Old 07-24-2007, 11:59 AM
   Vector ECM Problem
Jackknife's Avatar
Received my re-flashed (back to stock) ECM from Vector today and installed it in my car.
Turned the key and the car "lights up" but won't crank.
Tried to call Chris, but he doesn't answer his phone...sent email also.
While I'm waiting, does anyone have any ideas?
Jackknife
FE3 sway bar ... Car. Cust. Rests and Pockets
Blacked-out Grills ... Debadged
DDM Pro-Beam and back brace
Jackknife is offline
Old 07-24-2007, 12:22 PM
PAO
PAO's Avatar
I beleive you have to do a crank re-learn....you can do a search for this subject...
Per Solstice Service Manual page 10-86:
If the ECM is replaced a CKP Variation Learn Procedure must be performed. Refer to Crankshaft Position System Variation Learn on page 6-553.
Page 6-553 is devoted to how to perform the learn.
It requires a scan tool, to see if the P0315 was successful.
Dealer does it, unless you have a good scan tool and the procedure.
Pontiac builds excitement...
NASSOA(TM)
PAO is offline
Old 07-24-2007, 12:26 PM
JustMike's Avatar
One question could be how you reflashed it back to stock as we know that Chris locks what he does on the ECM. Another is that besides the crank re-learn there could also be a security learn.
#1922 12/03/05
MODS: GM CAI & CATBAck
Dover DE
JustMike is offline
Old 07-24-2007, 12:27 PM
Jackknife's Avatar
Wouldn't you think Vector would do this? When they did my original re-tune a crank re-learn was not necessary.
Jackknife
Old 07-24-2007, 01:25 PM
RevmanII's Avatar
You shouldn't need a crank re-learn from my understanding. Possibly a security re-learn. Not sure the procedure, but I'm sure a little searching should come up with it.
Mods: DDM Stage II supercharger. Solo Performance hi-flow cat, and SQR-2 catback. Norms rear fascia. MSD DashHawk.
RevmanII is offline
Old 07-24-2007, 01:31 PM
Supporting Tuner
Jackknife
We were out to lunch in meetings most of the afternoon so far, you probably just have to do the security learn. I believe that info was included on the sheet with the unit when it was returned.
Chris White
www.GTOShiftLight.com
Home of the first 2.4L and Kappa tuning!
2006 GTO MXO Spice Red
2008 CTS4 3.6L DI
2008 Malibu 3.6L
2008 Trailblazer SS
2008 CBR600RR
GTPprix is offline
Old 07-24-2007, 04:13 PM
Jackknife's Avatar
I've tried the security re-learn...no help. The security light stays lit...the car won't crank.
BTW, there was no instruction sheet included w/the ECM.
I'm waiting for Vector to suggest another course of action.
Jackknife
Old 07-24-2007, 06:14 PM
Jackknife's Avatar
Well, here it is 6 PM, CST and no word from Vector since 2PM.
My car still won't crank, won't take a security re-learn and the fuel pump module in the fuse box clicks away continuously when the key is on "ON".
I hope tomorrow is a better day...Vector, are you out there?
Jackknife
Old 07-24-2007, 06:52 PM
seal9's Avatar
JK was the ECM your original that came in the car...Seal9
seal9 is offline
Old 07-24-2007, 06:55 PM
seal9's Avatar
JK had the same problem....My fix was to undo the Neg cable to Bat...took out the ECM..check the cable plugs..reinstalled this time it worked...seal9
seal9 is offline
Old 07-24-2007, 06:57 PM
Jackknife's Avatar
Yes, it was. Vector added their tune and it ran fine from the day I got it back...no re-learn anything.
Jackknife
Old 07-24-2007, 06:59 PM
Jackknife's Avatar
I might add, I marked the ECM so I'd know if I got the same one back.
Jackknife
Old 07-24-2007, 07:00 PM
Jackknife's Avatar
Will try, thanks.
Old 07-24-2007, 07:50 PM
   Still no good
Jackknife's Avatar
Will try, thanks.
Well, I tried what you said, Seal9, no help.
The connectors look fine, click into place and lock up.
Still won't crank, failed third attempt at security re-learn, fuel pump relay clicks away...and now I noticed that my fuel gauge, which has always been right-on, has quit.
I'm coming to the opinion that Vector did a lot more to my ECM than restore its stock program.
Jackknife (waiting for Chris to step up)
Old 07-24-2007, 09:30 PM
Have run into this with other GM ECM's, only 1 Bosch-duramax. The only fix was ECM replacement. Have tried to reflash problem ECM's but to no avail. Root cause was almost always external electrical fault (just boosted from or to another vehicle, faulty charging system, shortcuting repair/replacement procedures, etc..) What procedure did you use to reduce the chance of ESD (electrostatic discharge) during ecm removal & replacement-possible cause.
Depending on what was changed during a reflash a security relearn may or may not be needed, engine will crank & fire up but stall-cuts injectors. As a matter of practice I always do a c
