Old 06-14-2008, 01:32 PM
   Rod Mode and Westers Tune
NightwingII's Avatar
I know this will probably be another post speaking bout the same thing but....
If you do the Rod mod on the waste gate does it work well with westers tune?
Thanks
2007 Mysterious GXP Red Stitching
All Options minus OnStar
Solo Mach Shorty Exhaust
Solo Hi Flow Cat
Dejon Intercooler Pipes
Dejon Wastegate Spring
Wastegate adjusted
NightwingII is offline
Old 06-14-2008, 05:34 PM
shabby's Avatar
Do you really need more boost? Westers is running like 23+ psi with the race tune, i'd keep the rod in the stock location.
shabby is online now
Old 06-14-2008, 05:49 PM
Go-N Def's Avatar
They don't go well together. Like Shabby said, you can get 23 PSI with the tune. If you hold that over 3 seconds, you'll go into limp mode.
I had the mod on mine when I got the tune and noticed some knock at 23 PSI. I backe mine back to the stock position, get 21-22 PSI consistantly, and eliminated the knock.
Pics on MySpace
Go-N Def is offline
Old 06-14-2008, 06:49 PM
JustMike's Avatar
You are not going to have the rod much forward of stock with the Wester's tune ...
#1922 12/03/05
MODS: GM CAI & CATBAck
Dover DE
Pontiac builds excitement...
JustMike is offline
Old 06-14-2008, 09:24 PM
Thanks for the info.
I have the rod mod right now just getting the info together fo rthe tune. Didn't want to conflict with anything. I will turn the rod back before the tune then.
Thanks a bunch guys.
Solo Hi Flow Cat
Wastegate adjusted
