Old 07-21-2009, 03:14 PM   #1 (permalink)
volumetric efficiency of 2.0?
does anyone know what the volumetric efficiency of our engine is in stock form?
thanx in advance
perris is offline   Reply With Quote
Old 07-23-2009, 06:24 PM   #2 (permalink)
I'm just repeating what i've read, but since its a turbo engine, the VE is greater than 100%, and how much greater depends on the boost/airflow of the turbo...
If you're referring to the calculated paramter "VE Airflow" on stock engine, I've seen 23-24 lbs/min stock, currently 29lbs/min. Some say max is 30lbs/min on stock turbo.
2008 BRAZEN GXP - 5M Loaded Tuned to ~22 PSI with HPT, AIS stage 1 water/methanol injection kit, Hahn Racecraft Intercooler.
To come: Bigger meth nozzle, Solo Street Race Exhaust, BIGGER TURBO
oldskool is offline   Reply With Quote
Old 07-23-2009, 06:34 PM   #3 (permalink)
thanx, wound up not needing the information but your post is interesting
