Very impressive. After I finished the install, I started the car and let it idle for about 5 minutes while I looked and listened for any potential problems. Then I took it on the road for about 10 miles at no more than 1/2 throttle. Came back, re-tightened the hose clamps, checked all the bolts, checked fluid levels, and made a small adjustment on belt tention. I attached the hood and took it on the road again, this time to have some fun. OMG, it was a totally new car. Going from n/a to Stage 2 in one swoop is impressive. The sound the supercharger makes just makes me smile and as the rpm's went up, the smile got bigger. I had no problems with shifting response, no problems with check engine lights, no problems with hesitation or backfire, and no problems with idle. I just had no problems. Did I say, Very impressive?
Dave and team at DDMWorks,
Thank you for such great products.
John G
aka, Rx4theSol
2006 Aggressive with DDMWorks Stage II Intercooled Supercharger, DDMWorks Long tube header and High-Flow Cat, DDMWorks Pro-Beam, DDMWorks A-Pillar Pod with Autometer Boost and Volt guages, Magnaflow Dual Outlet Exhaust, Gravanna J2 Staggered 18 in. wheel set, Goodyear Eagle F1 A/S 245/45/18 front 275/40/18 back tires, Custom Fender Vents, and Racing Stripes.
