Old 06-17-2008, 11:36 PM   #1 (permalink)
AdamVIP's Avatar
INtercooler romoval troubles.
OK ive been fussing around with trying to get this intercooler off for about 30 min. I cant seem to get it to slip out of the hoses. I have clamps very loose so I know its noot that. My instructions say to just wiggle it out but that doesnt seem to work. Its moved about 1/4" from where it was before I started but it doesnt want to move anymore.
Should I just WD the crap out of it or is there a trick?
Oh and Im loosing it on the top non-intercooler side. The other clamps were too buried to get with a driver.
Victoria
2007 GXP Manual.
AdamVIP is offline   Reply With Quote
Old 06-18-2008, 12:01 AM   #2 (permalink)
AdamVIP's Avatar
OK Update. I got the bottom clamps loose too now. Still cant get either part out. Im gonna sleep on it now though cause im starting to get frustrated and dont wanna break anything.
Victoria
2007 GXP Manual.
Old 06-18-2008, 03:33 AM   #3 (permalink)
anorth45503's Avatar
if getting the hoses off is the problem. here is a good vid
Solstive GXP intercooler pipe install Porsche TV - Brightcove
hope it helps
anorth45503 is offline   Reply With Quote
Old 06-18-2008, 06:16 AM   #4 (permalink)
Deepbluegxp's Avatar
shove a straight slot screw driver in between the hose and IC, that will break the seal of the hose and allow for removal.
See my car on cardomain.com
NASSOA Founding Member #48
Old 06-18-2008, 06:32 AM   #5 (permalink)
LOST SOL
MSG_McKee's Avatar
That was how I got my hoses off.
Current sMiles: 21,622
Click Here To See My Mod Page
Old 06-18-2008, 06:54 AM   #6 (permalink)
JustMike's Avatar
Yep had to do that on mine as well ...
#1922 12/03/05
MODS: GM CAI & CATBAck
Dover DE
Pontiac builds excitement...
JustMike is offline   Reply With Quote
Old 06-19-2008, 01:27 PM   #7 (permalink)
bones's Avatar
I always use a little 409 or something like it. Squirt it around the hose openings and then run your straight blade screwdriver around the inside of the hose. They will basically fall off.
If you gotta ask "how much?" You cant afford it.
bones is offline   Reply With Quote
Old 06-19-2008, 01:55 PM   #8 (permalink)
Silver Fox's Avatar
Ditto on removal, but I used WD 40
Silver Fox is offline   Reply With Quote
Old 06-20-2008, 07:29 AM   #9 (permalink)
AdamVIP's Avatar
OK I couldnt really get anything in there. After a bunch of pulling and twisting and wiggling I got the passenger side off. The drivers wouldnt budge so I ended up taking off the driver piping at the intake coupler and twisting it till it came off.
After it came off the install wasnt too bad the Hahn intercooler pipes seem to line up farther back than stock. I think I still need to tweak it a bit cause the intercooler piping support holes dont really ailign now. I took it out on the street and she would show 17lbs. I couldnt here any leaks. Im gonna put the front end on tonight.
In the process I managed to break the lower driver tab on my shoud. Anyone know what the part number is to order another one?
Victoria
2007 GXP Manual.
Old 06-21-2008, 09:49 PM   #10 (permalink)
Howster's Avatar
Hey Adam,
I just installed the Dejon intercooler, and even though I have been working on high-performance Euro cars for many years now, this was a pain in the butt. But I got 'er done in about 4 hours, which included some tweeking and getting drinks as it is bloody hot here in the coastal Texas area. Anyway, hope you got it done and if you have any questions, pm me and I will assist wherever I can. Good Luck...
Howster
Howster is offline   Reply With Quote
Old 06-22-2008, 08:09 PM   #11 (permalink)
There is a hose puller, it starts as an ice pick and there is actually two ninety degree bends at the end with the tip pointing back at the hand. It is simple and works very well.
Jack B is online now   Reply With Quote
Old 06-23-2008, 01:02 AM   #12 (permalink)
Howster's Avatar
I used a little soapy water and sprayed it into the hose as I pulled it away just a tad. They loosend immediately.
2007 GXP MEAN All the extras to include Auto.
SOLO Mach Shorty Exhaust, KW V3 Coilovers, SSR Type C RS wheels, Vredestein Sessanta 245/45/18 tires, DDM 4-Pot Calipers, DDM Pro Beam, DDM 3/8" Race Backbone Brace, DDM Slotted Front Rotors, Dejon Intercooler
Purchased 3/05/2008
San Antonio, TX
Howster
Old 06-23-2008, 12:17 PM   #13 (permalink)
Tailhooker's Avatar
I used to get motorcycle handgrips off by letting some rubbing alcohol seep / wick inside, but back then I wasn't a cigar smoker.
Tailhooker is offline   Reply With Quote
Old 07-01-2008, 01:10 AM   #14 (permalink)
Howster's Avatar
What's in the hangar?
Howster
Purchased 3/05/2008
San Antonio, TX
Howster
Old 07-01-2008, 07:05 AM   #15 (permalink)
Howster
Tailhooker, he is referring to your avatar.
