LinkBack (5) Thread Tools Display Modes
Old 11-26-2007, 01:59 PM   #61 (permalink)
OK now it's a contest, I am guessing 340rwhp and the winner gets an old truck lug nut.
Let's get SLIDEWAYS!
Solo Mach and No Cat
JPM custom shifter.
Barney Juice XPR 21
RMR Style Bar.
DDM Works PINK Breastplate
HKS Coilovers
Old 11-26-2007, 03:03 PM   #62 (permalink)
The ol' Gt3076R wont run outta breath until 525hp. I wonder how many psi it will take to Jam 50 lbs/min thru there?
Iguess I should build another intercooler while I'm at it. Although I guess it would be cool (and funny) to see what the stocker can do. P1/P2 ought to be hilarious.
Like I said I really really like Liquid cores being a street/strip kinda feller. I have used the A/c system on a few different cars for the Heat exchanger and it's VERY effective.
I'll sweeten the pot, your old truck lugnut + an exploded saturn trans (FWD, dont get scared now lol)
Old 11-26-2007, 03:47 PM   #63 (permalink)
Beau's Avatar
Ok before I put my official WHP estimate down lets define the parameters.
What kind of exhaust are we talking?
Intake setup?
Lets also estimate for max power under 1 degree of KR on 93 pump.
So Stock intercooler eh? ( arg ) Dude seriously I wouldnt. I mean at first is fine, but if you wanted another 40 whp upgrade, new intercooler plus tuning will = nice gains.
You tell me what the exact setup will be, and I'll guess within 8 whp.
Then what do I get :}
Beau is offline   Reply With Quote
Old 11-27-2007, 01:42 AM   #64 (permalink)
XplosivePlushToy's Avatar
I say it'll be a minimum of 300whp.
That's broad enough to guarantee me a win...
I support our Supporting Vendors, one paycheck at a time!
My CarDomain!
My Mods@The Mod Thread
XplosivePlushToy is offline   Reply With Quote
Old 11-27-2007, 01:03 PM   #65 (permalink)
1st test will be
1)pumpgas
2)stock exhaust
3)stock intercooler
4) shooting for 18psi (and if the F'er dont gimme it I have a Eboost2)
only mods will be the GT3076R and accompanying BOV/Gate.
tuned by HPtuners on a Land-and-Sea dyno. For comparison's sake it's pretty similar to a mustang dyno or 12-15% lower then a dynojet.
Winner gets gargemel's old lugnut, a blownup saturn trans and oh hell why not a carbon/Kevlar engine cover in your choice of color.
Closest without going over wins! Bob Barker'd be proud!
Old 11-27-2007, 01:20 PM   #66 (permalink)
Randy@ddmworks's Avatar
My bet is limp mode....301 whp
www.DDMWorks.com
Randy@ddmworks is offline   Reply With Quote
Old 11-27-2007, 01:30 PM   #67 (permalink)
Yep got limp mode with everythign Ive tried on this thing,Randy.
Some dataloggin,some reflash and 5 min later no more limp mode.
I have the factory sensor stuck in a 4" pipe. no limpmode. It's all relative.
What I havent been able to do is stuff double the lbs/min thru the motor with this little peeshooter. But it will give me some nice data and insight into what measures the PCM will take against it. Perhaps it may help the boys @hpt.
So lets put limpmode out of our head, if it gets really pissed at me over the HIgh psi I will reduce boost until it's happy. Im most interested to see if she tries to shut the Throttle down on me.
I have a feeling it wont though. It only reduces boost on me when I have deviations from CMD to actual A/F. It only reduces throttle angle at redline and if it goes over 22psi. I think if I can maintain A/F and keep it below 20 psi she's just gonna sing her little heart out for me.
Old 11-27-2007, 03:59 PM   #68 (permalink)
I have no doubts about the turbo's ability, I just wonder how you will overcome the ECM NAZI, that sucker is mean and does not take well to being messed with. I know the stock turbo will spike to 300 rwhp, but almost instantly goes limp. I think if anything I maybe high with the 340, if HPT comes out with an update soon I will change my number.
JPM custom shifter.
Barney Juice XPR 21
RMR Style Bar.
HKS Coilovers
Old 11-27-2007, 05:18 PM   #69 (permalink)
Indeed,
well I do speak half-ass German,lol.
well I havent run into an obstacle yet with the Ecm that hasnt beenable to be programmed around. But it hasnt gone this far out of parameter either.It should prove interesting nonetheless.
Old 11-27-2007, 10:55 PM   #70 (permalink)
330whp is my guess. We should have a secondary contest: How much hp before engine failure?
2007 Aggressive GXP "Natsumi"
GMPP Tune, GMPP Intake, Solo Mach Shorty, Solo High-flow cat, SSR Type-C RS Wheels, DDM Backbone.
Lithium Lotus is online now   Reply With Quote
Old 11-28-2007, 08:15 AM   #71 (permalink)
my guess would be that the liners fail around 600hp. give or take. Sine Im chasing the power up the Rpm band the net cyl pressure goes down to make the same Hp @ a higher RPM. Just more frequent bangs.
It will be interesting to see if the piston crown or ringlang gives way before the Cyl wall does.
Old 11-28-2007, 10:10 AM   #72 (permalink)
I was wondering more about how much fuel can the stock injectors support before the engine leans out.
Old 11-28-2007, 10:43 AM   #73 (permalink)
Well I know for a fact that the injection cycle still occurs during the intake stroke NOT the compression stroke during PE mode (as Per a Bosch whitepaper) so duty cycle is calculated as it is in any other car. That being said, Ive only logged a max of 29% duty cycle.
Mind you now, as RPM's increase the injection window narrows so Duty cycle goes up by default even @ the same PW.
The primary/secondary pump should be able to support 400whp. That is my opinion based on the datamining done thus far.
Old 11-28-2007, 10:47 AM   #74 (permalink)
cyl wall will definately let loose first. open deck design = split block, lets just say i know first hand. the pistons looked fine other than where they got wedged in the bore when it split.
i'd like to think 400 hp would be possible with an intercooler, exh, tune and turbo upgrade but i dunno with the stock stuff
greaseyjockey is offline   Reply With Quote
Old 11-28-2007, 10:52 AM   #75 (permalink)
just like a f'n honda. Ive had them split top to bottom on my dyno. But that was detonation (Someone gave the Dizzy a turn,advancing the timing about 20deg) Open deck sux, too hard to keep the bores from walking unless you recess them into the Head deck.
Was it a first or second gen eco?
LinkBacks (?)
LinkBack to this Thread: http://www.solsticeforum.com/forum/f63/gt30r-wg-going-saturday-morning-39654/
Posted By For Type Date
Turbo para Opel GT 264cv - Forocepos This thread Refback 02-15-2008 06:52 AM
Turbo para Opel GT 264cv - Forocepos This thread Refback 02-15-2008 06:48 AM
400 Hp - Saturn Sky Forum This thread Pingback 01-28-2008 04:38 PM
Bigger Turbo? - Saturn Sky Forum This thread Refback 01-22-2008 08:03 PM
Bigger Turbo? - Saturn Sky Forum This thread Refback 01-15-2008 09:30 AM
