Old 06-14-2008, 10:28 PM
   BTF Racing GXP turbo upgrade ready! Q& A thread
Check out vendor row, the group buy is on!
Ready for production and rear tire deconstruction!
BaldTurboFreak is online now
Old 06-15-2008, 07:17 AM
I notice it comes with a cat delete pipe. Is this a fitment thing or a performance thing? Will it still fit with a 3" (non-factory) cat?
Victoria
2007 GXP Manual.
AdamVIP is offline
Old 06-15-2008, 07:38 AM
It's both, with the external gate inside there (and inverted) to hide it from the prying eyes of the public it was impossible to put an adequatly sized Cat in the stock locale.
Actually scratch that, the stock cat would fit with the right endtank -just wouldnt have the WG flow coming thru it.
I have a few monolith's in mind that will physically fit and be adequate in Mass to not turn into a platinum/ceramic mess after 4 or 5 full throttle blasts (your doubling the heat input with all this "extra" power).
If sufficient demand exists, I will proceed with the engieering of a correctly sized and performance oriented Catalyst. It will be then offered to kit owners that require it at an very inexpensive rate.
All exhuasts that will bolt up to the stock cat flange will work fine. All mods after the factory compressor discharge elbow will work fine. (intercoolers,piping from Hahn or Double D should fit no prob).
But other manufacturer's downpipe or highflow cat's wont directly bolt on here. The position of the turbine shaft is lower and spread more twards the pass side of the vehicle to fit that honkin' GT30 in there.
Old 06-15-2008, 11:14 PM
Morfious's Avatar
Originally Posted by BaldTurboFreak View Post
I openly share the tune nessicary for it, however without a wester's torque delete/rpm unlock you cannot take FULL advantage of what this setup has to offer.
My kit consists of the following:
1) Ball Bearing Garrett GT3076R w/custom Tial SS housing in your choice of A/R
1)Mild steel Catless downpipe (v-band no gasket at the turbo to leak)
1)Black 38mm Tial wastegate w14.7psi spring
1)Bosch recirculator valve
1)4" intake pipe with enourmous cotton-gause filter (for C6 vette)
2)6mm oil drain bolts
1)6mm drill bit
1)braided oil feed line
2) 4" hoseclamps
1) Garrett turbine speed guage/datalogger kit (part #781328-001)
your choice of color in powdercoat on the intake and compressor housing
Posted free tune for those with HPT
BTF a few questions for a very intrigued buyer!
Will this system pass state emissions without a cat? It's not something I have to do for a while but it would be nice to know.
Since I already have the Westers tune would I need to send you my ECM, or could I just email you my tune and have you tweak it. I have access to HP Tuners to flash the ECM. I also have my stock and upgraded tune saved to my computer. Or could I just add your enhancements on top of my Westers tune? How would this work?
How difficult is the entire install. I know how to turn a wrench and have done most of the mods to my car myself in my driveway. Assuming average skill and speed how long should it take to install in a driveway? What, if any, special equipment is required for the install?
Do you have any pics of the whole thing laid out? It would help me understand exactly what is included.
Does the turbine speed datalogger come with a gauge (I assume not) or is it more used with data acquisition electronics for testing purposes?
AWESOME work and thank you for being a guinea pig in an effort to make our cars faster than they should be!
Team Solo Performance
Team Solstice 2008
Pioneer Avic D3 - Sirius, iPod, Bluetooth, and backup camera
Debadged rear lettering
K&N Air Filter
OZ Ultraleggera Wheels
Morfious is offline
Old 06-16-2008, 05:39 AM
It wont pass the visual if the guy really really goes poking around. I did my very best to make it stock appearing and to make it really hard to tell there is no cat. Down the road if it becomes a problem the highflow cat will become a priority and as I said be made availible to kit owners on the cheap.
I can tweak your existing westers tune, or show you how to use the compare file function to make the changes . Really only changes to the MAF tranfer, ignition, and cam tables are nessicary.
Hptuners makes a list of whats different, you go thru the tables, set to compare file and put all things to Zero (as in zero difference to the one your comparing it to)
No special equipment, it's a 2-4 hour job your first time. hand tools only, jackstands.
Go back to stock in the same time or less.
Yes, I 'll take even more today.
It most certainly does, for your money you get the delux kitTurboByGarrett.com - Accessories
It's the second pic down. You get everything needed, I CNC machine the compressor housing for the sensor.
The guage will fit nicely in one of the AC vents.
Thanks bud! It's great to feel appreciated!
Old 06-17-2008, 04:57 PM
I posted up the pics in the group buy thread. I took a video as well but the wind noise & shoddy camera work make it unworthy. But you can at least see it roll up on 23psi by 3200rpm in 4th from a cruise.
Old 06-17-2008, 04:58 PM
Old 06-19-2008, 11:19 AM
IBDRINKEN's Avatar
I currently have the solo race exchaust 3 inch with the hi flow/fujita intake and ic pipes. Will any of those work with this kit
TEAM FREAKY CIRCUS S**
2.5" Stubby Black Antenna
Lil' Chromies
Norms Fenders
Kappa Intake
Kappa IC Pipes
IBDRINKEN is offline
Old 06-19-2008, 07:48 PM
Race exhaust will bolt right up as will your intercooler pipes.
the fujita gets resold. the intake for the Gt30 is HUGE.
Old 06-26-2008, 06:55 AM
Finally HPTuners has looked our way. Perhaps in the next few weeks we'll be able to turn up the rpm and set it on kill finally.
Then we'll see the difference between stock exhaust and NONE. Via dynographs.
As it is right now, you can stay below 19ish psi and it won't give you any trouble with reduced power mode.
I'm looking into what will be required for stage 2, (there will be upgrade paths from each of my products) now that the ball has possibly begun to roll at HPT.
It will be the same kit +GT3582R, headstuds, valvesprings and retainers.
Possibly a balance shaft delete, I'm not sure.
It will look almost identical to a stage 1, but should be able to make 500whp or more and be a very angry little beastie indeed between 4000-8000RPM. I dont know about you but I just cant wait to see the needle make it's way around ALL of the tach! lol
Id be willing to wager that number comes on pump gas+meth.
Old 06-28-2008, 06:32 AM
I posted up some vids of 4th gear from 1800ish Rpm to 4K on the thread in my vendor section.
They aren't the best quality, but it shows the threshold and boost charicterisitics on my setup +all stock everything else.
Old 06-28-2008, 03:27 PM
mena661's Avatar
Not feeling the 3" exhaust yet?
mena661 is offline
Old 06-28-2008, 07:45 PM
getting there. More concerned with other goodies at the moment. I just dont want loud at all. I like how it sounds, just need another half inch or more.
Old 06-30-2008, 08:08 AM
Beau's Avatar
BTF, can you get a current dyno for us? I'd like to be able to see exactly how well its pulling up to the stock RL, then interpolate the data myself.
Beau is offline
Old 06-30-2008, 08:19 AM
Yes. I can even do it New Era on his dynojet to make it more apples/apples. IF and thats a big freakin if,hpt gets us a beta within the next week or two as promised it will be alot more impressive.
I havent installed a westers torque delete/rev control so im still shutting down at 6300 and will go limp running my current boost(22psi,spring alone) over 4 sec. So it will require me to do the run in a gear that keeps it under that time frame.
Old 06-30-2008, 09:19 AM
Beau's Avatar
See what you can get, I'd love to see this.
Beau is offline
