Old 07-28-2006, 09:17 PM
   Moving the Power Steering Reservoir for Turbo-ed cars
VIN2020's Avatar
Moving the Power Steering Reservoir for Turbo-ed cars.
More details will be coming, and I will update this very first post as I collect them all and get pictures.
Parts list:
1) 40 inches #10 hose (part# AQP FCN10 at Speedtek, aka Aeroquip FC598-10) @ $6.99/foot
For complete length between resevoir and power steering pump.
This is the pump supply line
2) 36 inches #6 hose (part#AQP FCN10 at Speedtek, aka Aeroquip FC598-6) @ $5.99/foot
For additional length from power steering rack hose to resevoir.
This is the return line.
3) 2 x 8' Expandable sleeving, I.D 3/4", Max Dia: 1" $18 (from Frys)
Black braided style to give it a great production look.
http://shop2.outpost.com/product/228...H:MAIN_RSLT_PG
4) 3 x 5/16"-7/8" Hose Clamps
For splice addition hose from power steering rack to resevoir.
5) 2 x 1/2" - 1 1/4" Hose Clamps
For pump feed line from resivoir
6) 1 x 3/8" Barb x 3/8" Barb Splicer Brass (from HomeDepot)
For addition to the power steering return line from the rack to the resevoir
7) 3/4" Drill Bit for metal (from HomeDepot)
To dril a hole in bracket to swivle the feed line to the pump.
8) 1 x Cap Screw Socket 8mm x 20mm 8 Plain Steel (from HomeDepot)
To replace OEM screw so that new bracket can be used to swivle the feed line to the pump.
Note: this scew was too long as is, thus I added 3 lock washers to it.
NOTE: WARNING: Becarefull with removing the OEM scew I ended up destroying it trying
to remove it. Apparently I did not have the allen head all the way in when I first
tried. That one time, and I couldnt recover it with out serious surgery on it.
9) "S" style bracket 7" tall with 1.5" folded over to create tabs for mouting at both ends
Made from aprox. 3/16" thick x 1" wide bar stalk I had laying around.
See picture 3 below
10) Bracket to swivle the feed line to the pump 180 degrees.
See pictures 7 & 8 below.
11) "Valvoline SynPower Power Steering Fluid Synthetic Blend With Conditioners"
Part#:VV056
Rough steps:
1) Have 1 liter plastic bottle with top cut off to capture drained power steering fluid.
2) Disconnect power steering feed hose down by power steering pump.
3) Drain fluid
4) Fabricate "S" bracket (painted black)
5) Fabricate swivle bracket
6) Install parts per pictures.
7) Start engine and start pouring power steering fluid into resevoir
8) turn steering wheel to stops one way while keeping power steering fluid at proper level
9) turn steering wheel to stops the other way while keeping power steering fluid at proper level
10) repeat steps 8 & 9 two more times
11) Check for leaks.
1) Part of the "S" bracket and hose routing, notice the braided sleeves around the hose.
http://putfile.com/pic.php?pic=main/...3974.jpg&s=f10
2) "S" bracket mounts using the original frame bolt.
http://putfile.com/pic.php?pic=main/...4952.jpg&s=f10
3) Close up detail of the 7" tall S bracket
http://putfile.com/pic.php?pic=main/...5513.jpg&s=f10
4) Just another picture of the mounting location
http://putfile.com/pic.php?pic=main/...0398.jpg&s=f10
5) More details of the hose routing
http://putfile.com/pic.php?pic=main/...1145.jpg&s=f10
6) About middile over the fan shroud, is where the 3/8" barb to barb was used to add in the 3' more of hose for the return from the power steering rack.
The braided sleev covers up the hose clamps used for the 3/8" barb splicer.
http://putfile.com/pic.php?pic=main/...2956.jpg&s=f10
7) Bracket used to allow the power steer pump feed line to be swivled 180 degrees.
Need to swivle the connector so the hose bend radius isnt to sharp to keep away from the turbo.
The picture is looking down at the power steering pump.
http://putfile.com/pic.php?pic=main/...4842.jpg&s=f10
8) Again looking down at the power steering pump, trying show more of the bracket made to swivle the return line 180 deg.
Notice: the power steering pump feed tube is rotated 180 degrees for the hose to go up and over the fan shroud.
Notice: 3/4" hole to slide the bracket over tube.
http://putfile.com/pic.php?pic=main/...0497.jpg&s=f10
9) Finished look on turbo side. It is clear now how much the resevior was limiting air flow back into this area.
http://putfile.com/pic.php?pic=main/...2641.jpg&s=f10
VIN2020 is offline
Old 07-28-2006, 09:52 PM
These part numbers....they are from what store?
Napa, Advanced Auto, OReilly?
The sleeving....is it loom sleeving or something more heat resistant?
I don't see a bracket in the list, did you not have to make one?
tweety is offline
Old 07-29-2006, 12:54 AM
   Updated first message
VIN2020's Avatar
First message was updated.
VIN2020 is offline
Old 07-29-2006, 07:14 AM
   Thats where I moved mine.
BoostedSOL's Avatar
great job on the how to! If you look closely at my setup you'll see that I reused the factory mounting bracket as I cut it just that section off, in order to use this you will need an allen head bolt as the theres not enough space for a standard bolt. Awesome work on the 180 degree rotation of the feed line, I'm inspired to do that myself now.
BoostedSOL is offline
Old 07-29-2006, 07:42 AM
Moving the reservoir is not only the best idea to protect it from the heat but it also allows for a cleaner look and an easier access to the turbo for spot inspections and checking of bolts.
All said the materials couldn't have cost even a tank of gas. Awesome work.
tweety is offline
Old 07-29-2006, 08:08 AM
VIN2020's Avatar
I was thinking about cutting that section off to, although with just tossing it to the side. Your idea to use it on the new bracket isexcellent!!
Did you keep the resevoir height the same as its was in original postion?
VIN2020 is offline
Old 07-29-2006, 08:13 AM
BoostedSOL's Avatar
Its lower but the reservoir is still above the rest of the system so thats all that matters, now a really crafty guy would get a B&M trans cooler and mount that in front of the radiator and do away w the stock tube cooler
thats, actually in my to do list for a later time.
Old 09-04-2006, 09:24 PM
VIN2020's Avatar
Updated original post to add in the power steering fluid used.
VIN2020 is offline
Old 09-05-2006, 09:29 AM
carlintexas's Avatar
VIN., guess I'll put this on my 'to do' list while I'm installing the radiator.
TEAM SOLSTICE 2008
NASSOA(tm)
Founding Member #2
1st 1K #781
DDM Custom Turbo System
3" Magnaflow cat-free
Riken Raptor's 255/45/18
carlintexas is offline
Old 09-05-2006, 07:52 PM
VIN2020's Avatar
After moving the resevoir, it made me feel kind of silly trying to work around it all this time while working on the turbo. I think it is a true must do.
VIN2020 is offline
Old 07-28-2007, 08:24 AM
VIN2020's Avatar
Updated Picture links:
Parts list:
See picture 3 below
Part#:VV056
Rough steps:
3) Drain fluid
http://www.putfile.com/pic.php?img=3110629
http://www.putfile.com/pic.php?img=3110622
http://www.putfile.com/pic.php?img=3110616
http://www.putfile.com/pic.php?img=3110612
http://www.putfile.com/pic.php?img=3110602
http://www.putfile.com/pic.php?img=3110597
http://www.putfile.com/pic.php?img=3110594
http://www.putfile.com/pic.php?img=3110591
http://www.putfile.com/pic.php?img=3110587
VIN2020 is offline
Old 08-01-2007, 10:53 AM
   You did this yourself?
ClearBraInstall's Avatar
Didnt your Hahn Kit come with a PS relocation kit? Mine did. Although mine is relocated over the battery compartment.
Clear
Mods
  • Dynoed at 450HP
  • Hahn High Flow CAT
  • Eibach Sportline Springs
  • SSBC Big Brake Kit
  • Konig Privat 19" Wheels
  • Custom Two Tone Paint
  • Razzi Wing
ClearBraInstall is offline
Old 08-01-2007, 11:00 AM
V10Venom's Avatar
Clear
I know the DDM kit is relocating it to the same place. I really hope install is easy. ClearBra...it is a lot more simple than this thread makes it sound?? That's the one part I'm sort of unsure of.
2004 Dodge Ram SRT-10 - 500HP/525 ft/lbs!!
V10Venom is offline
Old 08-01-2007, 11:02 AM
