Go Back   Pontiac Solstice Forum > Technical Solstice Discussion > Mods - Engine 2.4 l Ecotec
Old 02-24-2009, 12:14 AM   #1 (permalink)
supercharger risks - problems
What are the risks of installing a supercharger and has anyone had any trouble or problems with it?
carcollector is offline   Reply With Quote
Old 02-24-2009, 02:40 AM   #2 (permalink)
EndiSky's Avatar
Burning through tires faster!!!
EndiSky is offline   Reply With Quote
Old 02-24-2009, 04:08 AM   #3 (permalink)
zzzybil's Avatar
pretty impressive huh
i can't say that i've ever seen a post about trouble or problems......
i'm assumin if there were any ........lol....we'd know !
....thats pretty impressive.....
... come to think of it ! wow!!
BOOsted 2.4
42lb injectors
3" tubes front to back
10 boost
38mm tial wastegate / bov
custom i/c (BELL)
Werks radiator
aem wideband
hi flo cat
HPTUNING - the hard part !!!
(tune therapy -> randy @DDM)
JET-HOT 2000
aerologic egt kit
DDM backbone
AEM boost control
custom .08ss heatshield
YEAH I DID THAT !
Old 02-24-2009, 07:48 AM   #4 (permalink)
Chemist's Avatar
I'm four months with mine with only one real issue (threw a belt because _I_ did not check the tension on it before beating on the car hard one afternoon). This was NOT a S/C issue per se, but my lack of experience/attentiveness.
The other "problems" I have are:
1) My right foot seems to be heavier now, and I burn through gasoline and tires.
2) My wife has taken to shaking her head at me when I leave stoplights.
NASSOA Founding Member
Old 02-24-2009, 07:57 AM   #5 (permalink)
Have you considered doing a search ?
Some of the first installations had issues with engine codes, primarily related, if I recall correctly, with MAF sensors. Since then, nothing that I have noticed.
Sky VIN 00252
5-Sp Manual
Midnight Blue
Old 02-24-2009, 09:43 AM   #6 (permalink)
RevmanII's Avatar
I've had mine since Sept '07. Stage I for about 3k or so then stage II the following spring. About 15k total. Problems have been minor. Couple of misc codes with Stage I. I was getting an occasional lean code with stage II, but never while in boost. Randy custom tuned mine at the NY mod meet in the beginning of Jan this year. No codes since. Couple people have had belt issues. I'm not one them . I think it's important to have some way to read and clear codes. Without knowing what they are and being able to clear them I think it could be very frustrating. Some guys have run code free, but for me having the DashHawk has been a great investment. Other than that, the setup has been very solid. I wouldn't hesitate to do it again .
Mods: DDM Stage II supercharger, long tube header and cat, Probeam, and Race Backbone. Solo Performance SQR-2 catback. Norm's first center exit Solstice rear fascia. JPM center console. DashHawk.
RevmanII is offline   Reply With Quote
Old 02-24-2009, 09:51 AM   #7 (permalink)
AZDarkSol's Avatar
Question: What happens when you break or throw the belt to the SC?
Are you dead in the water 'till it's re-installed? Or will it somehow sift thru N/A?
Mods: Billet front grille.
Venture shield clear bra
GM mud flaps (front)
Carolina Custom armrest pads
Norm's "Fabulous" Fiberglass Split Dual Rear Fascia
Lovin' AZ
Pontiac: "We Used to Build Excitement! Now We Build Nothing"....
AZDarkSol is offline   Reply With Quote
Old 02-24-2009, 10:14 AM   #8 (permalink)
seal9's Avatar
NO, with the new belt and pulley system DDM has for the S/C kits the S/C belt is on its own drive. If you do brake or throw a belt you can still drive the car as it was before the S/C. I have just updated my kit and I like the new sysytem, But then I never had any problems with the old system...Seal9
Chili Pepper Red leather/LSD
White Redline Loaded Stock
Focuz Long tubes/Free Flow Cat
Thermal Research Dual Exhaust
DDM Supercharger Stage II.5
High Vol Fuel Pump
Water/Methanol Inj
DDM Shock Tower Brace
DDM Brakes/Pro Beam/Backbone
PLX Wideband AFR /Boost
DashDyno/Dashhawk
seal9 is offline   Reply With Quote
Old 02-24-2009, 11:20 AM   #9 (permalink)
Jackknife's Avatar
Somebody said the new pulley system increases boost. Did you experience this? If so, did you have to re-tune the ECM?
DDM Pro-Beam and back brace
Jackknife is offline   Reply With Quote
Old 02-24-2009, 11:57 AM   #10 (permalink)
Chemist's Avatar
Even with the old system, I was able to limp home to replace the belt. The alternator was not working in the serpentine belt's absence, but I was only about 3 miles from the house.
As Seal9 stated, the latest version isolates the S/C from the main belt system. Now, should you lose the S/C belt, which is as likely now as losing any belt would be (i.e., nil if replaced periodically ), your car simply reverts to "normal" N/A status and home you go to replace it (or in my case, off you go to the side of the road to replace it, as I carry spares ).
Bottom line: the DDM S/C system is stable, reliable, and WAY FUN! Come on in, the water is fine!
Old 02-24-2009, 12:32 PM   #11 (permalink)
Randy@ddmworks's Avatar
Jack,
No ECM tune is required with this upgrade.
www.DDMWorks.com
Randy@ddmworks is offline   Reply With Quote
Old 02-24-2009, 01:03 PM   #12 (permalink)
Jackknife's Avatar
Originally Posted by Randy@ddmworks View Post
Jack,
Thanks, Randy. What about boost change?
Old 02-24-2009, 01:12 PM   #13 (permalink)
seal9's Avatar
I just had a Grand Baby Boy 6lb 8 oz very ruff on my daughter all most lost her. so I don't have it all done yet. will let you know if the boost gos up. seal9
High Vol Fuel Pump
Water/Methanol Inj
DashDyno/Dashhawk
Old 02-24-2009, 01:18 PM   #14 (permalink)
AZDarkSol's Avatar
I am a GrandPa Sol myself four times over!
Congrats GrandPa!
Here is praying everyone continues well!!
Lovin' AZ
Old 02-24-2009, 01:22 PM   #15 (permalink)
Jackknife's Avatar
Will do, Seal9. Best to your's...family first.
