Punisher - Page 52 - Pontiac Solstice Forum
 6Likes
post #766 of 2683 (permalink) Old 01-19-2013, 09:16 PM Thread Starter
screws inside the glove box
Name:	Glove Box left.JPG
ID:	20363   Click image for larger version
Carol's husband for 48 years
rob the elder is online now
post #767 of 2683 (permalink) Old 01-19-2013, 09:17 PM Thread Starter
Bump Stops in glove box
Name:	Bump Stops Glove Box.JPG
ID:	20365   Click image for larger version
Name:	Bump stop installed left.JPG
ID:	20366   Click image for larger version
Name:	Bump stop installed.JPG
post #768 of 2683 (permalink) Old 01-19-2013, 09:19 PM Thread Starter
Mounting the knee brace under the steering wheel
Name:	Knee bracket.JPG
ID:	20368   Click image for larger version
Name:	Knee mouning screws right.JPG
post #769 of 2683 (permalink) Old 01-19-2013, 09:21 PM Thread Starter
Mounting screws for rear cupholder
Name:	rear cupholder mounting screws.JPG
ID:	20370   Click image for larger version
ID:	20371   Click image for larger version
Name:	Mounting screws.JPG
post #770 of 2683 (permalink) Old 01-19-2013, 09:23 PM Thread Starter
Radio alignment pin on the back goes into a hole in the mounting structure to support the radio.
Forward console mates to the dash with a hook and an alighment pin on the right side, as well as three screws
Name:	Radio Alignment pin.JPG
ID:	20373   Click image for larger version
Name:	Fwd console rear.JPG
ID:	20374   Click image for larger version
Name:	fwd console mounting bolts.JPG
ID:	20375   Click image for larger version
Name:	forward console top.JPG
post #771 of 2683 (permalink) Old 01-19-2013, 09:32 PM Thread Starter
Airbag is installed. The cover was a load of fun. You need to install the pyro unit without the cover, then install the cover through the dash. I had to hook the back (top) hooks then fit it into the dash. There are a set of hooks that are attached to the pyro unit and another set of hooks that grab the edges of the dash opening. Its really fun to get it installed.
Name:	Waterfall new paint mounted.JPG
ID:	20377   Click image for larger version
Name:	Airbag installe3d.JPG
ID:	20378   Click image for larger version
post #772 of 2683 (permalink) Old 01-20-2013, 11:51 PM Thread Starter
I got the car put back together. Took it out for a couple of test hops this afternoon. Was going to post pics of the assembly and final results, but .....
But...
I was watching the Ravens kick butt when I closed the garage door. An old floor mop fell into the path of the door on one side. The door crashed, the retract spool on that side jumped off the pulley and it took me three hours to disassemble the door, lower it so I could get at the pulley and springs, and reattach everything. Then I had to preload the rings, put the door back into the tracks and stop the bleeding
Don't ask!
Pictures tomorrow.
I will offer one comment. I took Punisher out for a short hop, then took Green Dragon out for a warmup and battery charge. Driving them back to back was interesting. The Dragon is a 2.0 with the GMPP tune. It was pick but I kept waiting for it to hit the cam and launch ..which of course it can not do like Punisher does
post #773 of 2683 (permalink) Old 01-21-2013, 08:44 AM
SolNut's Avatar
Garage doors are NASTY! I read that more homeowners get hurt fixing them than any other home repair.
Be careful out there.
Steve
eCar
SolNut is offline
post #774 of 2683 (permalink) Old 01-21-2013, 01:56 PM Thread Starter
Steve
Yes, I can believe that! If the damn things done break and fall on you then you break your face preloading the springs.
post #775 of 2683 (permalink) Old 01-21-2013, 02:21 PM Thread Starter
Here are a few pics. Shows the front drivers side kick panel. The clips on the back, there are two that mate with holes in the door leading edge and one that mates with the side panel structure. The dead pedal then mounts via two studs / nuts. The rear stud / nut is covered with a rubber cap to prevent damage to your shoes and to keep it clean.
Name:	Kick panel left.JPG
ID:	20396   Click image for larger version
Name:	Kick panel 2.JPG
ID:	20397   Click image for larger version
Name:	Drivers side kickplate.JPG
ID:	20398   Click image for larger version
Name:	Dead pedal installed.JPG
post #776 of 2683 (permalink) Old 01-21-2013, 02:25 PM Thread Starter
I found this - autograph? on the back of the right side kick panel. Anyone have any thoughts about it?
Name:	Back side sig kick panel.JPG
post #777 of 2683 (permalink) Old 01-21-2013, 02:28 PM Thread Starter
Installed the connectors on the back of the boomarang. It takes three hands but made due.
There are a number of clips around the edges of the boomarang that mate with slots in the dash.
I then began to install the trim pieces around the gauge cluster. Mine come apart in two pieces, the black tunnels and then the outer trim bezel. It makes for easier cleaning. Also, I had to pull the trim and the clear plastic cover over the instrument cluster to reset the speedo needle which was an easy job.
Name:	Boom clips 2.JPG
ID:	20403   Click image for larger version
Name:	Boom clips close.JPG
ID:	20404   Click image for larger version
Name:	Boom in, no cluster trim.JPG
ID:	20405   Click image for larger version
Name:	cluster outer trim going on.JPG
ID:	20406   Click image for larger version
Name:	Cluster trim in place.JPG
post #778 of 2683 (permalink) Old 01-21-2013, 02:30 PM Thread Starter
Here is the pieces of the trim coming together
Name:	Cluster trim inserting.JPG
ID:	20408   Click image for larger version
Name:	cluster trim rings inserted.JPG
ID:	20409   Click image for larger version
Name:	Cluster trim in place totally.JPG
post #779 of 2683 (permalink) Old 01-21-2013, 02:33 PM Thread Starter
I got the right seat installed. Getting the studs to mount up with the holes in the seat rails turned out to be an unexpected joy! I ended up using a pry bar to get it lined up. Some fun.
This is my helper. A Carin Terrior named Cody. He was into everything of course.
Name:	Pass seat installed.JPG
ID:	20411   Click image for larger version
Name:	interior installed with dog.JPG
post #780 of 2683 (permalink) Old 01-21-2013, 02:36 PM Thread Starter
The center console cover has two tabs on the front that go under the forward console and two tabs that lock into slots in the waterfall in the rear.
Name:	center console forward tabs.JPG
ID:	20413   Click image for larger version
Name:	center console tab close.JPG
ID:	20414   Click image for larger version
Name:	Center console installed.JPG
« Aftershock??? | - »
  LinkBacks (?)
LinkBack to this Thread: http://www.solsticeforum.com/forum/f62/punisher-65168/
Posted By For Type Date
Daily driver? - Page 2 - Saturn Sky Forums: Saturn Sky Forum This thread Refback 05-16-2013 11:28 PM
Building the Kappas. - Saturn Sky Forums: Saturn Sky Forum This thread Refback 05-16-2013 04:20 PM
Replace instrument cluster? - Saturn Sky Forums: Saturn Sky Forum This thread Refback 05-16-2013 03:10 AM
