Old 07-06-2007, 12:04 PM
   Clutchmasters Stage 4 Install Next Week!
Starman's Avatar
I have decided on the stage 4 clutch. After spending some valuable time on the phone with Bill Hahn we decided tio go with the Clutchmasters Stage 4. I will not have to worry about this clutch not holding!. There will be a learning curve on launching but that's half the fun. I will provide feedback once i get it installed next Thursday. I hope to visit the dragstrip soon after a short breakin period. Thnaks Bill for all the help and the great turbo kit. Keep on boosting!
Clay
Clay
Mods-Hahn Stage 3 Turbo/Hi-Flow Cat, Greddy RS BOV/Profec B Spec 2, MagnaFlow Cat Back, Eibach Sportline Springs, GM High Perf. Sway Bars, Koing "Unknown" Rims w/ Bridgestone RE01R Tires, RK Sport Body Kit/Ram Air Hood/Spoiler/Rear Valence, Vertical Doors Solstice Kit, Autometer Fuel Press,Boost Gauge, Autometer Digital Shift Light, AEM Wideband A/F Meter, Dark Walnut Woodgrain Dash Kit, Clutchmasters Stage 3 Clutch, Kicker 8" Sub/Alpine 6.5"/Blaupunkt 3.5" Speakers, MSD DashHawk, etc.
Starman is offline
Old 07-06-2007, 03:18 PM
shabby's Avatar
A friend has a cm stage 4 on his awd talon, he launches at 6000rpm, spins all 4 tires and the clutch grabs like no other. Pedal pressure is almost stockish too.
The bad things he noticed was he had to launch at higher rpm then normal for some reason, the clutch also made some funny noises at low rpm. No big deal imo.
shabby is offline
Old 07-10-2007, 03:15 PM
madmods's Avatar
Clay,
Are you changing the flywheel also. Please post you driving impressions. Carl, if your reading, which clutch did you install?
Team Solstice 2009
How I built my solstice:
2008 show sponsors: Team Solstice 2008, Tillett, Wind Restrictor, Werks, Aspis, Norm's Fiberglass, DDM, AfterShock, Universal Studios, Cardomain, Easystreet AirLift, Alpine, Parkerracing, Madmods-Motorsports, Scap. To be a sponsor, just pm me.
madmods is offline
Old 07-10-2007, 07:59 PM
carlintexas's Avatar
Well, I had the Fidanza billet flywheel and Spec stage II+ clutch and pressure plate installed. I'm not ready to recommend it at this time. I have a vibration that started after the install. I've been in contact with Spec and they feel it's not their equipment and it's either a bad install or the noise & vibration are 'normal'. It best not be normal - or I'm pi$$ed!
So - I ordered and have received a clutch/pressure plate for a GXP. I'm going to see if it will bolt up to my stock flywheel. If it does the next step will be to drop the transmission down and check the Spec installation. If there is no obvious install problem (loose bolts, wrong bolt pattern, etc) I am going to assume that the Fidanza/Spec combo is a problem and it's coming out, to be replaced with the GXP clutch.
Madmods, that was a long answer - but that's my status.
TEAM SOLSTICE 2008
NASSOA(tm)
Founding Member #2
1st 1K #781
DDM Custom Turbo System
3" Magnaflow cat-free
Riken Raptor's 255/45/18
carlintexas is offline
