Old 08-09-2008, 07:51 PM
   New Wind Restricter and A-Pillar gauges installed
Lucy'sDaddy's Avatar
I FINALLY got a chance to get some CNC machine time last Saturday to make this custom wind restricter that I designed myself. Pretty happy with the way it came out. It's made out of Polycarbonate, not Acrylic, so I can't light it up, but on the other hand, it won't break like the Acrylic will. By the way, Lucy is the name of the car
The A-pillar gauge pod has been in a couple of weeks, but I feel the gauge brightness is low, and 1 didn't display at all, and had to send it back for repair, which they said nothing was really wrong with it. Works now, that's all I know. The gauges are Aeroforce Interceptor gauges, which are OBD II units. They can display up to 52 functions the car monitors, each gauge having 2 displays. It's actually 4 gauges in 2. They also can diagnose error messages, whether engine, body, chassis, or whatever. You can manually turn on the engine fan with them. They can record data, like the Dashawk, just not as long. They can record 1/4 mile performance stat's, like 60ft, 1/8 mile, and 1/4 mile times and speeds, and save them.
They just plug into the OBD II port, so SUPER easy to install.
OOOHHH LUCY! U GOT SUM SPLAININ 2 DO!
Lucy'sDaddy is offline
Old 08-09-2008, 07:55 PM
spiky3480's Avatar
Those look awesome...both the gauges and the WR. I really like the Interceptor gauges.
2007 Mysterious GXP
INTRUDER Modifications (74)
TEAM SOLSTICE 2008
Northeast Mod Meet
Exhaust Sound Clips
spiky3480 is offline
Old 08-09-2008, 09:55 PM
Yamatr3's Avatar
Very nice!! I like the dual function of the gauges!! I might have to look into those...
Yamatr3 is offline
Old 08-09-2008, 10:56 PM
DirtyMike's Avatar
Looks nice
I ordered those guages yesterday, did you have to give it 12V?
07 Sky Redline, 5 spd manual, black w/ black & red int, spoiler
2008 NOPI FL Car Show Series-ECOtec Class 1st Place
CAI & ICP
HID-low & fogs
stubby ant.
5% tints
RPi GT Exhaust & Race Pipe
Hahn IC
Dejon BOV Spring
Dual Aeroforce Guages
DDM ProBeam & A-Pilar
Wester's race tune
TenzoR DC-5 v.1
Eibach Sportlines
JPM Shifter...pending installation
DirtyMike is offline
Old 08-10-2008, 07:21 AM
They say no to adding 12v to CAN bus cars. They just plug into the OBD II port. Powered by that. I fished the cable thru the dash in the corner under the window, by the other cable.
Old 08-10-2008, 07:56 AM
flatdab's Avatar
Where did you get the gauges? those are nice.
flatdab is offline
Old 08-10-2008, 09:26 AM
DirtyMike's Avatar
cool, thanks
2006-2008 Pontiac Solstice Accessories Store - PFYC they dont have the chrome ring but if you search around you'll find them
CAI & ICP
HID-low & fogs
stubby ant.
5% tints
Hahn IC
Dejon BOV Spring
Wester's race tune
TenzoR DC-5 v.1
Eibach Sportlines
Old 08-10-2008, 11:16 AM
compression's Avatar
Looks good. I really like the double fuction on the gauges. Saves alot of room in the car. I also might need to look into something like that.
Performance Auto and Sound
Compression Performance
compression is offline
Old 08-12-2008, 07:11 PM
I got them right from aeroforcetech.com, but there are a few suppliers out there, also. Each gauge is custom made, so no one stocks them. That's why I bought them from the factory. $410 including shipping for the 2 gauges, which is really 4 gauges. These are chrome bezel, black face, and red illumination, and IMO, match the factory gauges PERFECT!. Right now, after driving Lucy today, the gauges are set at ambient air temp, battery voltage, oil temp', and boost. There are 52 GM settings, but only about 20 are used by the Solstice. 2 additional analog sensors can be added, also. I like the ability to diagnose a check engine code with these gauges, as well as the performance recording abilities. The more I use them, the more I like them!
Old 08-30-2008, 06:42 PM
davytudope's Avatar
i had red ones on my last car. i could never read the faces in the day.
i see in your first picture that you are reading a/f ratio. is it wb? if so do they read the wb o2 from the obd2 or did you ad a sensor?
2007 "black" solstice gxp:stock
sold:2004 ion redline w/
cai, throttle body, zzp header, magnaflow, autometer dpss, 2 interceptor guages, adjustable tensioner, 2.8 pully, hurst shifter, hp tuners, wbo2, 42.5 inj, harness, front and rear trans mounts, autolite plugs, afco he, 6" fan, spec stage 3+ and flywheel, dss stage 2 axles
for the track: hoosier qtp's
http://s68.photobucket.com/albums/i18/davytudope/
davytudope is offline
