Old 06-08-2008, 09:45 PM
Supporting Tuner
DEJON-Dave's Avatar
Originally Posted by GhostRL View Post
The short answer is that does the same thing as Dave's mechanical solenoid valve... and we can't get in touch with MTS to see if they can modify it somehow to make it more approriate to what we're trying to accomplish
I hope by Wednesday night to have a new design IAT2-Reg tested out.
Founding Member #6
DEJON-Dave is offline
Old 06-13-2008, 02:10 PM
NightwingII's Avatar
Did you manage to get the test done?
2007 Mysterious GXP Red Stitching
All Options minus OnStar
Solo Mach Shorty Exhaust
Solo Hi Flow Cat
Dejon Intercooler Pipes
Dejon Wastegate Spring
Wastegate adjusted
NightwingII is offline
Old 06-13-2008, 02:55 PM
Supporting Tuner
DEJON-Dave's Avatar
Not yet, we got slammed with orders this week (stimulous checks) I'll be working on it tomorrow
Founding Member #6
Old 06-13-2008, 03:18 PM
XplosivePlushToy's Avatar
Oh Good God! I think I need to change my shorts. Those numbers are awesome!
As soon as I get settled down in my new apartment next month (separating from the Marine Corps ) I'll definitely be ordering this kit, along with new I/C piping and the Dejon intake.
I support our Supporting Vendors, one paycheck at a time!
My CarDomain!
My Mods@The Mod Thread
XplosivePlushToy is offline
Old 06-13-2008, 04:06 PM
GhostRL's Avatar
Send a message via AIM to GhostRL
Dave shoot me a PM or an EMail with your results
2007 Sky Redline
Dejon 5027BB & Piping - RPI I/C - Magnaflow+Cutout
365 RWHP 351 RWTQ
2002 Honda RC-51 RVT
GhostRL is offline
Old 06-24-2008, 08:21 AM
Beau's Avatar
Can we get a graph on this bish.
Beau is offline
Old 06-25-2008, 04:17 PM
GhostRL's Avatar
I already posted it.
http://i304.photobucket.com/albums/n...g?t=1212442514
2007 Sky Redline
365 RWHP 351 RWTQ
GhostRL is offline
Old 06-30-2008, 09:17 AM
Beau's Avatar
Thanks Ghost, not sure how I missed that.
On that graph it obviously gets real rich top end, is that to reduce knock? It killed power numbers.
Beau is offline
Old 07-02-2008, 06:15 PM
GhostRL's Avatar
Thats the computer going into limp mode on the graph. AFR was steady 12:1, regardless of what you see there.
2007 Sky Redline
365 RWHP 351 RWTQ
GhostRL is offline
Old 07-04-2008, 10:09 PM
Beau's Avatar
OK so you mean you tuned it for 12:1 but it obviously wansn't running that top end, so its the limp mode killing the power. Hrm. I wish we could get around that : /
Beau is offline
Old 07-06-2008, 09:35 PM
Supporting Tuner
DEJON-Dave's Avatar
You can get around it, I do. With a Manual Boost controller and either our "Over-BOOSTER" or IAT2-Reg set at 23psi.
Founding Member #6
Old 07-09-2008, 10:18 AM
ender's Avatar
What were the little bugs you encountered with the turbo kit?
Thanks,
Russ
Well I got the sky strapped down since I finally worked out all the little bugs in the dejon 5027RE turbo kit.
Dejon 5027 Ball bearing turbo kit with Garrett 5027RE by Precision Turbo
Dejon Pipes + Greddy RS BOV
Dejon Boost controller
Dejon 2.75" Ceramic coated catless DP
Magnaflow 3" Exhaust
QTP 3" Stainless Electric cutout (It was CLOSED on all of these runs so the dyno would reflect street performance. Could probably gain 10hp or more up top with it open)
Fujita Intake (This HAS to go, it is way too small at 2.5" for this setup and doesnt fit the dejon correctly, going to a 3" dejon intake to match)
RPI Intercooler
Westers Base tune to eliminate ecm nannys and up to 7000 rpm limiter with adjusted fueling through HPTuners by me
93 OCTANE PUMP GAS!
SAE Numbers
21 Psi - 333 RWHP - 301 RWTQ
23 Psi - 341 RWHP - 341 RWTQ
25 Psi - 365 RWHP - 352 RWTQ
The 23 and 25 psi runs stopped early at 5600 rpms, the fuel isn't there on the current tune (I tuned it at 21 psi) for it to pull all the way to redline, But I imagine at 25 psi she stands to pull to close to 400rwhp on PUMP GAS if the graph continues like the 21psi pull was, perfect nice and smooth. It was HOT HOT HOT outside, 92-95 degrees on each pull ambient and 30% humidity. I'll post the sheet tonight when I get home from my parents' house.
Lookout hahn racecraft, you're about to lose the quickest 4cyl kappa title when I can get back to the strip and put some race gas in her
Speed Is Life
ender is offline
Old 08-03-2008, 08:31 AM
Howcome you ended all the runs at 6500? It looked like it was still making power. I think it will sustain torque for another 1K at least.
BaldTurboFreak is offline
