Use a light coat of contact spray adhesive on both the backing plate and air bag, allow to "tack up" and position the air bag on the plate.
Slide nylon ties thru the previously drilled holes and attach the assembly to the seat frame with the air bag between the seat foam and the backing plate.
Zip up the zippers and feed the squeeze bulb between the seat back and seat bottom. I wanted the bulb on the inside, but it's your choice. It has really made the seat more comfortable on long trips.
