Go Back   Pontiac Solstice Forum > Technical Solstice Discussion > Mods - Engine 2.4 l Ecotec
Old 12-12-2005, 02:54 AM   #31 (permalink)
JT72's Avatar
Yeah, Sorry about that. I'm not too computer literate to flip image.
JT72 is offline   Reply With Quote
Old 12-12-2005, 01:54 PM   #32 (permalink)
Per Diem Administrator
brentil's Avatar
It's all good. All that matters is you got dyno graphs to show us.
Save the Kappa!
NASSOA (TM)
Old 12-12-2005, 07:08 PM   #33 (permalink)
Ex-Miata Man's Avatar
I've never seen a dyno graph before. Can someone give a quick lesson on how to read them and what they are showing? Thanks!
AKA xmm
DEEP with Steel/Sand leather,
88,000+ miles on the odo and still goin' strong- Silver side stripes - My wife named my car "Nittany" after Penn State, my Alma Mater
Proud Member - ICoD EHDoR&M
WPASC
Founding Member #41
"Goin' on a Turkey Run !!!"
Ex-Miata Man is offline   Reply With Quote
Old 12-12-2005, 10:15 PM   #34 (permalink)
salstice's Avatar
Sure, I can try and explain what you're looking at. Usually the dyno graphs show rpm's (rotations/revolution per minute) along the bottom axis (x-axis). Along the vertical axis (y-axis), either torque (ft-lbs) or horsepower will be shown. Now the line that is plotted represents a specific horsepower or torque values at corresponding rpm's. This plot is very helpful because one can see where there are power losses and gains. One can then tune to add power where it is desired. Hope this helps.
salstice is online now   Reply With Quote
Old 12-13-2005, 05:59 AM   #35 (permalink)
salstice,
Thanks for the explaination. I've read about the dyno tests on the Forum but didn't know how they worked. Thanks again.
XMM
AKA xmm
WPASC
Founding Member #41
Old 12-13-2005, 10:02 AM   #36 (permalink)
todd_raleigh's Avatar
sorry for the stupid question, but how do you get two values for the same horsepower/torque? is it due to different gears? how do you read the shift from gear to gear? there are different colored lines? what are they? I didn't see a legend on the graphs to explain it. thanks. todd
2007 Solstice GXP | Arrived: 9/11/2006 | VIN #109588 (Deep)
2006 Solstice (traded in for GXP) | VIN #1337 (Deep)
Solstice Chat room (unofficial): http://www.emmershy.com/SolsticeChat
todd_raleigh is offline   Reply With Quote
Old 12-13-2005, 11:51 AM   #37 (permalink)
toddwcarpenter's Avatar
I'm not exactly sure what you mean by multiple values. I think you are asking about the different runs on the dyno. Each colored line represents these different runs. Many dyno shops run your car three times for a flat fee. This allows you to be sure that any one dyno is not an anomoly. Runs are usually only done in one gear, 4th usually.
toddwcarpenter is offline   Reply With Quote
Old 12-13-2005, 12:49 PM   #38 (permalink)
Engines make different horsepower and torque at different RPM, period. If you have a 170 hp engine... that's the engine's PEAK horsepower at whatever RPM is peaks at. No matter what gear you are in, your engine makes the same hp/torque except it's multiplied by the gear ratio and your tires experience it at the multiplied number. The different colored lines on those sheets denote either torque, hp or air fuel ratio. As for the three runs, your engine isn't perfect, it'll put out very slightly different numbers from one run to the next simply because of random events... like spark plugs arcing a slightly different direction causing better or worse burns.
Thraxz is offline   Reply With Quote
Old 12-13-2005, 03:57 PM   #39 (permalink)
What's the deal with the dips at 2400 & 3400 rpm's??? That would scare me. Almost looks like clutch slip. Pretty dramatic on the torque graph. Maybe wheel slip. I have never seen a dyno on this type of dyno. Where is the A/F you are talking about?
SRT4Geezer is offline   Reply With Quote
Old 12-22-2005, 10:02 PM   #40 (permalink)
Probably should datalog a run as well with some sort of scanner. Logging timing, IAT, etc.. We will be doing one next week and I will post some results.
Dave
Old 12-22-2005, 10:17 PM   #41 (permalink)
Hey fellow Sol'legues, I decided to go get my Solstice Dynoed just morning and want to share my results. Not stated but, I'm getting a lil over 190 at the fly wheel. Tech says i'm running a lil rich but if i can get someone to adjust my mixture using my ECU I should get around 200hp on the F/W & maybe around 173 at the R/W. Anyway i'm happy with the Sol's performance. He said with a Turbo at 10 psi i should be around 300hp. (Subaru WRX STi killer I really don't know what most of these colorful lines mean but i'm sure most of you do. Oh, don't forget i am equiped with GMPP Intake & Cat back. Feel free to comment. Oh yeah, Miata MX-what! IN LUV with #1928
Nice wheels, who makes those, and uh how much?
mlegere is offline   Reply With Quote
Old 12-28-2005, 07:19 PM   #42 (permalink)
JT72's Avatar
Dave
I have no idea what you are talking about, i have problem reading my own Dyno. What's Loggin timing, IAT, and how was the results.
#1928 Delivered Mysterious Home Oct.19, 2005 All past augmentations:, GM Performance Exhaust, HRC high boost kit, Eibach lowering springs, chromies, HRC Stage 4, Random Technology High Flow cat Findanza Lighten Flywheel, RKsport CF Hood,, Greddy BOV, AEM A/F Gauge & Boost , Vertical doors, Oil Catch can, Gravana J2 staggered set wheels, EBC Dimple drilled slotted rotors, Hawk Performance brake pads, Proxis T1R tires, Carbon Fiber Gas Brake & Clutch pedals.
Old 01-10-2006, 09:41 PM   #43 (permalink)
Dogtown's Avatar
Stock Dyno
Here is my first baseline dyno.
-DT
#197
V-8
Dogtown is offline   Reply With Quote
Old 01-11-2006, 02:36 PM   #44 (permalink)
brentil's Avatar
I was having issues with the image no loading for me so I attached it to your post as well.
Seeing that 3200 RPM torque drop over and over again just baffles me all the time. Is GM doing something the the ECU or something to hinder the engine at that point or something?
Save the Kappa!
NASSOA (TM)
Old 01-11-2006, 04:14 PM   #45 (permalink)
Dragon Rider
SolsticeWolf's Avatar
Send a message via AIM to SolsticeWolf Send a message via Yahoo to SolsticeWolf
Ditto.
Tell me about it, brentil. I refer you back to mine:
The dip in torque co-incides with a drastic drop in the A/F ratio. How odd is that? Any body care to enlighten me?
Honda Associate, Solstice Owner
2006 Mysterious Steel/Sand
Personal tag: PURNRG = PURe eNeRGy!!!!
SolsticeWolf is offline   Reply With Quote
