Old 06-25-2008, 11:17 AM
Ben Washburn's Avatar
i would definitely be intrested
2008 Pontiac Solstice Mysterious
Leather seats
6-disc cd changer and monsoon stereo
chrome 18'' wheels
drivers mounted controls on wheel
Darkside top
cruise control & fog lamps
catback exhaust system
its a solstice!, need i say more?
Ben Washburn is offline
Old 06-25-2008, 11:28 AM
Yamatr3's Avatar
Originally Posted by Krelubot View Post
You could get some clear two-part resin and use that. First you would need seal or tape the top of the part. Then flip the sill over and make a small resevoir out of tape all the way around where you want the clear to be. Mix the resin, pour it in, and let it dry. Model railroaders do this for water effects all the time. A hobby store that speciallizes in model trains could help you get the material. You may need to do some finishing or polishing once you remove the tape.
Thats a pretty good idea, I'll look into this.
Yamatr3 is offline
Old 06-25-2008, 06:34 PM
I want lighted door sills...
2007 Aggressive GXP "Natsumi"
GMPP Intake
Lithium Lotus is offline
Old 06-25-2008, 06:43 PM
EndiSky's Avatar
I have been speaking w/ some friends that work in a few industries that apply the the situation here.
After putting all of the pieces together I think this might be something that we can do.
Yamatd3, will I be stepping on anyones toes if I were to start working on this?
EndiSky is offline
Old 06-25-2008, 08:38 PM
Deepbluegxp's Avatar
I want them also
Team Solstice 2008
Click My modifications
See my car on cardomain.com
NASSOA Founding Member #48
Deepbluegxp is online now
Old 06-25-2008, 08:59 PM
LOST SOL
MSG_McKee's Avatar
Sweet ... I want lit door sills too. I have another idea that no one else has done (yet), but just never seem to have enough time ... too many other mods on my wish list!
Current sMiles: 21,622
Click Here To See My Mod Page
MSG_McKee is offline
Old 06-25-2008, 09:06 PM
Yamatr3's Avatar
Not at all. Go for it!
Yamatr3 is offline
Old 06-30-2008, 08:28 PM
rlhammon's Avatar
Originally Posted by Deepbluegxp View Post
Agree some what to the 2nd suggestion. I wasn't going to say anything and try this at home but this is what I plan on doing.
Cutting the letters on the aluminum sill would be a PITA, so cutting the whole oval section out and gluing in a thin plexi-glass piece with that was roughed up or sand blasted, then the letters Solstice or what ever masked off and painted. Only one led would be required to light the plastic. The paint plus clear coat should make it durable.
This idea or finding a large sheet of that blue "timex" glowing material they use in watches would work as well.
Not sure of what that material is, but I know it's out there and available in a think material that you would be able to fit under the door sill and cut out the "text" above.
rlhammon is offline
Old 06-30-2008, 08:56 PM
The sandblasted pexi would do the same affect as the Wind Restrictor engraving.
Team Solstice 2008
Old 06-30-2008, 10:15 PM
EndiSky's Avatar
Electroluminescent Tape, working on it!
My hesitation w/ going that route is that the area WILL get scuffed up so acrylic in my mind is a no-go.
EndiSky is offline
Old 07-01-2008, 12:06 AM
SOLster's Avatar
Actually when tyou sandblast the surface it etches it so scuffing may not even happen unless your wearing metal spiked shoes or something. If you're still concerned, another alternative is to use polycarbonate which is tougher. It's also more pricey and requires more effort to work on. But it will be much more durable than acrylic and may give you the same lighting effect that you're trying to acquire. Good luck with the project. Sounds like you'll get some interesting results in the end.
Rudy (aka SOLster)
aftershockproducts.com
VIN# 110120: Cool Silver N/A purchased 5/5/06. TRADED IN 5.6.07
VIN# 125623: Cool Silver GXP purchased 5/6/07
Mods: 19" Gravana J2 rims & Goodyear Eagle F1 GS-D3 tires, Kappashield, Eibach's Pro-Kit Lowered springs, SOLO Center Exaust, Norm's Center Diffuser, & BSR tune.
AFTERSHOCK accessories: Vent & Shifter Rings, Rear Spoiler (painted) , Front Marker Clear Lenses, PROTOTYPE: Side Skirts and Recessed Grills.
SOLster is offline
Old 07-01-2008, 06:36 AM
Try this web site. Electroluminescent panel/El tape/back light with 12V inverter
Team Solstice 2008
Old 07-01-2008, 07:33 AM
rlhammon's Avatar
If that's the case, why not use a piece of the 3M material we use for stone chip protection. It's clear, durable, and cheap enough to put a piece over the top and protect anything under it.
rlhammon is offline
Old 08-15-2008, 10:21 PM
   Any progress on this
Just bumping this back on the page.
Triple Blk is offline
