Old 07-24-2008, 09:39 PM
   max hp with stock turbo ?
skotty's Avatar
what kind of numbers ARE being seen with a stock turbo on a gxp ? lets say different intercooler, the ability to tune, good fuel, no restrictions in the exhaust, wastegate turned up and less 10 feet of vac line that is routed to hell and back. lol
what real numbers are out there ?
skotty is offline
Old 07-25-2008, 07:58 PM
Well 1st of all the wastegate mod will have to stay at the OEM position, if using a tune, like Westers or BSR.
The numbers are from 250 RWHP to 290 RWHP
LatinVenom is offline
Old 07-25-2008, 08:31 PM
skotty's Avatar
why does the wastegate need to be in the oem position? has anyone tweaked the vac signal through a regulator or adjusted the rod to get higher boost yet ?
skotty is offline
Old 07-25-2008, 09:09 PM
spider's Avatar
Limp mode is how they found out the wastegate rod needed to go back to its original length.
spider is offline
Old 07-25-2008, 09:55 PM
skotty's Avatar
thats a good reason
i am not running the factory computer so limp mode wont be a problem.
skotty is offline
Old 07-25-2008, 10:53 PM
imaj's Avatar
I have the Westers tune and my wastegate is not back to normal. It is about four turns shy of all the way up. No codes here. Plus, I have shown a crossfire, mustang GT and a 350Z that the Solstice is not to be messed with.
imaj is online now
Old 07-25-2008, 11:34 PM
elwood58's Avatar
skotty,
The cat and mouse with the details is going to get old fairly quick. Man up! Tell us all about your ride, including details on the mods.
3" Magnaflow CATBack Exhaust
K&N Drop In
Short Antenna
ProClip iPhone System
Silverstar Headlamps
elwood58 is offline
Old 07-25-2008, 11:37 PM
fr0stb1t3's Avatar
thats a good reason
Well in that case the factory turbo is likely to run out of breath in the 290-310 whp range. If you want to make any REAL power you'll need to replace it.
fr0stb1t3 is offline
Old 07-25-2008, 11:48 PM
Deepbluegxp's Avatar
It was posted before that the MFG specs say that the turbo is capable of 375hp
Team Solstice 2008
Click My modifications
See my car on cardomain.com
NASSOA Founding Member #48
Deepbluegxp is online now
Old 07-26-2008, 12:02 AM
fr0stb1t3's Avatar
Umm... Where? There's no way that turbo has enough flow on our I4 to produce 375. The actual manufacturers specs for the K04-025 is 260hp.
That's the efficiency map for our turbo:
You'll see even 260 is pushing it a bit. (horsepower along the bottom)
Old 07-26-2008, 09:06 AM
shabby's Avatar
Which begs the question, is that map even accurate? Wasnt gm pushing the stock turbo to 425 ft/lbs of torque at topeka?
shabby is offline
Old 07-26-2008, 09:18 AM
skotty's Avatar
i know that a small turbo can make more boost than most people think. i had a garret off a earlier saab turbo on my 2.2 ecotec and it would go over 25psi in a snap !
we will see what this stock lnf turbo can do soon.
skotty is offline
Old 07-26-2008, 09:35 AM
skotty's Avatar
Originally Posted by elwood58 View Post
skotty,
i am building a off road car (sandrail) and i am using a motor out of a 2007 gxp turbo. i have used the ecotec in my last 3 offroad cars and like the motor alot ! hell i even went out and bought a cobalt for my daily driver. the lnf has a stand alone system so i can tune with no problems. straight exhaust. wastegate will just run a single vac line to the manifold nice and simple. i want to run 20 psi or more and will run race gas if needed. i have a large intercooler and more piping than the stock gxp so a pressure drop and lag could be a problem but time will tell.
skotty is offline
Old 07-26-2008, 09:44 AM
lil goat's Avatar
This is what GM has gotten on 110 race gas in the Gardella Drift Solstice. The hp is 335 but look at the torque! It has a Hahn intercooler mounted vertically with 3 fans pushing air through it. The info is straight from the site listed in my signature.
2007 Pontiac Solstice GXP
Production 2.0L ECOtec LNF turbocharged with race-only calibration
330 hp @ 4500-6000rpm
425 lb-ft @ 3600rpm
7000rpm rev limit
Straight-thru 3” exhaust, with catalytic converter delete
Gardella Racing induction system
Red Bull Drift Team 2008
Solo Mach and High Flow Cat
Wester's Garage RACE tune II
JPM custom shifter.
Barney Juice with Militec-1
DDM Works PINK Breastplate
lil goat is offline
Old 07-26-2008, 09:50 AM
skotty's Avatar
425 lb-ft @ 3600rpm
7000rpm rev limit
wow ! i just read they are using the oem turbo
skotty is offline
Old 07-26-2008, 10:09 AM
fr0stb1t3's Avatar
