Punisher - Page 49 - Pontiac Solstice Forum
LinkBack (3) Thread Tools Display Modes
Old 01-06-2013, 04:18 PM   #721 (permalink)
BCM pic
With the carpets and all the trim removed, its time to clean everything up and start on construction.
Next is to de-rattle the dash. I have had an annoying rattle for the past year. I found one source on the far right end. Am checking else where before I start putting parts back on the car.
Old 01-06-2013, 08:08 PM   #722 (permalink)
cooper1340s's Avatar
Rob,
My question is: how the hell do you get the trunk switch out? What is holding it in place?
06 SLY, LS3/480 V8, Tremec 6 speed, 3.23 positraction Getrag diff, custom stainless steel true dual exhaust system w/high flow cats, carbon fiber rear valance, red pc calipers, DDM Works Stage 1 brake upgrade, garage door opener, custom fuse box cover, Red anodized engine covers, DDM Works console, Lambo doors, clear bra, DDM Works red racing backbone, DDM Works red pro beam, twin horns, Opel GT radio antenna, upgraded tires, conv top cover, de-badged, chrome rings around A/C controls
cooper1340s is offline   Reply With Quote
Old 01-06-2013, 10:06 PM   #723 (permalink)
I will take some pics tomorrow. It's held in with clips molded into the switch body. Because of the structure around the switch, I'm not sure if I could get at it in any case. Without pulling the airbag you can't even see the connecter.
I would just push it through the mount into the dash, then fish it into the glove box and disconnect the plug. You could install a new switch and push it through the hole from inside the dash.
Let me test this and see if it works.
Old 01-07-2013, 09:46 PM   #724 (permalink)
I looked again tonight. The switch has tow alignment tabs and two retention tabs. It is designed to come out through the front of the dash. There appears to be enough slack in the cable to allow you to pull it forward out of the dash and then release the connecters. There is no access to the connecter from the back, even with the air bag removed.
Old 01-08-2013, 06:07 AM   #725 (permalink)
Rob.
When you get the trunk switch out, can you take a couple of pictures of it so I can see what kind of retainer tabs are on it and where. I would like to take the little sucker out in one piece, if possible. Thanks.
Old 01-08-2013, 07:28 AM   #726 (permalink)
I will do it tonight. Since I have the dash sitting on the bench and the switch there too . . ..
Old 01-08-2013, 05:44 PM   #727 (permalink)
Here you go.
The switch has two alighment posts and two locking tabs. If you pull the switch straight out, it should release and come out.
But, in looking at my car, the pigtail to the switch looks too short to pass outside the dash where you could disconnect it. It looks like you need to release the connecter first.
Punisher-switch-close.jpg   Punisher-switch-side.jpg   Punisher-socket-front.jpg   Punisher-socket-rear.jpg   Punisher-switch-socket-back.jpg
Old 01-09-2013, 05:01 AM   #728 (permalink)
Thank you Rob. I am sure I will now be able to break that switch with no problem. :-)
Old 01-09-2013, 07:57 AM   #729 (permalink)
RedSkyMan's Avatar
Looking around on YouTube and found this video on Punisher that I hadn't seen before.
https://www.youtube.com/watch?featur...&v=PcmwTM3_WX4
Chili Pepper Red
Ordered 3-28-06
Delivered 6-29-06
Vin # 3963
Sent to Mallett 2-21-07
Delivered 5-11-07 # 007 "Beast"
LS-2 400 HP/368 RWHP
Magnaflow Custom True Dual Exhaust
RedSkyMan is offline   Reply With Quote
Old 01-09-2013, 08:01 AM   #730 (permalink)
Rick is the "new" tech that Dave hired specifically to do the V8 swaps. I was told that he had done similar work for several years for a different shop before coming to DDMWorks.
When I showed that video to Devin my local tech he about had a hernia!
But I must admit, I did enjoy it.
Old 01-09-2013, 08:10 AM   #731 (permalink)
RedSkyMan's Avatar
I have to admit I never had the guts to try a burnout in 'Beast'. Didn't want to break anything.
Chili Pepper Red
Ordered 3-28-06
Delivered 6-29-06
Vin # 3963
Old 01-09-2013, 09:45 AM   #732 (permalink)
I must admit that "occasionally" I turn off the TC and do a viking take off. It does some smoking but not like in these burnouts.
https://www.youtube.com/watch?v=6QmvSWjzqgc
Old 01-09-2013, 04:47 PM   #733 (permalink)
received new switch
Here are a couple of pics
Old 01-11-2013, 04:03 PM   #734 (permalink)
Took another look at the dash trunk release switch. I took some pictures of the connector, the connector through the mounting hole and with the switch connected on the end. I confirmed that the wire is long enough to penetrate the dash. It looks very much like you could pull the switch and the wire out through the mounting hole, release the connector, install a new switch and then push the assembly back through the dash into its proper location.
Punisher-connector-through-hole.jpg   Punisher-connector-through-hole-switch.jpg   Punisher-connector-distance.jpg
Old 01-11-2013, 04:04 PM   #735 (permalink)
I wanted to put a better picture of the driver's side floor. And the Cool Mat that will be going down starting tomorrow morning
LinkBacks (?)
LinkBack to this Thread: http://www.solsticeforum.com/forum/f62/punisher-65168/
Posted By For Type Date
Daily driver? - Page 2 - Saturn Sky Forums: Saturn Sky Forum This thread Refback 05-16-2013 10:28 PM
Building the Kappas. - Saturn Sky Forums: Saturn Sky Forum This thread Refback 05-16-2013 03:20 PM
Replace instrument cluster? - Saturn Sky Forums: Saturn Sky Forum This thread Refback 05-16-2013 02:10 AM
