LinkBack (6) Thread Tools Display Modes
Old 02-07-2008, 10:29 AM   #61 (permalink)
Originally Posted by BaldTurboFreak View Post
The Dragstrip is about 30min from where were looking to buy, and the specific property is over 40 acres in the country. Lots of Kappa's and Tents will fit on 40acres....
Enough room for a little roundy round in the grass.
It WAS Cool, Leather, XM, Monsoon and different! :)
b_faster is offline   Reply With Quote
Old 02-07-2008, 11:06 AM   #62 (permalink)
Hee hee when you see the topography I think you'll wanna rock the slazer.
we like this place alot,adds 20min to the wife's commute though.
Whaddaya think perfect place for a Kappa chassis hoe-down?
Old 02-07-2008, 11:29 AM   #63 (permalink)
carlintexas's Avatar
Where does the deer feeder and stand go?
TEAM SOLSTICE 2008
NASSOA(tm)
Founding Member #2
1st 1K #781
310whp DDM Custom Turbo System
Riken Raptor's 255/45/18
carlintexas is offline   Reply With Quote
Old 02-07-2008, 11:45 AM   #64 (permalink)
He he right next to the pond, and I'd say bedroom window....
Old 02-09-2008, 02:31 PM   #65 (permalink)
so what would you use for tuning/boost control on the 3076 kit besides the IAT2, boost controller, map regulator, and a cel reader? it doesn't seem like it would be safe to just run these and nothing else in terms of electronics/tuning. if i were to purchase the 3076 kit, i would want a custom tune; there's still no way to do this with the current available tuning options right?
-Chris
skyline is offline   Reply With Quote
Old 02-09-2008, 06:52 PM   #66 (permalink)
No CHris,
I not totally pos about the differences in my turbo to dave's turbo but you most certainly can run the stock tune & boost without hurting the motor.
But if you go looking at my dynographs (and dave will have some this spring) you'll see that the power gain isnt worth the hit down low until you start rockin' boost. then the top end power curve fills in.
Buy HPtuner pro right now if your even considering hotrodding your car. It will be a lot to learn at first but once you learn how to "drive" the software. Pro's like Dave and myself can hand you a tune over the 'net that works well on a similar combo. Then just scan & drive watch for KR and keep the Ltft's negative.
Old 02-11-2008, 06:19 PM   #67 (permalink)
AdamVIP's Avatar
-Chris
Not to be a downer on the party but this man speaks what many are thinking. These turbo swaps sound awesome until you realize that we are still hugely hindered by the ECU.
Victoria
2007 GXP Manual.
AdamVIP is offline   Reply With Quote
Old 02-11-2008, 06:33 PM   #68 (permalink)
Actually Adam, I wouldnt call it hugely hindered.
Thanks to Bfaster/Lil goat we have a PSi for Psi comparison. A big turbo was worth up to 90ft/lbs at the wheels with the stock boost and mostly the stock tune.
Esp if your considering Dave's middle of the road turbo, id buy it rock it and be happy. I promise you'll stomp a mudhole in your buddy's stock turbo GXP.
Look at HPT as somethign to look forward to or a free "stage" whence the rest of RPM/desired boost target has been unlocked.
Like I said anyone who is modifying their car should own their own copy of HPT pro. It's a prerequisite to modern hotrodding. period.
Old 02-19-2008, 09:59 PM   #69 (permalink)
DEJON-Dave's Avatar
Update
I've finally got a solo 5" hi-flow cat on the car, but the weather is lousy. I had a 4" magnaflow installed and had problems of erratic O2 readings and fuel delivery at 24psi, 3300-3600 rpm, just after the turbo spooled up. I'm guessing it was due to the magnaflow cat, since I never saw it with a catless downpipe. I'm anxious to see if the solo solves it.
Founding Member #6
DEJON-Dave is offline   Reply With Quote
Old 02-26-2008, 01:19 PM   #70 (permalink)
all this increase in power with which ecu tuning is accomplice??
Iceman is offline   Reply With Quote
Old 02-26-2008, 03:17 PM   #71 (permalink)
MMMm HP Tuners it is. (in best Yoda voice). Posted Tune dave will give you.
Old 02-26-2008, 05:31 PM   #72 (permalink)
And the tuning is in the price that dave give or extra??
Old 02-26-2008, 06:51 PM   #73 (permalink)
DEJON-Dave's Avatar
Yes, I'll give my latest tune to you free, with the Turbo kit. You'll need HP Tuners software or go to someone who can download it to your car. Remember that this is not a custom dyno tune like Wester's sells, rather what I run on my car based on many actual drive runs. I'm giving it away because it makes running my turbo upgrade safer and the car run better so you're satisfied with my products.
Founding Member #6
LinkBacks (?)
LinkBack to this Thread: http://www.solsticeforum.com/forum/f63/dejon-mitsu-16g-turbo-install-41900/
Posted By For Type Date
400 Hp - Saturn Sky Forum This thread Refback 01-28-2008 05:22 PM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-26-2008 10:35 PM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-26-2008 08:51 AM
Turbo Kit Available for Redline - Saturn Sky Forum This thread Pingback 01-25-2008 11:28 PM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-25-2008 12:43 AM
Turbo guys check this out... - Cobalt SS Network This thread Refback 01-24-2008 11:55 AM
