Signatures cause the threads to become too large to read text. You do allot of scrolling just to get through.
As a non supporting member the signature block is limiting in the number of characters and markup code even though I tried to keep mine to a few lines with commas, there wasn't enough space to list all of the mods that you may want to consider for your cool ride.
I Hope that others will follow suit.
I can always come back to this thread and update it when I add or change the look of my ride.
Reply to this post and then copy the format, create your own and add it to here. For your signature, link to your post by copying the shortcut on the # of the post, you can see it next to the (permalink), right click on the number and click copy shortcut. Then paste it into your Signature.
Rules:
Please do not comment on this thread except to add your own list.
Do not post photos here.
Create your posting for each mod in the appropriate area and then make URL references to them in your mod list here.
Welcome to DeepBlueGXP's Mod Page.
Her name is Renée.
Deep GXP, No On-star/XM, Ordered 01-26-07, Born 02-22-07, Delivered 3-9-07.
30245 miles. VIN: 1G2MG35X87Y128779
NASSOA Founding Member F08010100048
Disclaimer: Reading the rest of this thread may offend purists.
It's name is The Boogeyman.
Mysterious N/a, Onstar, XM, Premium and Convenience packages only. No ABS, No TCS.
14,000 miles.
Disclamer: Reading the rest of this thread may offend purists.
PERFORMANCE/GO FAST GOODIES
K&N Cold Air Induction
SS Brake Lines
EBC Front Pads
DDM Long Tube Headers
DDM High-flo Cat
Solo N/A Single Outlet Exhaust
DDM Stage II Supercharger #22 w/update
SMS Big Bore Throttle Body
APPEARANCE
Colormatched lights and grills
Colormatched OEM wheels
Smooth Rear Facia
A-Pillar Gauges- Boost and AFR
DIY MODS/Small Mods
Debadged
PARTS ON ORDER/COMING SOON
PLANS TO COME
DDM Works Stage 3
Zex wet nitrous system
Limited Slip Differential
Stage II Clutch
Lightened Flywheel (Maybe)
OZ Ultraleggera Wheels
Vented Fenders
2.4L turbo, fully loaded, brought home Nov 15 05
Name SLOSTICE
Exterior
RK Sport front bumper
RK Sport side skirts
RK Sport carbon fiber rear filler
RK Sport Carbon Blister Ram Air Hood
One off custom air brushing
8000K Ignited HID kit
Wind Screen with LED lighting
2.55 inch antenna
Suspension, Brake and Wheels
KW coilover V3 suspension
PowerSlot rear rotors
DC Sport front strut bar
Rotora 4piston calipers
Rotora 330mm floating black hat rotors
Rotora stainless steel brake lines
Privat 19x8front 19x9.5rear light weight racing wheels
APR extended racing studs
Rays Racing lug nuts
Conti Contact 3 street tires
Engine
2.4L ecotec engine
One off TAG turbo set up
One off TAG turbo manifold
GXP muffler system
Vibrant Performance 2.5inch cat back piping
Vibrant Performance high flow cat
Vibrant Performance tig welded turbo pipes
Powered coated hot and cold side piping in red
Vibrant Performance intercooler core tig welded end tanks
Turbo Smart BOV
Powered coated Red and chrome turbo smart BOV
Turbo Smart boost controller
Turbo Smart 38mm waste gate
60LBS injectors
Garrett GT2876R turbo
Werks Racing duel core RAD
Bully state 4 6 puck racing clutch
Relocated power steering fluid container
Car is dialed in at 311RHP 268TQ
In Car Entertainment
Nakamichi 7inch in dash screen
JBL 10inchsub woofer
JBL tweeters
JBL 6.5inch door speakers
JBL 3.5inch rear speakers
JBL 6.5inch trunk speakers
JBL crown series amp
JBL power series amp
4 gauge street wire
RCA Street wire
Custom install for component kit with plexi glass
Custom fiberglass kick panel box for 10inch sub
Custom AMP rack behind seats to display AMPs
Interior
Pair of Bride Vorga seats Carbon fiber seat
Pair of Sparco 2 inch 4PT Harness
Red suede door inserts
Red suede trunk liner
Carbon fiber dash kit
Custom made gauge pod
Auto meter C2 boost gauge
AC Autotechnic oil pressure gauge
AC Autotechnic exhaust temp gauge
AC Autotechnic oil temp gauge
AEM air/fuel wideband gauge
Ignited flight switch panel
Ignited push start button
Ignited LED switches
That is everything I can think of right now if you would like to see pictures send me a PM of your email.
Performance Auto and Sound
Compression Performance
Repair Front Stabilizer Links as per TSB 07 03 08 003
Repair Rear Differential Vent (again)
Repair Rear Differential Vent (for a third time)- they placed a filter in the vent as per TECH SERVICE- the filter is part # 5651682 and the clamp is part # 22518665- 12,108 miles- 2/5/08
Convertible Top B-Pillar Tabs Installed for Roof Tearing
Driver's Side Door Handle Replacement (dealer broke it off)- replaced with part number 15773795 (handle)
Repair Differential Vent Tube (4th time)
Vent Tube Deemed Unrepairable- they replaced the entire differential using part numbers 2585822 (carrier), 89021677 (gear lubrication), and 1052358 (additive)
Called GM Customer Service to file complaint- Regional Manager declined any compensation for being in a rental over 1 month for warranty (after only 9 months of ownership)- related repairs- stated that there were aftermarket parts on the car, yet i was forced to remove them each time it went in for service- will continue to pursue being compensated with letter to Genera
