Old 07-26-2008, 05:02 PM
fr0stb1t3's Avatar
Your dyno shows what I am talking about. You are losing power towards the end of the graph. That is not your motor, that is the turbo running out of breath. Put a mildly bigger turbo on it and with some tuning it will continue to climb instead of dropping off. I have contacted a company about a K04 impeller swap good for 20-30 more horses without sacrificing much (if any) spool time.
fr0stb1t3 is offline
Old 07-28-2008, 11:08 AM
Deepbluegxp's Avatar
Originally Posted by skotty View Post
good info there guys ! keep it coming
i will get some pictures up when the mods let me
thanks
Two ways to post directly, become a supporting member or join a photo hosting site like photobucket.com and then post the IMG CODE in the forum.
Team Solstice 2008
Click My modifications
See my car on cardomain.com
NASSOA Founding Member #48
Deepbluegxp is online now
Old 07-28-2008, 11:09 AM
An impeller swap on the existing turbo, hmmm that sounds interesting...
Team Solstice 2008
Old 07-28-2008, 01:43 PM
skotty's Avatar
Originally Posted by Deepbluegxp View Post
You can't post directly without becoming a supporting member, join a photo hosting site like photobucket.com and then post the IMG CODE in the forum.
how do you become a supporting member ?
skotty is offline
Old 07-28-2008, 01:49 PM
Click User CP from the menu above and then on the left, Paid Subscriptions. You can also post images here through a photo hosting site. I fixed my post above.
Team Solstice 2008
Old 07-28-2008, 02:55 PM
skotty's Avatar
motor pic
skotty is offline
Old 07-28-2008, 02:56 PM
skotty's Avatar
brain and wiring box
skotty is offline
Old 07-28-2008, 03:23 PM
Place IMG codes around the picture instead of URL and you can post photos. Hit reply to my post to see the code.
Team Solstice 2008
Old 07-28-2008, 04:24 PM
skotty's Avatar
[quote=Deepbluegxp;727755]Place IMG codes around the picture instead of URL and you can post photos. Hit reply to my post to see the code.
thats bad azz
thanks !
skotty is offline
Old 07-29-2008, 07:17 AM
How are you going to get the MEga to control the DI??? Did you write custom code? can I see pleeeeeeaaase!!!! (I'm a mega-lover and have 5 cars running them)
Oh wait I just saw the port injectors...lost my half chub..
BaldTurboFreak is offline
Old 07-29-2008, 07:40 AM
lil goat's Avatar
BTF thats TMI....
Red Bull Drift Team 2008
Solo Mach and High Flow Cat
Wester's Garage RACE tune II
JPM custom shifter.
Barney Juice with Militec-1
DDM Works PINK Breastplate
lil goat is offline
Old 07-29-2008, 08:08 AM
skotty's Avatar
yeah it has the mega and is converted over to port injection. the mega cant controll the di, you can use a mefi controller and controll the di but what you going to do for a upgrade on a di injector ? sorry about the chub thing ! lol
skotty is offline
Old 07-29-2008, 08:45 AM
Brother, you wont need to upgrade the DI injector until you reach 1000hp. Ive run 27psi(with ALOT more turbo than most) and only gone up to 48% duty cycle. The DI has such a narrow injection window that they had to be huge to get the fuel in. WHen runnign in PE mode, the DI injects when the intake valves are open just like port, only downstream.
Maybe when we get our hands on the new sequencer, DI could be possible since it has true sequntial thruout the rev range. I understand that since the new unit will communicate thru CAN, that we lose a little resolution which could be an issue with DI. they have a minimum PW resolution of like 0.5mS. Could be an issue.
Old 07-29-2008, 09:37 AM
Originally Posted by lil goat View Post
This is what GM has gotten on 110 race gas in the Gardella Drift Solstice. The hp is 335 but look at the torque! It has a Hahn intercooler mounted vertically with 3 fans pushing air through it. The info is straight from the site listed in my signature.
2007 Pontiac Solstice GXP
Production 2.0L ECOtec LNF turbocharged with race-only calibration
330 hp @ 4500-6000rpm
425 lb-ft @ 3600rpm
7000rpm rev limit
Straight-thru 3” exhaust, with catalytic converter delete
Gardella Racing induction system
biggest knob on that is spark. the boost is probably max'd out but you can dump the spark and run straight to MBT on race gas. Plus, with cam phasers and plenty of room in the compressor map at 3600 RPM that number doesn't suprise me at all.
sodamninsane is offline
Old 08-04-2008, 05:56 PM
skotty's Avatar
mbt ? sorry i am acronym impaired. sound like you are talking about timing? you should be able to run more timing with better gas. anyone have timing info on a stock motor i can use for a base when i get the motor installed ?
skotty is offline
Old 08-04-2008, 06:10 PM
