LinkBack (6) Thread Tools Display Modes
Old 02-04-2008, 11:21 AM   #46 (permalink)
turboman808's Avatar
Send a message via AIM to turboman808
Man once I can slap this on a plug something into the computer to run it right I am so down for this! Hmmm Road trip to Ohio could be fun LOL
Oh I see ya got the ball bearing turbo as well. Sweet. I may just have to do this on a few months once things settle down and around here.
I love the life but I never sold my soul...
turboman808 is offline   Reply With Quote
Old 02-04-2008, 03:32 PM   #47 (permalink)
DEJON-Dave's Avatar
Originally Posted by GhostRL View Post
PE is basically the table the car uses over the PE threshold which is around 85% throttle and above a certain RPM. The rpm threshold is adjustable. You can basically set the car to add more base fuel and it will adjust to hold the parameters you define.
Dave - I'm excited about the 50 and 57 trim, have you tested the fuel systems capability with the 57 trim? KB boost a pump necessary, any input?
We calculated 474hp fuel capacity at 80% I'd recommend a pump voltage increasing device with the 57trim turbo.
Founding Member #6
DEJON-Dave is offline   Reply With Quote
Old 02-04-2008, 03:35 PM   #48 (permalink)
DEJON-Dave's Avatar
High-Flow Cat
Solo emailed that the downpipe prototype is finished and will ship to me as soon as they take it across the border.
Founding Member #6
Old 02-05-2008, 07:55 AM   #49 (permalink)
bradyb's Avatar
So what would our bolt on horsepower increase be with the turbo upgrade?
Mod#1 blacked-out headlights
Mod#3 Special Sauce (23PSI)
Mod#4 Solo Street Race
'07 Charger R/T Mama's car
bradyb is offline   Reply With Quote
Old 02-05-2008, 02:02 PM   #50 (permalink)
DEJON-Dave's Avatar
If you also have supporting parts to handle 45% increase in airflow, software to lower AFR, and boost control to get 23psi to redline, 375hp at 23psi and 6300rpm. Saturday, I ran 394hp at 25psi boost but got some erratic 02's I think due to the 4" Magnaflow Cat I'm using. I should be able to go higher when I get the SOLO 5" cat downpipe.
Founding Member #6
Old 02-05-2008, 03:12 PM   #51 (permalink)
Is that crank or rear-wheel horsepower?
2007 Aggressive GXP "Natsumi"
GMPP Tune, GMPP Intake, Solo Mach Shorty, Solo High-flow cat, SSR Type-C RS Wheels, DDM Backbone.
Lithium Lotus is offline   Reply With Quote
Old 02-05-2008, 03:33 PM   #52 (permalink)
Based on his spec.s that would be crank hp.
Your butt dyno would have to be dead to not feel this.
It WAS Cool, Leather, XM, Monsoon and different! :)
b_faster is offline   Reply With Quote
Old 02-05-2008, 10:44 PM   #53 (permalink)
Originally Posted by shabby View Post
Ah i thought that was slightly differrent than commanded afr, just some extra fueling for wot.
Shabby:
the PE value becomes the commanded a/f at wot. It actually starts working at lower thresholds if you chose to change those values.
Jack B is offline   Reply With Quote
Old 02-06-2008, 07:32 AM   #54 (permalink)
Im starting to believe that it's more. The BSFC on this engine is very low.
Ive seen as much as 48lbs/min thru the motor and w/ 51% max dutycycle on the log.
When the weather breaks pack up some goodies and drive that thing up here. We'll have a good ol' test and tune on my dyno. your only about 4hrs from me. My buddy Brian makes it here from cleveland in about 5.5.
Old 02-06-2008, 01:09 PM   #55 (permalink)
DEJON-Dave's Avatar
It's based on airflow thru the engine, not a dyno wheel
Founding Member #6
Old 02-06-2008, 05:12 PM   #56 (permalink)
shabby's Avatar
Either hptuners isnt reading the duty cycle correctly or gm gave us 1000hp injectors
These can be relatively small injectors but running them at 2000psi increase fuel flow dramatically.
Old 02-06-2008, 07:26 PM   #57 (permalink)
DEJON-Dave's Avatar
I guess we'll find out in time, I've seen Injector pulse widths over 10 in some conditions when my 02's went Wako due to (I think) the 4" magnaflow cat.
I've had no clutch problems yet, I wonder what it's capable of?
When we get full tuning capability this car will be awesome.
Founding Member #6
Old 02-06-2008, 08:52 PM   #58 (permalink)
Ive got a log with 52lb/min and 51%duty, unknown kpa 11.7msec PW.
Old 02-06-2008, 10:46 PM   #59 (permalink)
BTF:
four hours in a jet!
Old 02-07-2008, 09:01 AM   #60 (permalink)
For some reason I thought Ol' double D was in NE ohio instead of NW.
Oh well. Springtime!
Once the wife and I decide on a house and move I'll be putting up a huge pole barn for the DYNO /machine shop. Then all my crap will be under one roof and we can start planning:
The "1st annual Killer Kappa party cruise & Dyno bonanza"
The Dragstrip is about 30min from where were looking to buy, and the specific property is over 40 acres in the country. Lots of Kappa's and Tents will fit on 40acres....
LinkBacks (?)
LinkBack to this Thread: http://www.solsticeforum.com/forum/f63/dejon-mitsu-16g-turbo-install-41900/
Posted By For Type Date
400 Hp - Saturn Sky Forum This thread Refback 01-28-2008 05:22 PM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-26-2008 10:35 PM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-26-2008 08:51 AM
Turbo Kit Available for Redline - Saturn Sky Forum This thread Pingback 01-25-2008 11:28 PM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-25-2008 12:43 AM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-24-2008 11:55 AM
