| License Number: |
Item | Description |
1 | Pop open the key fobs to verify the integrity of the solder joint to the battery retainer |
Exterior | |
1 | Verify operation of exterior lights |
2 | Inspect body panels for fit, condition |
3 | Check TPMS for function and tire pressure |
Engine Bay | |
1 | Visually inspect engine bay for condition clean as necessary |
2 | Verify brake fluid level and condition. DOT 3 change 3 years DOT 4 Change 2 years |
3 | Visually inspect condition of all charge tube clamps. |
4 | Check air cleaner filter element condition |
5 | Inspect the PCV valve for proper operation and connection |
6 | Check tightness of exhaust bolts, mounts |
7 | Check tightness of turbo shield |
8 | Inspect turbo oil lines |
9 | Inspect oil fill level and condition (fuel contamination) |
10 | Inspect / service battery terminals |
11 | Inspect / service engine ground terminal |
12 | Check all fluids. Verify mileage / life are within required values |
13 | Inspect forward fuse box and terminals for condition |
14 | Inspect hood / fender latches, lube as necessary |
15 | Inspect electrical cables for condition |
16 | Check condition of inner fenders |
17 | Check ECM is properly mounted and condition of connectors |
18 | Check radiator intake for blockage. Clean radiator with coil cleaner from Home Depot |
19 | Check status of anti corrousion fuel treatment and add as required |
20 | Check on age of belts and hoses |
Cockpit and Top | |
1 | Check tightness of top when up and locked. Adjust as necessary (left and right) |
2 | Query owner about wind noise. Adjust windows if necessary |
3 | Check condition of door handles, tighten / repair if required |
4 | Lubricate the sliding portion of top mechanism over the doors to preclude pinching. |
5 | Inspect side slider and lube as necessary |
6 | Visually inspect the slide plate over the doors for tightness and wear. Replace if necessary |
7 | Check operation of the roof latch, tighten as necessary |
8 | Visually inspect the windshield to top gasket. Looking for tears, holes etc. Lubricate |
9 | Check operation of buttress latches, lubricate / adjust as necessary |
10 | Verify proper operation of convertible top folding mechanism. |
11 | Verify condition of rear window glass and defroster |
12 | Treat all rubber seals with di-electric grease |
13 | Pull the center console and check for cracks. Install support if required. |
14 | Cycle both cupholders and check operation. Lube as necessary. |
15 | Check operation of dash trunk release button. |
16 | Pull the right carpet front and visually inspect BCM area |
17 | Visually inspect BCM fuses. |
18 | Cycle driver's seat height adjustment to verify operation. Lube as necessary. |
19 | Check operation of hood release latch, lube as necessary |
20 | Check dead pedal for condition |
21 | Check door hinges for operation, service as necessary |
22 | Verify condition of door body latches |
23 | For vertical doors verify fit and adjust. Lubricate |
Trunk | |
1 | Verify trunk latch operation |
2 | Check trunk operation. Verify condition of torsion bars / hinges |
3 | Check / service trunk lid hold down rubber feet. |
4 | Visually inspect trunk pressure release valve |
5 | Visually inspect flap cables for operation and condition. Adjust / Lube as necessary |
6 | Visually inspect trunk cable assembly, connectors etc. |
7 | Visually inspect and lube as necessary buttress latches |
8 | Check trunk light for operation |
9 | Check rear trunk drain area. Clean as necessary. |
10 | Verify operation of trunk forward drains, left and right. Clean as necessary |
Underside | |
1 | Inspect intercooler drain tube, check for presence of oil, water or contaminates |
2 | Inspect radiator for blockage, clean as necessary. |
3 | Inspect the front bumper and "chin" for scuffing or damage |
4 | Visually inspect inner fenders for rubbing / wear inside rear wheel wells |
5 | Inspect condition of wheel electrical connections |
6 | Check break pads / disks for wear |
7 | Visually inspect shocks for condition / leaks / operation |
8 | Check wheel hub bolts (three per wheel) for proper torque (or if missing) |
9 | Inspect the bottom attachment points for fenders and condition of fenders |
10 | Visually inspect the differential for leaks and condition of mounts |
11 | Verify condition of wheel bearing condition. |
12 | Inspect exhaust system for condition and tightness |
13 | Inspect condition of O2 sensor wiring |
14 | Check / torque wheels |
15 | Inspect tires for condition, wear |
