Old 05-01-2008, 08:20 AM
SmokinSolstice's Avatar
Originally Posted by 4Banger View Post
These tunes cannot do anything with the transmission as of yet so I would say any
torque mgmt help would be minimal. I'm waiting for the full tuning capability of engine
and tranny in a handheld unit. Maybe, that is what chris is working on.
Not what the tuners are saying, they say it get rid of the torque limiters.
Team Solstice 2008
Ordered 11/12/05
SmokinSolstice is offline
Old 05-01-2008, 08:21 AM
Originally Posted by Moose GXP View Post
There's no need to do anything for a manual. It's purely ...manual...that include no torque management too. That's only on autos.
Are people talking about the nanny controls? Those are easily turned off with a tune, I believe.
Yes the nanny controls...at least thats what I am talking about.
Team Solstice 2008
Ordered 11/12/05
Old 05-01-2008, 08:32 AM
12_month_wait's Avatar
What are these 'nanny' controls? Since my car didn't come with Mary Poppins in the passenger seat, I would consider the traction control and stability control functions to be among the other anonymous 'nanny' limiters. However, removal of those particular features would be a minus. There are a few roads around here that are quite slippery when wet.
"Thou shalt make a GM vehicle** people will like."
**excluding Corvette and other desirable GM vehicles
-Bob Lutz
12_month_wait is offline
Old 05-01-2008, 08:37 AM
Read this....GM Roadster Car Club Saturn Sky Pontiac Solstice Opel GT Daewoo DX2 Owners - Ecotech ECM Tuning 101
Team Solstice 2008
Ordered 11/12/05
Old 05-01-2008, 08:59 AM
Interesting, but it also implies traction control and stability control would be affected.
"However, most engine computers are programmed at the factory with "granny controls" to make insure that the operator will not lose control and that the vehicle will have limited stress on it's components."
Otherwise, is this (from the link) the definitive list?
Power Enrichment Delay
Timing Table - timing curve advance
Speed Governor
Torque Limiters
It seems that these items get mentioned as other tuning items in addition to gr/nanny controls, so it's not clear to me if some of the ECM improvements are being double book-kept. I just like to know what I'm getting when I buy something. Stage 7 hyper-nanny control removal doesn't mean much to me. What if I like the stage 3 nanny controls?
-Bob Lutz
Old 05-01-2008, 11:44 AM
As the tuner/technical guru for GMRoadster, maybe I can help out here.
There are a lot of good companies out there that offer tunes, including myself.
Ideally you would not want to have your PCM/ECU locked, because that requires you to send it back and have it unlocked and untuned before you can alter the files on it. Plus, it can be a long wait to get it back since it has to be shipped both ways.
What you want to have done in your tune is:
1. Disable torque management, which raises the amount of engine power that can be applied in the low RPMs. This will eliminate some of the initial hesitation, and sometimes jerking sensations you can get when letting the clutch out and giving it gas.
2. Raise rev limiters to ~7,300, but keep them intact. There is no reason to rev beyond this, and I still recommend shifting at or before 7,100 rpms. It is not a wise idea to completely remove the rev limiter in any way.
3. Raise the Top Speed Governor to what ever you want (200mph is more than adequate)
4. Remove the timing dip that sits around 4,000rpms to even it out. And raise timing across the board. Timing can be increased more in the low end, but the top end (4k+) is limited to ~2-4* advance depending on available octane.
5. Increase fan speeds above 205*F, but not before due to cooling issues. The cam advance calculations are based upon engine temp, and if it operates below projected temperatures then a lack in power and fuel economy will result. (Not true on all cars, just Ecotecs with VVT)
6. Slightly lean out top end fuel mixture
7. Lower PE Delay to above cruise rpm, don't completely remove it.
8. OPTIONAL - If you have removed the catalytic converter, then you will need to disable COT controls, and the necessary engine codes. Failing to do so will result in a super-rich Air Fuel Ratio.
PSYKOSTEVO is offline
Old 05-01-2008, 11:45 AM
Those are my articles BTW, you guys should check some of them out, and feel free to comment / ask questions.
Old 05-01-2008, 11:47 AM
Moose, unfortunately there are torque limiters on the Manual cars too. They are built into the tune for the motor regardless of transmission choice. The Auto cars just have additional abuse modes and torque converter lockup tables.
Old 05-01-2008, 12:09 PM
Stability Control and Traction Control are still enabled on my tuning. They CAN be removed, but are not recommended.
Traction Control and Stability Control are turned on and off through a tune by switching between ENABLE and DISABLE, Torque Management is a whole different table that relates the amount of torque output to engine load and RPM. Even if you turn torque management to it's maximum setting and keep traction control on, the traction control will still work.
Old 05-01-2008, 02:00 PM
Steve very well said, you cleared up a lot questions in this thread. It is obvious you know what your doing, I will be in touch soon when its time.
Team Solstice 2008
Ordered 11/12/05
Old 05-01-2008, 02:10 PM
Moose GXP's Avatar
Agreed. Thanks for the input, Steve!
NASSOA Founding Member
Moose GXP is offline
Old 05-01-2008, 05:02 PM
Did you make it out to the National meet this past weekend in Vegas?
I will be out in El Paso, TX next on May 17-18th if any one is in the area and interested in a tune.
After that, the next big meet is scheduled for San Diego on August 15-17th. To sign up for any of these events or tuning just log onto GM Roadster Car Club Saturn Sky Pontiac Solstice Opel GT Daewoo DX2 Owners - Home
Old 05-01-2008, 08:07 PM
GM Roadster Club's Avatar
Steve does a great job for us at GM Roadster, he has truly earned the trust of this National Club as well as the respect of it's members.
As mentioned Steve will be in Texas next week tuning Cobalts & Kappas and he'll be with us at the Regional San Diego Coastal Event in August.
We are willing to fly Steve to do group tuning if you can get 10 members together.
Martin-GMR
GM Roadster Club is offline
Old 05-02-2008, 09:25 AM
4Banger's Avatar
How effective is torque mgmt. though without being able to access transmission tcm?
Also, how would I go about getting a tune from you? Thanks!
2008 Deep 2.4L - Premium Package - Preferred Package-
Convenience Package - 5 Spd Auto - Dashhawk - GMCAI - Flowmaster 40
http://i40.photobucket.com/albums/e2...dee/sigpic.jpg
4Banger is offline
Old 05-02-2008, 10:48 AM
