On a stock car, the improvement is immediate. If you have added a lot of power or torque adding mods, the ECM has learned down to 260 ft pounds. It can take a few key cycles to learn back up. It appears that if you do a reboot of the ECM, by pulling the power for a few minutes, the ECM will reset to the data tables and loose the learn down data it had contained.
Tread Head (DAT)
"They call 'em crunchies because that is the noise they make when you run over 'em"
Qualified in M-48A5, M-60A1
Electrical Engineer
Suramar DK Oberstkurtz, DPS Colonelkurtz, DPS Majorkurtz
NASSOA and GMR member
