LinkBack (38) Thread Tools Display Modes
Old 08-12-2009, 02:51 PM   #31 (permalink)
xtrememedic's Avatar
Welcome to AEROSOL Mod Page
SLY NA
Performance mods:
  • AEM CAI
  • Clear Image Automotive Shorty Header (Ceramic Coated)
  • SOLO Hi Flow Cat Convert
  • SOLO SQR2 Dual Center Exhaust
  • Vector ECM Retune
  • DDM BackBone
Exterior
  • Brake Caliper Painted G2 Orange Paint
  • Solstice Decals on Calipers
  • Norms Center Exhaust Facia
  • Shorty Antenna
  • Front and rear mud gaurds
  • DDM Installed VDI's
Interior
  • Seat Belt Extender
  • Lil Chromes
  • Brushed aluminum Door Sill Covers
  • JPM Leather wrapped sun visors
  • JPM Center Console Wrap
"AEROSOL"
The First,The Orignal Since 2006
Peach State Kappa Club...New Web Site
Xtrememedic's Mod Page
xtrememedic is offline   Reply With Quote
Old 09-04-2009, 12:09 AM   #32 (permalink)
sunruner19's Avatar
Location: adirondacks, Northville, NY, So Yarmouth, Cape Cod, Ma
my mods
Short cut antenna 3 cents
gm color coded mud flappers
painted scuff guards
painted engine cover
Probeam and Backbone
license plate
09 Solstice GXP 5speed yellow,#000444
09 Tacoma 4wd Dbl cab auto 4.0L sc v6
10 Tundra 4wd 5.7L reg cab SR-5
04 Crossfire coupe
93 Corvette 40th annv 6 speed convertible
sunruner19 is offline   Reply With Quote
Old 09-04-2009, 06:45 AM   #33 (permalink)
1KULSOL's Avatar
Send a message via Yahoo to 1KULSOL
Welcome to 1KULSOL's Mod Page.
Her name is 1KULSOL Cool NA, No On-star/XM, Ordered 09/1/05 and Delivered 1/28/06.
52,985 miles as of 9/3/09.
Vanity License plate "1KULSOL"
NASSOA Founding Member F08010100033
Performance mods:
1. DDMWorks - stage 3 supercharger kit
2. DDMWorks - 4 – 1 LT header
3. DDMWorks - HiFlow cat
4. Solo Performance - SQR-2 custom exhaust (dual center outlet)
5. DDMWorks - Clutch/ Light Weight Flywheel/Pressure Plate Combo needed after installing stage 3 s/c kit
Electrical Mods
1. DDMWorks – LED Underhood Light
2. DDMWorks – LED Trunk light
3. InvisiCord – extension cable for my STi Driver radar Detector
4. Replaced stock horn with Advance Auto Parts Dual Air Horn.
5. Dashhawk mounted in speedo gauge
6. Chemist – Blue LED lighting running off of interior lighting circuit
7. Side marker and turn signal mod
Other Mods
1. Pioneer - Pioneer AVH-P4100DVD receiver
2. Pioneer - GEX-P920XM XM Digital Satellite Tuner for Pioneer Head units
3. Tire Rack - Bridgestone Potenza RE-760 Sport - 255/45/18
4. Tire Rack – Kazera KZ-L wheels
5. JPM Coachworks - Custom Leather center console w/1KULSOL embroidered on side
6. JPM Coachworks – Performance Shifter w/Black Polymer ball
7. Norm's Fiberglass - Custom Rear Valence w/diffuser
8. Kappasphere - custom floor mats
9. Kappasphere - Lil Chromies
10. Windrestrictor - Custom Lighted & Engraved V1
11. DDMWorks – A-Pillar pod w/PLX gauges (AFR, Oil Temp & Boost)
12. DDMWorks – Extreme Backbone
13. DDMWorks – 4 Piston Big Brake Upgrade w/Blue racing fluid
14. DDMWorks - Chrome powder coated valve cover
15. DDMWorks – Black powder coated shorty antenna
16. DDMWorks - Koni Sport shocks
17. DDMWorks – ProBeam
18. DDMWorks - Shock Tower Brace
19. DDMWorks - SP cross drilled and slotted rotor
20. DDMWorks - SS brake lines
21. DDMWorks - Stainless Steel coil cover
22. DDMWorks – Big Brake Kit 4 piston calipers in RED
23. GM Mud Flaps on rear
24. Popped the GM Chicklets pimples
25. Rear of car debadged – added 1KULSOL badge to center
26. Latin Venom Custom Solstice Cooler for the trunk (3)
Link to !KULSOL's mod page:
http://www.solsticeforum.com/forum/f...45/#post887478
1KULSOL is offline   Reply With Quote
Old 09-04-2009, 09:11 AM   #34 (permalink)
duckSol's Avatar
WELCOME to duckSol’s SLY MODS Page
SLY is a “Deep Gray” 2008 GXP loaded
Go-N DEF Disclaimer #2: This post, in no way, shape, or form, means that I have actually modified/changed/driven my car. That could, after all, void the warranty!
09/04/2009 revision
Interior
Silly Putty in cockpit glove box for stickum on
Round GPS mount over Air Bag light
JAZZ overlay on waterfall
Coat hanger tabs behind both seats replaced by velcro, didn't work.
Velcro remains, but added suction cup hangers on hump and those appear to work for now.
Rain-X anti-fog on windows
Smoke gray wind restrictor with FELT tabs removed 8-30-09, felt tabs not needed and were 'moving' around, like wandering???
NC max legal window tint (front top is 4” wide Max legal in HI is 3”)
Exterior/Body & Appearance
Custom Norms Fiberglass center dual exhaust fascia SLY gone SOLO
Door ding removed at MECCA 2009
Trunk alignment at MECCA 2009
Surround seal & ubber replacement with top adjustment by dealer April 2009
AC/H control modification (resistor installation) by delaer April 2009.
GM Molded Mud Flaps
Black stubby antenna
Partial de-badge
“SLY” in place of Pontiac (Sky & L300 badge Dremel bash)
SOLSTICE removed
Chicklets gone
JAZZ overlays all around
TOTD dragon on fascia above quads
GM SOLSTICE car cover
Dealer decal removed (Dealer magnetic door sign available for parades & events)
Lots of race style decals accumulating, some magnetic/vinyl others to be magnetic/ vinyl mounted
Detail
Meguiar’s
Rain-X
Performance
SOLO Exhaust SLY gone SOLO
DDM CAI
DDM Tune
DDM Prototype IC and IC pipes
Suspension
DDM ProBeam
DDM Backbone
DDM Tower Brace
Functional/Other
Wrapped exposed hood cable release with heat shield tape
Nitro-Fil for tires
DDM Coil Cover
Engine cover gone
Blankie gone
Tool Time
Tiki Man SLY watcher in stall
Bling, semi-functional
Painted turbo heat shield with painted TOTD dragon
Heat shield bolts coated with high temp Aluminum paint
Next?
I know nothing, Nothing!
On hand to install
Dual Air Horns
FIAMM High Way Blaster
DDM powder coat calipers Aggressive
Coat non contact rust areas of rotors with powder coat.
5 gallons race gas Beetlejuice blended by EtherBreather
Slot/Drill Rotors by BBPW
Side marker flash mod
Chiropractic Adjustments
duckSol version of Dashhawk and Trunk Monkey under development-UPDATE DAS BOOT WEINER fully deployed for High Country Cruise 9-4-09.
Repaint surround with ghost cooties climbing the surround on one side then being eaten by a dragon at the center and pooped out the dragon down the other side of the surround.
FOUNDING MEMBER NASSOA
duckSols Mods revised 9-4-09
Transformer SLY
"Okolemaluna"
duckSol is offline   Reply With Quote
Old 09-04-2009, 10:54 AM   #35 (permalink)
King-Oka's Avatar
King-Oka's mod page
Welcome to King-Oka's Mod Page.
2006 Solstice ENVIOUS /Darkside/ 2.4N/A / Grey/Black cloth interior/ 5 speed transmission /FE2 Suspension/ Polished stock wheels/Goodyear RSA's/ NO Options - Came bare bones,with only 4,000kms with hand crank windows, manual locks, no trip odo, no DIC etc.
Delivered Jan '06, I bought it used 7/7/07
Performance mods:
DDM Stage 2 bought used from Bowhunter1331 (one of the first DDM kits?)
DDM Intercooler & ECM Tune (Replaced previous Autowerks Tune)
Solo Performance SQR2 Cat Back Exhaust
Solo Performance High Flow CAT (Replaced previous DDM CAT)
DDM Race Backbone
Other Mods
Norms Center dual rear diffuser style valance (Envious)
DDM Stainless Coil Cover
Brent Frankler Airbag cover decal
Inverted Licence plate holder
ASAP Backup light covers
Aftershock clear side markers
Green LED side marker lights
Green LED underhood lights
Green LED Park/Indicator lights
Autosound Plus security system c/w remote truck open
GM Splashguards
Front park light covers (on order)
Wish List
Clutch upgrade
New booties
ASAP Stripes
Audi or projector style headlights
Norms fenders and skirts
AVIC D3 or equal sound system c/w Nav,backup camera and bluetooth
See King-Oka's mod page here
http://www.solsticeforum.com/forum/f...tml#post887582
Old 09-07-2009, 09:06 PM   #36 (permalink)
Originally Posted by PubliusE View Post
Welcome to PubliusE's Mod Page.
Cool GXP - VIN#4380, Black Interior with Red Stitching. Loaded except 6 disk CD. Picked up 9/30/08
Cool NA - VIN#3231, Ordered 4/15/05, Born 10/14/05, Delivered 11/15/06, Traded 9/30/08
Engine Mods:
  1. GMPP Stage II Turbo Upgrade
  2. GMPP Cold Air Intake
  3. MBRP Stainless Intercooler Charge Pipes
  4. MBRP GXP Turbo Stainless Heat Shield
  5. DashHawk
Exterior Mods:
  1. Red Painted Calipers with white Solstice Lettering
  2. Foose 18x8.5 Chrome Nitrous Wheels My New Wheels
  3. Goodyear Eagle F1 GS-D3 245/45/18
  4. ASAP Slotted Silver Backuplight Covers
  5. GM Splash Guards (4)
  6. GM Bodyside Protective Film
  7. Sylvania Silverstar Headlamps
  8. Stealth Driving Light Lamps
  9. Shorty Antenea
Interior Mods:
  1. ASAP Solstice Silhouette Airbag Cover Plate
  2. Solstice Silhouette Visor Covers
  3. JPM Center Console Cover - Black with Silver Alcantara Center
  4. Kapashere Lil Chromies
  5. GMPP Pedal Covers
On Order and Coming Soon:
  1. RPI GT Series Exhaust
  2. AutoTrim Design GXP Bodyside Graphics
Love to see a pic of the painted brake calipers before I decide to do hers.
mickeykelley is offline   Reply With Quote
Old 10-15-2009, 02:28 PM   #37 (permalink)
SLY NA
Performance mods:
  • AEM CAI
  • Vector ECM Retune
Exterior
Interior
  • Lil Chromes
TEAM SAVE THE TA TA"S
"AEROSOL"
LinkBacks (?)
LinkBack to this Thread: http://www.solsticeforum.com/forum/f62/index-owners-mods-42145/
Posted By For Type Date
New Addition to my Family... NEW SKY - Saturn Sky Forum Post #0 Refback 11-11-2008 09:48 AM
Please Post Your SKY Specs - Saturn Sky Forum This thread Refback 11-09-2008 10:24 PM
Relocation of Rear View Mirror. - Solstice GXP Owners Forums This thread Refback 11-08-2008 04:00 PM
Westers Garage Tune 07-08 GXP - Page 5 - Solstice GXP Owners Forums This thread Refback 11-06-2008 10:21 AM
painted dash panel - Page 2 - Solstice GXP Owners Forums This thread Refback 11-05-2008 04:24 PM
any one see this??? - Solstice GXP Owners Forums This thread Refback 11-05-2008 09:56 AM
Nitrogen filled tires - Page 4 - Solstice GXP Owners Forums This thread Refback 11-05-2008 12:02 AM
GM Bailout was Denied! - Saturn Sky Forum Post #0 Refback 11-04-2008 09:51 AM
What Differential Leak? - Page 4 - Solstice GXP Owners Forums This thread Refback 11-04-2008 06:19 AM
Smooth Line Hardtops Now Available - Solstice GXP Owners Forums This thread Refback 11-03-2008 10:46 AM
Hello and Question - Solstice GXP Owners Forums This thread Refback 11-03-2008 06:38 AM
T2 and SSB championship decals - Page 2 - Solstice GXP Owners Forums This thread Refback 10-31-2008 06:06 PM
Performance Adjustments - Necessary to Reflash? - Solstice GXP Owners Forums Post #0 Refback 10-30-2008 02:35 PM
Damaged During Oil Change - Page 3 - Solstice GXP Owners Forums This thread Refback 10-29-2008 09:39 PM
bsr tune Vs. Westers Tune - Solstice GXP Owners Forums This thread Refback 10-27-2008 08:45 PM
New wheels and tires - Solstice GXP Owners Forums This thread Refback 10-27-2008 01:13 PM
Hello and Question - Solstice GXP Owners Forums Post #0 Refback 10-27-2008 04:27 AM
Hello and Question - Solstice GXP Owners Forums Post #0 Refback 10-26-2008 11:09 PM
9/28/08 - 2009 Price increase - Solstice GXP Owners Forums This thread Refback 10-26-2008 09:57 PM
Hello and Question - Solstice GXP Owners Forums This thread Refback 10-26-2008 09:20 AM
Need opinions on what to do with wrecked sky redline car - Saturn Sky Forum Post #0 Refback 10-25-2008 09:48 PM
Does your Solstice have a name? - Page 2 - Solstice GXP Owners Forums Post #0 Refback 10-25-2008 06:37 PM
Winter Storage - Solstice GXP Owners Forums Post #0 Refback 10-24-2008 07:01 AM
bsr tune Vs. Westers Tune - Page 3 - Solstice GXP Owners Forums This thread Refback 10-23-2008 07:25 AM
Battery removal...how? - Solstice GXP Owners Forums This thread Refback 10-22-2008 11:58 AM
Moteur de recherche lo.st : Infos, Photos, Videos This thread Refback 10-21-2008 11:05 AM
Dyno Day 17 Nov Odenten MD - Solstice GXP Owners Forums Post #0 Refback 10-20-2008 06:02 PM
Attention St. Louis Skys and Solstices - Saturn Sky Forum Post #0 Refback 10-20-2008 01:41 PM
Battery removal...how? - Solstice GXP Owners Forums This thread Refback 10-17-2008 09:57 PM
New Mach and Cat installed today - Page 2 - Solstice GXP Owners Forums This thread Refback 10-14-2008 09:33 AM
St Louis Area Fall Foliage Run Oct 12th - Page 3 - Saturn Sky Forum Post #0 Refback 10-14-2008 01:06 AM
Is 260hp going to be enough for you? - Page 8 - Solstice GXP Owners Forums This thread Refback 10-13-2008 09:31 PM
Norm's New Stuff - Solstice GXP Owners Forums Post #0 Refback 10-13-2008 04:35 PM
Changing Battery Question - Solstice GXP Owners Forums This thread Refback 10-13-2008 04:51 AM
PIcs ST Louis Fall Run - Saturn Sky Forum Post #0 Refback 10-12-2008 10:21 PM
Owners Photo Gallery - Page 3 - Solstice GXP Owners Forums Post #0 Refback 10-08-2008 06:16 AM
New Aftermarket Radio options - Saturn Sky Forum Post #0 Refback 10-07-2008 09:11 PM
Cool WindRestrictor - Solstice GXP Owners Forums This thread Refback 10-07-2008 09:41 AM
