The 5L40E has been around for a while. Performance shops that rebuild transmissions can fit it with beefier torque converter and improved valving in some cases.
Are you adding a supercharger and plan to go beyond the 300 or so horsepower the 5L40 is meant to contain ?
It is worth noting that the 5L40E is used on Cadillac and BMW. For the solstice It's a rather beefy transmission out of the box.
It's a transmission meant for motors that run at higher than usual RPM's such as 4 cylinders and some V6's.
On the BMW boards they are saying that the 5L40 often tends to lose reverse as it ages... a common sign of aging in a 5L40E is to get in the car one morning and discover that reverse no loger works. Plan on seeing this in cars with well over 100K miles....
ME
