Old 12-20-2006, 10:44 AM
   5.3L Small Block V8 Engine (from Impala SS)
It produces 303 HP @ 5600 RPM & torque is 323 (lb.-ft.) @ 4400 RPM.
Fuel economy is 18 city and 27 highway (in the Impala).
Seems like a good comprimise to the LS2 (if GM would consider a V8). Its all aluminum, uses cylinder heads originally developed for the Z06, gets better fuel economy, and it produces more power & torque than the Ecotec turbo. And it would most likely be within GMs strict tolerances--LS2 fitment is too tight by GM standards. The LS2 adds 200 lbs to a base Sol's curb weight, the GXP adds about the same weight gain over the base. So I'm guessing that a Sol with the 5.3L would weigh less than the GXP.
I have 2 questions.
1. Will it bolt up to the stock drivetrain?
2. Would this be a good comprimise to an LS2?
The small block V8 in SS models features:
Active Fuel Management™ for an EPA estimated 18 city and 27 highway MPG
Aluminum Construction — all major castings in the V8 engine, including the deep-skirt engine block, are made of weight-saving aluminum. Casting from aluminum contributes to a stiff engine structure that helps ensure smooth operation
Electronic Throttle Control (ETC) — ETC replaces the mechanical link between the accelerator pedal and engine with drive-by-wire electronic control. This allows for remarkably smooth and precise acceleration
Polymer-Coated Pistons — pistons are coated with a polymer material that reduces engine wear and contributes to quieter operation
Cylinder-Head Technology — the small block V8 cylinder heads were originally developed for the Corvette Z06. Their pent-roof combustion chambers and flat-top pistons deliver high horsepower
Composite Intake Manifold — the composite intake manifold design allows the small block V8 to deliver high levels of torque at low and mid-range engine speeds, while still delivering plenty of airflow for peak engine horsepower
[Paul Wall]
Sittin' sideways, boys in a daze
It's the people's champ, I'm something like a baller
The candy paint dripping off of the old school Impala
http://wm.atlrec.com/paulwall/sittinsideways-wma-expl.wma
PaulWall is offline
Old 12-20-2006, 02:13 PM
Thanks for the overwhelming response to the above tread.
[Paul Wall]
PaulWall is offline
Old 12-20-2006, 02:18 PM
MyNewSolstice's Avatar
Send a message via Yahoo to MyNewSolstice
This is a pretty specific question that only a few could answer...I would almost gaurantee modifications will be needed to the engine compartment...could it be done...yes at a decent ammount of savings over LS7 or such engine...probably not!
Vin 2896 Deep
MyNewSolstice is offline
Old 12-20-2006, 02:22 PM
Traditional Curmudgeon
SolWhat?'s Avatar
Isn't this V-8 a transverse mounted engine, designed for front wheel drive? If so, there is a substantial amount of engineering time to adapt the engine for the 90 degree change in orientation needed for rear wheel drive?
"If you haven't seen the future, you haven't driven fast enough"
#000741, delivered 10/3/05
SolWhat? is online now
Old 12-20-2006, 02:27 PM
GradSoulStice's Avatar
Send a message via MSN to GradSoulStice
yeah this is the front wheel drive version in the impala ss however the 5.3 could also be found in a rear drive configuration in a truck.
-Black 2006 Solstice #733 (Sold)
-Black 2007 GXP
GradSoulStice is offline
Old 12-20-2006, 02:35 PM
Okay...why do you need it? I'd bet the 2.4 turbocharged would beat that engine. And you could later rebuild the 2.4, run more boost, and really embarrass that 5.3L.
RX-8 driver just passing through...
Red Devil is offline
Old 12-20-2006, 02:37 PM
Slicer's Avatar
WHAT!? You gave it 3 hours for response... in the middle of the day. Why not exercise a little patience.
We've all learned patience waiting for our Solsti.
Vin# 5765 Ordered 10-17-05, Picked up 11-29-05
Envious/Ebony Leather/Everything but XM, ashtray and polished wheels. Traded on GXP 7460 miles
GXP Ordered 8-4-06 Picked up 12-11-06! $30,197 out the door
Mysterious/Darkside/Ebony Leather/everything but XM, ashtray and spoiler
Pick up mileage - 8
Current mileage - 19275
Alternator Replaced, Top "Tabs" Installed, Rear Main Seal Replaced
Originator of the phrase "Solstice Mecca".
My GXP Thread
MY '06 SOLSTICE!
'06 Sold
Slicer is offline
Old 12-20-2006, 02:39 PM
SolWhat?'s Avatar
I didn't know that there was a RWD version of this block. I assume that the reason this hasn't been tried in a Sol is because it isn't as common as the LSx V-8s, nor does it have as many aftermarket performance parts availalable.
Old 12-20-2006, 02:40 PM
SolWhat?'s Avatar
. . . and waiting for responses to some of our more off the wall questions!
Old 12-20-2006, 02:45 PM
For the same reason folks want a Mallet conversion. Except this would be from GM, weigh less than a GXP, get better fuel economy, more HP, more torque, V8 rumble (as American as apple pie), etc, etc, etc. Would be a modern AC Cobra.
[Paul Wall]
PaulWall is offline
Old 12-20-2006, 02:54 PM
   5.3 L Ls4 V8
LS4
5.3 L LS4 V8 in a 2006 Chevrolet Impala SS.The LS4 is a smaller 5.3 L (325 in³) version of the Generation IV block. Though it has the same displacement as the Vortec 5300 LH6, it differs in that it has an aluminum block rather than an iron one and it uses the same cylinder head as the Generation III LS6 engine.
A version of this engine is adapted for transverse front-wheel drive application. In order to fit into the smaller engine compartments designed for V-6s, in the front-wheel drive Pontiac Grand Prix GXP, for instance, the LS4 engine block had to be shortened by one inch. Displacement on Demand is also used. Output of this version is 303 hp (226 kW) and 323 ft·lbf (438 N·m).
Applications:
2006 Chevrolet Impala/Monte Carlo SS
2006 Pontiac Grand Prix GXP
BTW: The Impalla SS tips the scales at a hefty 3,712 pounds
And it does 0-60 in 5.7 seconds! And thats front-wheel drive.
[Paul Wall]
PaulWall is offline
Old 12-20-2006, 03:12 PM
I see your point. I guess you and I come from different schools of thought...I'd rather have little displacement and boost it instead.
I think it's an interesting idea. With enough money and/or elbow grease, I'm sure this can be made to fit and mate the bellhousing.
And if it does in fact weigh less, than it would be a pretty nice alternative. To make it run, I'd guess you would need a new standalone PCM. (What is Werks doing for their LS conversions?) If you do need a standalone, I think getting the displacement on demand feature may be difficult to implement. Even with a reflash of the Sol's PCM you'd probably still not be able to accomodate DOD.
Old 12-20-2006, 05:06 PM
2091351's Avatar
Glad you are starting this project.
Keep us informed as to the progress. Photos are fantastic!
Steve
#1113 42,585 Miles
DOCUMENTED ISSUE 10/26/2005 Delivery *** Ordered 2/13/2004
Envious/Black/ABS/Cruise/A-C/LSD/Mud Flaps/Tonneau/Mats/GMPP CAI/FocuzTech-Stan's Real Tri-Y Header/MagnaFlow High Flow Cat/MagnaFlow Cat-Back/AirBag Adjuster/HighBeam Helper/DashHawk II
*Carrier Replaced @11,392 miles*
Club=Solstice Sky Club of Arkansas (solskyoa@sbcglobal.net)
NASSOA #24
Pure 2009 Solstice GXP Coupe on order 7/16/2008
2091351 is offline
bones's Avatar
I have this engine in my 05silverado p.u. Its also in the new grand prix , monte carlo and i believe the impala , It replaced the tried and true 350. Runs more h.p than the 350 but less torque
bones is offline
Old 12-20-2006, 06:47 PM
I think this is a great idea! I'd love to have a Mallet conversion, but I don't have the money laying around for such an expensive upgrade. I'd like to see a conversion kit developed that I can do myself with a engine that can be easily procured from a number of places. Although, I'd probably wait 3 or 4 years until my warranty expires.
One of the things I like about this is balance. The 5.3 application adds a lot of hp and even more torque, but no so much that the engine or drive line is overstressed. Hum, deep rumble, gobs of torque, and reliability and economy, sound like a winning package.
What about the transmission? How hard is it to mate the 5.3 to the existing transmissions? Or would it be better to use the future 6L80 6-speed read drive manumatic transmission?
OK all you entrepreneurs, I encourage you to get started on a conversion kit ASAP!
Larry4pyro
larry4pyro is offline
