Old 10-07-2005, 05:32 PM
   6sp Aisin transmission
I have the Tech. specs from the Frankfurt Auto show for the 6sp Aisin trans.
I would guess this will be the future 6sp for the Solstice GT/GPX(what ever) since it's already in use in the Caddy CTS..??
I also have some pictures.
Here is what I have:
RWD 6-speed Manual Transmission (AY6)
-Wide application MT from Large RWD Passanger Car to SUV
-Lightweight and compact size achived by reduced gear width of new gear train
-Improved shift quality & reduced gear noise throught new gear train
-Installed in Cadillac CTS, Commodore, Tundra, Tacoma, Land Cruser Prado
TQ capacity 450Nm
Center distance 85mm
Gear Ratios:
1st: 3.791-5.232
2nd: 2.190-2.644
3rd: 1.488-1.632
4th: 1.154-1.219
5th: 1.00
6th: 0.728-0.849
Rev: 3.466-4.525
nvmygtz is offline
Old 10-07-2005, 07:57 PM
shabby's Avatar
I hope this doesnt decrease the amount of torque the tranny could handle.
People will want to up the hp in the turbo solstice, so i hope the tranny wont be the weakest link.
shabby is offline
Old 10-07-2005, 08:07 PM
Whats the conversion numbers of 450 newton meters?
350 lb/ft of torque?
2008 Blk Corvette Z51 w/NPP and 2008 Silver AWD 304hp FE2 CTS
JBsZ06 is offline
Old 10-07-2005, 08:40 PM
Crimson Avenger's Avatar
Originally Posted by JBsZ06
What's the conversion numbers of 450 Newton meters?
Very close, it's 331.9 Foot pounds.
Does anyone know the ratings for the 5 speed that's currently being used? Mallette is using it for the 400 ft lbs of the LS2, so it would seem the 5 speed is a bit stronger.
President, West Coast Kappa Car Club
Crimson Avenger is offline
Old 10-07-2005, 10:04 PM
shabby's Avatar
Actually the 5spd is rated at around 225 ft lbs...... yup 225 ft lbs
shabby is offline
Old 10-07-2005, 11:26 PM
Anybody doing a mallet conversion would be smart to upgrade the tranny at the same time...Otherwise its a time bomb waiting to blow..
JMO
JBsZ06 is offline
Old 10-07-2005, 11:45 PM
shabby's Avatar
You'd figure with a 20k price tag a tranny would be included, i just dont see that package being worth more then half that.
shabby is offline
Old 10-08-2005, 01:33 PM
TOY4TWO's Avatar
TQ capacity 450Nm
Gear Ratios:
1st: 3.791-5.232
2nd: 2.190-2.644
3rd: 1.488-1.632
4th: 1.154-1.219
5th: 1.00
6th: 0.728-0.849
Rev: 3.466-4.525
Nice specs, hope it makes it into the GT Turbo
TOY4TWO is offline
Old 10-08-2005, 03:42 PM
Greg55_99 is offline
Old 10-08-2005, 06:08 PM
2KWK4U's Avatar
Originally Posted by Greg55_99
Thanks, Greg. According to that page, they are both (AR5 and AY6) rated to handle 255 ft*lb max. I suspect this might be a factor of a common part to both trannys (input shaft, maybe?). It's interesting to note that the AR5 is a top-loader, while the AY6 is not. May not be as easy to swap as we think. I'd rather go straight to a T56 anyway, though.
I've never met a Solstice I wouldn't autopsy.
'08 GXP #105359 - Bought and stored 10 months before I move back from Germany!
2KWK4U is offline
Old 10-08-2005, 10:34 PM
Here is a link to the pictures from the Frankfurt show
2005 Auto Show
Adam
93 GTZ Q4<-- Just a few mods =^P
92 GTZ Q4<-- A few less than above
91 GTZ Q4<-- Euro-spec *Black*
69 Chevelle 396SS
nvmygtz.com
nvmygtz is offline
Old 10-08-2005, 10:44 PM
Fformula88's Avatar
Mallett may be beefing up the tranny to better handle the power of the V8. Also, I suppose it is possible that the stock tranny is conservatively rated at 225 HP. Mallett seems confident it will handle the power.
I am not sure I will want to see a 6 speed in the Solstice turbo. As long as it has a good power curve, I think a 6 speed will be overkill. I know I am probably going against the feeling of most people these days, but I think in most applications 6 speeds are really unnecessary. The extra shift isn't worth the extra ratio. But it depends on the power curve. If you will have to really keep the engine on boil to get the power, the extra gear would be good to have.
We Build Excitement
Fformula88 is online now
