the LEDs worked. I ended up having to reverse the fuel guage LED wires as the polarity is opposite of the tach and speedo.
I re-assembled the guage to the point you see below and plugged it back into the car and turned the key forward to the on position without starting. Counting the seconds from before. Then installed the needles by carefully pressing firmly down. The tach and speedo needle were at 0 and the fuel guage was about 1/4. I then disconneted and went back inside to finish re-assembly.
I finished re-assembling the guage and installed it reversing the rest of the removal process.
Here is the final installed picture.
I rate this on a scale of 1-5, a 3. The soldering of the LEDs can be tricky in you are a novice and don't have a good gun. My son brought home his soldering station from work. The dash and such are fairly easy, as well as the dis-assembly of the guages.
This project took 1.5 hours
I may take the needles back off and change the color of them. The bottom of each needle is white. I'll probably scrape that off and then apply a blue color so during the day the needles will standout better.
See my car on cardomain.com
NASSOA Founding Member #48
Last edited by Deepbluegxp : 06-24-2008 at 06:48 AM. Reason: added time to do project
Old 02-08-2008, 08:25 PM   #2 (permalink)
KYGXP's Avatar
Send a message via AIM to KYGXP
I like.... How long did this take ya?
Team Save the Ta-Tas 2008
07 Mean GXP....
Current Mods:
JPM ROCKS
JPM Arm Rests, JPM Visor Covers, JPM Center Cover, JPM Shifter, JPM Seat Belt Loops,
DDM Backbone Brace, DDM Tune, Solo Mach Exhaust, Stubby Antenna, Wind Screen, Norms Rear Facia, Foot Well Lighting, Red Map Lights,.....
KYGXP is offline   Reply With Quote
Old 02-08-2008, 08:34 PM   #3 (permalink)
The whole thing took about 1.5 hours
Old 02-08-2008, 08:48 PM   #4 (permalink)
solmio's Avatar
That looks tremendous! You worked really fast to get that done in 90 minutes. Congrats to you on a mod well done. Great photos and tips on the needle work!
Black Cat is the best. Alex there is working on a custom faceplate for me as we speak, and I’m opting for the upgrade LED’s as well. Kind of ironic though – you went from a black face to a white face, and I’m doing the opposite. I didn’t realize until now that GXP gauges are black background. Oh well, just goes to prove the grass is always greener…
Mean N/A '07 pretty much loaded.
Mods to date: Kappashere CAI, billet grille, Helo rims, built-in garage door remote, JPM leather covered tulip (trim over waterfall), interior de-silverization including body color boomerang, radio, switch bezels and door hardware, retro gauge overlay, Halo DRLs, headlight bezel blackout, SOLO dual axle back exhaust, mesh rear fascia insert
Next up: final exterior de-silverization (windshield trim)
solmio is offline   Reply With Quote
Old 02-08-2008, 10:42 PM   #5 (permalink)
Gunnys GXP's Avatar
Looks great. Happy to steer you in the right direction. I know mine is so much easier to read with out having to stare at it.
Great job on the play by play as well. I was so happy to finaly get mine back out of the shop and get the stuff in I was finished before I even thought about making a photo diary to post.
Enjoy.
"BLUE DEMON"
Old 02-09-2008, 09:25 AM   #6 (permalink)
The dash took only about 10 minutes to pull and same to install and the guage cluster have little tabs you lightly push against and pop apart. I was extremely pleased on how simple that part was. The hardest thing was removing the stock LEDs because they are soldered on below the LED. So getting the heat to the wire of the LED without damaging the circuit card.
Old 02-09-2008, 09:31 AM   #7 (permalink)
Cheers's Avatar
Wow As much as I like the red lights (which you can almost see) this is a beautfully job. Got me thinking ....
Cheers
GMH
Mysterious GXP
NASSOA Founding Member #95
Cheers is offline   Reply With Quote
Old 02-09-2008, 10:27 AM   #8 (permalink)
solmio's Avatar
here is the overlay that Alex is working on for me...
I know to many of you it will look really plain, boring, and not worth the effort. But I'm going for a classic old school roadster look. Have been unsure about the needles. My stock NA needles are red...
I think I'd prefer white needles. But now I see that GXP needles are white, so maybe I can buy some of those from the dealer. Or maybe someone wants to trade?????
Old 02-09-2008, 12:00 PM   #9 (permalink)
The needle is just painted red on the bottom, scrape it off and make it any color you want.
Old 02-09-2008, 05:40 PM   #10 (permalink)
solmio's Avatar
Thanks for the info. Especially since I called the dealer and got a flat no regarding buying GXP needles.
Old 02-10-2008, 01:25 PM   #11 (permalink)
This is one of the best appearance mods I have sen in a long time, I really like this one. Now I just have to decide what color to get. Way to go DBG. Nice job of how to pics. I am really lucky, I can get you to help do mine.
Let's get SLIDEWAYS!
Solo Mach and No Cat
JPM custom shifter.
Barney Juice XPR 21
RMR Style Bar.
DDM Works PINK Breastplate
HKS Coilovers
Old 02-10-2008, 02:45 PM   #12 (permalink)
Cooooooooool!
SCISOLSTICE is offline   Reply With Quote
Old 02-10-2008, 06:32 PM   #13 (permalink)
No problem, when you get yours I'll help you swap it out.
Old 02-11-2008, 07:46 AM   #14 (permalink)
idkfa's Avatar
That was super well documented and looks freakin awesome! Any tips on the soldering? I've soldered before but have not had to do much around PCBs, just wire to wire.
Old 02-11-2008, 09:39 AM   #15 (permalink)
Use a small pointed tip, make sure it is clean and then "tin" it (tiny bit of solder on the tip) You also need one that operates at a high enough temp so that the when the solder is touched, it melts quickly without transferring to much heat to the surrounding components.
