Spinning Little Chromies??? - Pontiac Solstice Forum
Old 08-29-2008, 07:49 AM   #1 (permalink)
AdamVIP's Avatar
I installed my little chromies this morning and the drivers one is nice and snug but the pasenger side just keeps spinning and will slide up and down if I try to use it to unlock or lock the door. I put on plenty of the red goo that came with them. Im gonna let it set up for awhile but judging on how the drivers side locked in Im thinking the passenger side one is not going to stay put.
Anyone else have this problem?
Victoria
2007 GXP Manual.
AdamVIP is offline   Reply With Quote
Old 08-29-2008, 08:39 AM   #2 (permalink)
elwood58's Avatar
The instructions say to let the adhesive setup for 24 hours. It is unclear from your post whether you waited that long. I did not touch mine for 24 hours, and have had no issues with loosening.
PS - It was great meeting you at the SoCal Dinner last night.
Former Owner of a 2008 SLY GXP Auto with all of the goodies
elwood58 is offline   Reply With Quote
Old 08-29-2008, 09:06 AM   #3 (permalink)
Yamatr3's Avatar
Sounds like the threads are stripped on either the Lil chromie or the stem. What elwood is saying makes sense, put the red loctite on and let it set for 24 hrs. It should be fine after that.
Old 08-29-2008, 10:07 AM   #4 (permalink)
AdamVIP's Avatar
ok. I just noticed that it was spinning immediatly after I put it on. The drivers side spun till it locked up. Ill give it a day and see what happens
Victoria
2007 GXP Manual.
Old 08-29-2008, 04:42 PM   #5 (permalink)
Critterman's Avatar
Did you twist them on when you put them on? They should only stick up about 3/8" when the door is locked.
DDM stage III w/custom CAI
DDM Stage III Upgrade here
Old 12-06-2012, 12:30 PM   #6 (permalink)
I bought metal ones and made them work
Although little chromies sound cute and all...I wanted something different. I ordered some metal knobs with red crystals on top. I easily removed my original knobs from my 2009 Solstice by turning them counter-clockwise with pliers...one broke...no going back. The new knobs were too tall. I cut them to the correct height using a wet saw. The next problem I ran into was the drilled hole was not wide enough. I used my drill and a metal bit to ream out the hole until it was big enough. I then used Gorilla Glue to attach. I did not read the directions until after I put them on...you are supposed to use water with Gorilla Glue. One knob came off easily and I added water and then put it back on. The other had set already so I left it alone figuring moisture in the air will eventually get to it to finish the job. Anyway...I am an idiot and figured this out. I now have two new shiny gem encrusted knobs!
texxy is offline   Reply With Quote
Old 12-06-2012, 10:36 PM   #7 (permalink)
Sly Bob's Avatar
I hope the crystals aren't bigger than the shaft otherwise you won't be able to get the door panels off down the road. Pics?
Delivered on May 27, 2008
Sly Bob is offline   Reply With Quote
Old 12-07-2012, 11:05 AM   #8 (permalink)
I installed mine with some silicone so that I could still remove them if needed even though mine are pretty much cylinders and allow the door panel to come loose without removal of the door lock knob. No issues so far.
Old 12-07-2012, 11:45 AM   #9 (permalink)
Dang, CS, total SNAP! I used silicone too - same reasons.
Old 12-07-2012, 12:21 PM   #10 (permalink)
Great minds . . . ha ha ha. In all seriousness, I've been looking into these oil breather tanks versus catch cans, posted a thread here:
Oil Catch Can vs Oil Breather Tank
Care to chime in? Curious about what your opinion would be.
Old 12-07-2012, 03:54 PM   #11 (permalink)
OK - replied there.
