Okay Folks,
For the sake of bragging rights let’s start a dyno thread for modifications for the 2.0t. It would be very nice to see side by side comparisons for all the new tunes coming out, exhaust gains, intake gains, turbo upgrade gains, etc…
Don’t forget to list your mods along with an explanation!
Mod#1 blacked-out headlights
Mod#3 Special Sauce (23PSI)
Mod#4 Solo Street Race
'07 Charger R/T Mama's car
I’ll start PCM for Less since Bryan is doing some stuff for me.
Horsepower increase to 317HP (crank)
Torque increase to 332 Ft/lbs (at the rear wheels)
Top speed limiter increased
Boost raised to 22/23 LB with air/fuel changed to run safely at that boost level
Valve timing changed to bring in boost faster with a fast spool up to max boost
Torque management backed off for better launches
These numbers were from a stock car
My very first dyno run from June 2007, the first Westers tune for a Solstice GXP.
My most recent run, not the tune I am running now, but the last one I Dyno'd it is a HP vs AFR not TQ
These are on an eddy current Dyno Dynamics Dyno, they tend to run well below Mustangs and Dynojet, he used a 9% compensation, I think maybe 11% would be better from what I have seen, just this dyno shop tends to be very conservative. They dyno'd a stock GXP at about 216.
__________________ Let's get SLIDEWAYS!
Solo Mach and No Cat
JPM custom shifter.
Barney Juice XPR 21
RMR Style Bar. Peak RWHP 286.3, Peak Torque 313 ft/lbs.
DDM Works PINK Breastplate
HKS Coilovers
I think it is more than that now but Lyndon told me not to dyno the tune I am running because he has a new one coming soon. (when you and I go home and watch TV, he plays with ECM code)
When he did my first tune he had never seen a GXP, just adjusted what he could based on a best guess, 262 wasn't bad for a first try.
JPM custom shifter.
Barney Juice XPR 21
HKS Coilovers
Just understand when you are looking at the figures you most take into account what other mods the car has, since that will have a significant change in the numbers.
A car with ALL stock hardware and a tune will have different figures to the same car with Exhaust system, intercooler etc.
Also the type of Dyno gives different results.
~~~~~~~ NASSOA
Lil-Goat has a nice signature with listed mods.
The biggest issue with comparisons like these is the variance in dyno's, I have seen my car dyno 10 rwhp less on the same dyno with no changes to the car just because of weather. Eddy current dyno's are very accurate, and give lower results than inertia (roller drum) dyno's but they are not nearly as consistant. You can repeat results on a Dynojet pretty well, not nearly as easy on Dyno Dynamics. I also learned that the GXP heat soaks very quickly, and usually the second pull will give the best numbers. I am sure it has to do with heat, turbo does better warm but not hot.
JPM custom shifter.
Barney Juice XPR 21
HKS Coilovers
Magnaflow Cat Back -219 RWHP (Dyno Dynamics, 3rd gear pull) I dunno why they didn't do a 4th?
Magnaflow Cat Back, Solo CAT and Waste Gate Rod mod, Dejon Spring 235 RWHP (Eddy Dyno)
Magnaflow Cat Back, Solo CAT, Dejon Spring, Westers Race Tune (Wastegate returned to stock position) 280 RWHP (Eddy Dyno)
Amazing nose dive power takes after 5500 rpm on all these graphs. We need a bigger turbo.
Actually if you look at mine, the dyno operator stopped recording at 5700 and the HP was still up there. I need to go back and get him to push it to the redline (7400) I'd like to know where my power fall off.
Hopefully the larger wheel with the power management settings out of the way, it will show a good increase past 5500 RPM.
~~~~~~~ NASSOA
