Yeah that Y looks cleaner than the T. We should paint htem flat black then it will be a stealth.
If you dont have a cap to plug the solenoid, use a screw and a piece of hose to make a plug. That what i was going to use initialy but then i dropped it in the engine bay somewhere and managed to find a kit with vacuum caps.
This mod i would say would be equivilant to a $200-$300 performance gain.
Some of you have been asking how you hook up the bov and do the EDAL mod at the same time, well here is a good picture of it. YOu can see two Tees in this pic.
As far as I understand it, the ECU reduces boost when additional mods are installed, in order keep the vehicle on the programmed torque lines.
Does this mod keep that from happening?
If so, I would guess that the ECU would then lean the AF mixture to achieve the same goal.
Would the ECU be "dumb" enough to lean the mixture to the point of potential engine damage, just to limit power?
the ecu does several things when it hits limp mode. Closes throttle and sets timing advance to 0. This pretty much kills any boost/power one is making. a/f staying around 12.5-13 with aftermarket boost controller so the system has the fuel to throw at the higher boost levels, just that it doesn't play fair. :/
gotcha, that makes sense.
So HP increasing mods aren't going to hurt the car...your just not going to see the benefit due to the Nazi ECU killing boost/throttle/timing
Well, I'll be first in line for a tune as soon as someone comes out with it...well...maybe 3rd, behind MTS and ED
I just did this. took me 5 min to do. there is more boost at a lower RPM for sure. i just installed my CAI toady so i'm still loving the new sound and feeling of that. But this mod is for sure worth it.. 5 min and $5 to do.. sweet...
__________________ -----------------------------------
2007 Mean Yellow GXP
- 5 Speed
- DEJON Yellow Hard Velocity Stack Intake Pipe
- AEM Filter
- Anti-Lag Mod (Charge Air Bypass Mod)
- Silverstar Lights
- GENK31 NVS Mirror With Compass, Outside Temperature And Map Lights
- Custom Badge Overlays (yellow)
- GXP Side Emblems
- Dash Accent
- Door Accents
- Painted Engine Cover
- STUBBY Antenna
- Kappa pouch "with power seat"
$8 for me at PepBoys, but I bought extras in case I screwed it up. 15 minutes under the hood, since I literally have never done work on a car before (not even an oil change).
Was quick and easy - very detailed description. Had a hard time getting hose #1 in the diagram above off of its male counterpart, but a good bit of force eventually removed it.
Most noticeable to me was how much more quickly boost was gained once the turbo was engaged...1 PSI...3PSI...18 PSI. Also, I feel as though I noticed that the BOV and turbo itself were both making more noise during acceleration - but maybe that's just because I was paying extra careful attention.
Strongly recommend this to anyone that owns a pair of pliers and a pair of scissors.
ummmmm.....isn't the turbo ALWAYS engaged? it just lets the boost out when you aren't accelerating. when you put your foot down it closes the door to trap the air in and that's when boost climbs. correct me if i'm wrong.
08 Mean GXP
- Magnaflow Exhaust
- Dejon CAI
- O Stubby Antenna
- LightInSight
I installed this mod twice...Don't like it!!!!
1) Kills the great sounds of the blow off valve between shifts.
2) Can allow a surg in power if you punch it in a small area causing un-intended acceration.
3) From my testing could see no value add.
Just my opinion, and opinions are like a$$holes, everone has one!
DD
Future so bright I have to wear shades!!!
Mean GXP (VIN 117835 11/06 )
Name: Growler (Vin #4878) Traded for Mean GXP 3/19/07
Mean, dark side, ebony leather w/red stiching, LSD, ABS, AC, Monsoon 6CD changer, mats , headliner, stability control, XM, power pkg., convenience pkg., chrome wheels, sport peddles, Fiam Air Horns, Magnaflow, De-badged, shortened waste gate rod mod.
Garage Mates: 2005 Yamaha FJR1300, 2003 Yukon w/K&N CAI, 2003 Honda CRV
I originally performed the mod but didn't really like how it changes the driving. I have it back to normal now and like it much better. I know a few that did the same.
