Originally Posted by
carlintexas
BTF - your opinion please -
If the 2.0 is good for 500whp without internals......
What do you think our 2.4 can safely handle?
Carl, the 2.4 is a different animal.
1) crank is longer stroke,not forged steel will it break?-not at 500hp but the bending moment will be higher
2)Rods are ALOT wimpier the GM book describes a compression based fracture in the middle of th rod beam when they hit around 350hp. But that was nitrous and the jug is really tough on parts due to sharpness of the pressure rise.
3)Piston crowns arent designed for sustained high heat. PArt of why the LNF/LSJ pistons are so damn heavy is the powertrain engineers needed a little thermal mass to control crown temps during sustained asswhoopin'. Also the increased stroke/decreased rod ratio puts more skirtload on the piston.
So it comes down to duty cycle really. 300-325whp prolly max, but not everyday! drive with some respect for the parts and it will last long enough for you to want to build a highboost motor.
Then just buy a LNF crank,h-beam rods and forged pistons (hell I 'll build you the shortblock if needs be) stick it under your head and let her have it! the stock sleeves survived to 600hp in GM's torture cell.
Whats really really awesome and people arent taking enough advantage of it is that there is a complete guide and parts availibility to build a KILLER ecotec. GM made good on their promise to make the SBC of the Sport compact world. you can piece together a MONSTER right from your GMPP catalog. Lots of other engine families cant brag about that. Factory hotrod/racing parts.
