I have a stupid question, I heard that you can use the stock 5 speed transmission from the Solstice with an LS2 motor. If this is true could you use the 6 speed transmission from the corvette on the 2.4L Ecotec Motor??? Lets get some feedback on this....Thanks!
__________________ #357 of first 1k: Black and Fully Loaded!!!
Maybe, maybe not. It depends on the transmission length and possibly the bellhousing amongst other things like shifter placement etc. I'm not knowledgable enough to know the specifics of what would be involved in a 6 speed mod. (I'd get the richmond 6-speed anyway, one less overdrive gear)
Well, a different bellhousing would be needed to bolt the 5speed to the LS2. I would assume that it would be the same the other way around as well. As far as shifter location and things like that, While I don't have measurements I have (kinda) checked it out, and I don't think there would be a problem..
The solstice roadster concept had a six speed, does anyone know anything about that trans? I'm fairly certain that was a fully working concept yeah? If we can get that to work then maybe...
The concept had a different Ecotec motor, I believe it was the 2.0L.
~~~~~~~ NASSOA
I would really be concerned about the transmisson length. While I was in college (many years ago) I read a for sale ad for a Bug Eye Sprite that the owner had dropped in a Chevy 283. The ad went on to talk about performance and ended with the comment that the car had a 3-speed transmission because a 4-speed wouldn't fit. I'd be concerned about the same possible problem with the Solstice. By the way, I'll bet that Sprite could really run fast in a straight line.
AKA xmm
First 1000 Order VIN # 000218 - Time Stamp 2:35:20 DEEP with Steel/Sand leather,
68,500+ miles on the odo - Silver side stripes - My wife named my car "Nittany" after Penn State, my Alma Mater
Reborn at the factory at 57,100 miles Proud Member - ICoD EHDoR&M WPASC
~~~~~~~~~~~~~~~ NASSOA
Founding Member #41
~~~~~~~~~~~~~~~ "Planning a daughter's wedding!!!"
Dude, its called a custom driveshaft! length is not an issue. The only limiting factor is where the shifter would poke through and even that can be fixed with a relocation kit of some kind. When customizing keep in mind that there is Always a way!
Btw, I found that the six speed in the concept was a Borg Warner from a C5 corvette. If GM can do it so can I! Now I just need some parts ...and a car!
The Corvette transmission is a rear mount transmission. It won't fit in the Kappa all that well (if at all).
Not sure why you would want it with the 2.4L anyway. It is really just a 5 speed transmission with a second overdrive gear to help it achieve decent highway fuel mileage and avoid a gas guzzler tax. It doesn't have 6 speeds for performance reasons.
Besides, I don't think this car really needs a true 6 speed with the stock engine. It has a pretty flat power curve as it is, and I would think that adding an extra shift would cost you more time to shift then it would gain you in keeping the revs up a little more.
Keisler engineering has an adaptor plate as well as a bellhousing to bolt up a tremec or many other GM transmissions. I have already looked into this as i may be building a solstice to run in the nhra/nopi in sport RWD. Google ecotec tremec and youll see the webpage. now drop in a fully built turbo engine from the build book and the trans and go hunting
Well since I'm not keeping the stock engine it doesn't matter much! and yes you CAN mount a vette trans to a bellhousing, it doesnt matter much to it! You just have to make an adapter and an output housing ...that or use an early C4 trans, or something else... I think I'm going to end up using a highly modified LS1 in mine, but I'll decide that when I get there.
Bob Lutz has been quoted as saying they looked at 6 speeds in the solstice and found them to be no quicker 0-60 or in the quarter mile than the 5 speed.
The main reason to want a 6 speed, (with the base engine, anyway) would be for track racing, where you could use the closer ratios.
I also read in an article in the news section, that Pontiac didn't have the time or want to spend the money to use non off-the-shelf gears, and they realize that the drop from 2nd to 3rd is a little too big.
I'd bet that the 07's have this issue addressed, and maybe even an optional 6 speed.
Cadillac uses an Aisin AY6 6 speed in the V6 CTS. Its capable of handling 255 lb-ft of torque, higher than the AR-5's 225 lb-ft rating. The bell housing is different as is the shape of the gear box and the shift linkage is in a completely different location. By the look of it, no way it would easily transplant into the Solstice.
