LinkBack (6) Thread Tools Display Modes
Old 02-01-2008, 11:51 PM   #31 (permalink)
Can't wait until the stupid computer gets cracked and bigger turbo kits are available.
2007 Aggressive GXP "Natsumi"
GMPP Tune, GMPP Intake, Solo Mach Shorty, Solo High-flow cat, SSR Type-C RS Wheels, DDM Backbone.
Lithium Lotus is offline   Reply With Quote
Old 02-02-2008, 09:56 AM   #32 (permalink)
DEJON-Dave's Avatar
How big do you want/
I already offer the Mitsu 16g and will be offering Garrett kits this weekend. I showed a pic of the GT3076kit installed earlier on this thread.
Founding Member #6
DEJON-Dave is offline   Reply With Quote
Old 02-02-2008, 12:26 PM   #33 (permalink)
DEJON-Dave's Avatar
Garrett Turbo kits
I just uploaded the Garrett Turbo kits and parts to our website on the "Turbos" page
Founding Member #6
Old 02-02-2008, 12:44 PM   #34 (permalink)
Wow, that's fast. 16g is big enough for me. I'm just waiting until the computer gets fully cracked before diving into something as big as a turbo swap.
Old 02-02-2008, 01:22 PM   #35 (permalink)
carlintexas's Avatar
Since you're going from one turbo to another - is it possible that the ECM will 'adapt' to the new unit flow? Or is a re-flash required?
TEAM SOLSTICE 2008
NASSOA(tm)
Founding Member #2
1st 1K #781
310whp DDM Custom Turbo System
Riken Raptor's 255/45/18
carlintexas is offline   Reply With Quote
Old 02-02-2008, 06:57 PM   #36 (permalink)
mena661's Avatar
Reflash is required, custom tune is better, and no it won't "adapt".
Old 02-02-2008, 10:25 PM   #37 (permalink)
Worked fine for me... runs fine without reflashing so long as you dont change the MAF tube.
Mine is a force feed requiring a rescaled MAF. All else was bone stock.
But to up the boost enough to take rael advantage of the turbo your buying you'll have to do alittle tuning.
Old 02-02-2008, 11:42 PM   #38 (permalink)
shabby's Avatar
The beauty of an ecm with a stock wideband, it just pumps more fuel to keep the afr the same.
Old 02-03-2008, 12:26 AM   #39 (permalink)
I just want to play it on the safe side for now
Old 02-03-2008, 07:38 AM   #40 (permalink)
Hey now the Maf deserves a little credit, too!
Old 02-03-2008, 09:54 PM   #41 (permalink)
Youy might not want it the same?
Jack B is offline   Reply With Quote
Old 02-03-2008, 10:14 PM   #42 (permalink)
shabby's Avatar
I guess, but for the time being its good that it does. Hopefully with hptuners we'll be able to change this later down the road.
Old 02-03-2008, 10:22 PM   #43 (permalink)
You can change it now with the PE table.
Old 02-04-2008, 06:08 AM   #44 (permalink)
shabby's Avatar
Ah i thought that was slightly differrent than commanded afr, just some extra fueling for wot.
Old 02-04-2008, 06:16 AM   #45 (permalink)
GhostRL's Avatar
Send a message via AIM to GhostRL
PE is basically the table the car uses over the PE threshold which is around 85% throttle and above a certain RPM. The rpm threshold is adjustable. You can basically set the car to add more base fuel and it will adjust to hold the parameters you define.
Dave - I'm excited about the 50 and 57 trim, have you tested the fuel systems capability with the 57 trim? KB boost a pump necessary, any input?
2007 Sky Redline FOR SALE
Dejon Turbo + HPTuned
http://www.solsticeforum.com/forum/f...79/#post885290
GhostRL is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.solsticeforum.com/forum/f63/dejon-mitsu-16g-turbo-install-41900/
Posted By For Type Date
400 Hp - Saturn Sky Forum This thread Refback 01-28-2008 05:22 PM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-26-2008 10:35 PM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-26-2008 08:51 AM
Turbo Kit Available for Redline - Saturn Sky Forum This thread Pingback 01-25-2008 11:28 PM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-25-2008 12:43 AM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-24-2008 11:55 AM
