Old 07-22-2008, 04:36 PM
fr0stb1t3's Avatar
Originally Posted by LeadSled1 View Post
From what I understand the Audi RS6 uses the K04 turbo varients. But there are upgrades out there to put in a larger impeller by machining the stock housing. Putting RS6 internals into our housings may be an option.
Does anyone know how our turbine maps to the stock Audi K04 turbines? If ours is the same or smaller we may be able to leverage the already available aftermarket impellers.
Blouch turbo does work on the K04s that I have seen on the net. They do a 27lb/min compressor and an impeller upgrade for the Audi A6.
I'm just not sure of the specs on our stock stuff.
Is it not more expensive to replace the impeller setup then it is to just replace the turbo?
fr0stb1t3 is offline
Old 07-24-2008, 08:24 AM
Typically no, but it varies from turbo to turbo.
nester is offline
Old 07-24-2008, 08:39 AM
nester is offline
Old 07-24-2008, 10:02 AM
imaj's Avatar
I am chiming in late on this...But, with the Westers tune a bigger/better IC and Solo exhaust. The GXP is at 300rwh...Yes?
imaj is online now
Old 07-25-2008, 12:42 AM
ΙΜΗΟ the Audi RS6 uses the K04-029 turbo which is slightly more efficient than our K04-025.
Our K04-025 is the same as in Audi RS4.
Right now i'm in contact with a tech shop in Netherlands ...he installs a compressor wheel from a garett T28 into our turbo along with some port/polish.
He told me he will sell to me a new K04-025 hybrid with the new compressor wheel,not just a compressor wheel.
it's pricey...approx 2.500 usd.!!!
MEGAS is offline
Old 07-25-2008, 07:48 AM
mena661's Avatar
Close. People are getting ~290whp with those mods.
mena661 is offline
mena661's Avatar
Ouch! You might as well get a Garrett GT series for that price.
mena661 is offline
Old 07-25-2008, 08:10 AM
latest info is that this mod sacrifices low end torque at the expense of high end power/torque and the spool up in rpm takes 300-400 rpms more.
that's not an option for me,i like low end grunt/punch.
Anyway i'm searching for the closest alternative on our turbo..!
BTW,can anyone tell me what is the serial part no. on our little K04-025 turbo?there must be a label attached on it..!
MEGAS is offline
Old 07-25-2008, 12:18 PM
shabby's Avatar
Pricey indeed, but if you'd send him your turbo im sure the compressor swap would be cut to well under $1000.
shabby is offline
Old 07-25-2008, 06:53 PM
I think BF is working on something similar and his prices if he can pull it off, will be around 1K USD, or I believe that is what he is targeting as the price.
LatinVenom is offline
Old 07-26-2008, 12:38 AM
SrtRich's Avatar
i am not sure about this turbo but on my stage 3 kit for my neon i upgraded the wheel for less then 1000 so i dont see that being an issue. but i would also lik to see more tunes offered.
SrtRich is offline
Old 07-26-2008, 09:54 AM
Beau's Avatar
"uses the K04-029 turbo which is slightly more efficient than our K04-025"
It's not that its any more efficient, its that it flows more.
Beau is offline
Old 07-29-2008, 06:24 AM
Here is a comparison of the stock impeller, RS6 impeller and a K16 which can both be fitted to our turbo. The K16 takes some machine work to relieve the housing. I would be very interested to see how the RS6 impeller performs in our turbo. Should be a good comprimise between low end torque and more high end power. The RS4s get a nice boost in power from the same swap.
08 Sky Redline
LeadSled1 is offline
Old 07-29-2008, 06:55 AM
JustMike's Avatar
Now we are talking ...
#1922 12/03/05
MODS: GM CAI & CATBAck
Dover DE
Pontiac builds excitement...
JustMike is offline
Old 07-29-2008, 07:39 AM
Cant go too big on the wheel without increasing the size of the turbine spinning it. Otherwise you get a phenomenon called slip, making for a very poor performing turbo.
The middle one looks like it would be within the 15% rule O' thumb on turbine/compressor wheel OD's.
BaldTurboFreak is offline
Old 07-29-2008, 07:53 AM
JustMike's Avatar
Interesting discussion here ... Anyone here running RS6 turbos? - Audizine
#1922 12/03/05
Dover DE
S
