Old 03-11-2010, 06:07 AM   #1 (permalink)
Topcat's Avatar
Location: Extreme North Western PA Waterford (Erie), PA
Check Engine Light came on, why?
My check engine light came on, Why?
Do I need to take it to the dealer to see why?
What are some possible causes for that light to come on?
Thanks
Topcat
07 Aggressive GXP
Solo Hi-Flo Cat, Street Race Exhaust
Dejon Intercooler, Piping & Coupler Kit
Wester's HOT Tune
NASSOA Founding Member
Song of the Week: UNDER CONSTRUCTION
Movie Quote of the Week: Under Construction
Topcat is offline   Reply With Quote
Old 03-11-2010, 06:20 AM   #2 (permalink)
Caulairdis's Avatar
Most car parts stores have a code reader you can borrow. As to why- it could be any number of reasons- the first time the light came on for me, it was because the attendant at the gas station didn't close the gas cap right. Once you get the code, do a search on here- you'll usually find something.
I was not tested for normalcy before I was entrusted with this mission
2006 Solstice, Agressive Red
Caulairdis is offline   Reply With Quote
Old 03-11-2010, 06:21 AM   #3 (permalink)
druid-2's Avatar
Location: buzzard..what buzzard..do you see a buzzard..I didn't see a buzzard...or that little sparrow either- or dat squirrel
do you have an aftermarket exhaust system on the car?
You need to find out what code it is throwing before we can go any further
NEOKAPPA's
Some people grow old before their time...I choose to die before I grow old !
Druid (Cool) MERLIN came home 11-15-05 VIN 4495
Clear bra, Stubby antenna, Kappshield, mudguards, Chrome wheels with DZ 101's...CAI..SOLO SQR-2 exhaust with free flow CAT & SS header DDM Racing backbone ..painted calipers and wheel centre decals. 25% tint windshield ... Vertical Chrome billet grille .. stay tuned
druid-2 is online now   Reply With Quote
Old 03-11-2010, 06:22 AM   #4 (permalink)
snaponbob's Avatar
Could be ANYTHING !! If you have Onstar, they can "sweep" the ECM and give you some idea what is wrong. Also, many chain parts stores will allow you to use their scan tool (in the parking lot) to determine what code is present. HUGE majority of codes these days are about a loose fuel cap. Really -- check yours. BTW, what mods/changes have you made lately?
Take a look at this site - scroll down a bit to see the listing. OBD-II Check Engine Light Trouble Codes
Depending on the mileage of the car, and what the code is, the issue may be covered by warranty.
Old 03-11-2010, 06:35 AM   #5 (permalink)
If the CEL is on steady then its a fault but not a "fix it immediately" fault. As others have said, it could be any of many things. I got a code on the wife's Sky when I did not get the gas cap seated properly. Since the fuel tank needs to be sealed to atmosphere to work correctly, if the cap is not fully seated you get a CEL. But once you reset the cap, the CEL will go away after a couple of key cycles.
If the CEL is flashing or you go into limp mode or some other strangeness in operation then you need to get it checked ASAP
Tread Head (DAT)
"They call 'em crunchies because that is the noise they make when you run over 'em"
Qualified in M-48A5, M-60A1
Electrical Engineer
Suramar DK Oberstkurtz, DPS Colonelkurtz, DPS Majorkurtz
NASSOA and GMR member
Old 03-11-2010, 03:15 PM   #6 (permalink)
Topcat's Avatar
P2237. Unknown.
07 Aggressive GXP
Wester's HOT Tune
Old 03-11-2010, 03:25 PM   #7 (permalink)
lil goat's Avatar
P2237 Oxygen Sensor Pumping Current
Circuit/open (for A/f Sensor)(bank 1
Sensor 1)
Team Photographer ASD Falken Tire Drift Team
Solo Mach and No Cat
Wester's Garage tune
RMR Style Bar.
DDM Works PINK Breastplate
HKS Coilovers
Eclipse AVN726e; ZED Audio Leviathan, Image Dynamics components, active crossover tri-amped.
MB-Quart 10" sub
Old 03-11-2010, 05:07 PM   #8 (permalink)
snaponbob's Avatar
Switch the O2 sensors, clear the codes, and see what happens.
Old 03-13-2010, 12:59 PM   #9 (permalink)
Topcat's Avatar
Car runs fine, car sat for winter. I fired it up last weekend, drove it with no issues. was driving it home thursday night and I got the orange check engine light. check the code with my dashhawk.
i should be able to clear the code with my dashhawk correct?
I took the gas cap off and put it back on.
just not sure what to do first. car seems to run fine
07 Aggressive GXP
Wester's HOT Tune
Old 03-13-2010, 02:37 PM   #10 (permalink)
Senatorius's Avatar
Sorry to highjack your thread.
I had the Check engine light come on on my 2008 Base Automatic.
I have installed a SOLO high flow cat and Magna Flow dual exhaust.
I called it in on ONSTAR and the lady told me it was an exhaust warning.
She told me to take it on the highway for an hour and see if that would clear the check engine light.
She also told me that if the car lost some power to take it in for a check up ASAP.
Well, i took it out for an hour and the light is still on and no loss of power.
Does anyone have any idea?Thanks
2008 Pure White Solstice, Modded dash and accents,
Fujita Dual Cold Air Intake, Modded Windscreen.
RK Sport Body kit and Ram air hood
White and red Leather seat covers
SOLO High Flow cat, Magna Flow Dual Exhaust
Senatorius is offline   Reply With Quote
Old 03-13-2010, 08:04 PM   #11 (permalink)
druid-2's Avatar
you have an N/A version with a SOLO exhaust and a factory-installed
and calibrated ECM
either get a new ECM and have it re-flashed or ignore the light
I had Solo check out my system and it is working fine
it's just not working to the pre-assigned GM levels built into your ECM
NEOKAPPA's
Old 03-13-2010, 08:32 PM   #12 (permalink)
Senatorius's Avatar
and calibrated ECM
Thanks for the info Druid-2
So basically ignore it until i get my supercharger and then DDM will set up the ECM right?
