Old 02-09-2008, 12:44 PM
   How To: Spray Tint Center Brake Light
spiky3480's Avatar
This light must be one of most difficult to remove...so I decided to spray tint it on the car. Here's what I did....
Materials used:
  • VHT Night Shades Tint Spray
  • Acrylic Clear Coat Spray
  • Painters Tape
  • Towel
To Prep: I cleaned the area around the brake light and used windex on the brake light itself. Make sure you use a microfiber towel so none of the lint gets on the light.
Taping: Rip long pieces of tape off and fold one edge over so it becomes flat and is easy to slide into groove around light. Surround entire light with tape, and make sure to also tape about 6-8 inches wider to prevent overspray. After taping is complete, lay the towel on top in order to prevent spray from landing on the decklid.
Starting the Taping Process
Taping Finished
Spraying: I used three coats of the VHT Night Shades and two coats of the clear acrylic. Use even spray patterns and do not go too fast. Make sure to start to the left of the light and end to the right of the light to ensure even coating, and the opposite when spraying the other direction. Allow about 7-9 minutes drying time in between each coat.
After One Coat of VHT Night Shades (note towel to prevent overspray)
After Three Coats of Night Shades and Two Coats Clear- Tale Removed
Remove tape slowly so that it does not rub against the light you just sprayed...and you are done! The cost was approximately $10 total.
Steve
TEAM SOLSTICE 2008
ONCE YOU GO SOLO, YOU NEVER GO BACK
2007 Mysterious GXP- "Intruder"
Member of LISSC
Exhaust System Sound Clips/Videos- N/A and GXP Models
SOLO Performance Exhaust Sound Clips
Spiky3480 Modification Page
Mods: 72
Updated 9/7/08
spiky3480 is online now
Old 03-11-2008, 09:06 PM
Falsetto's Avatar
were can i get the supplies from
Her name is Falseto
08 Mysterious Solstice GXP
Order date 12/26/07 Delivered 01/15/08
Total mods to date July 01,2008
vanity plate Falseto, Stubby antenna
And The Youngest Member of LISSC
Falsetto is offline
Old 03-12-2008, 10:19 AM
Sly Bob's Avatar
Does that light come out of the deck lid?
Sly Bob is offline
Old 06-01-2008, 08:46 AM
kdasilva's Avatar
Looks Great! Do you have any pictures with the brake light on?
kdasilva is offline
