I am looking to order a Clutchmasters Stage 3 and would like to do the install myself. Has anyone tackled this job? If so how about some pointers or any information you may have. Thanks.
Clay
Clay
Mods-Hahn Stage 3 Turbo/Hi-Flow Cat, Greddy RS BOV/Profec B Spec 2, MagnaFlow Cat Back, Eibach Sportline Springs, GM High Perf. Sway Bars, Koing "Unknown" Rims w/ Bridgestone RE01R Tires, RK Sport Body Kit/Ram Air Hood/Spoiler/Rear Valence, Vertical Doors Solstice Kit, Autometer Fuel Press,Boost Gauge, Autometer Digital Shift Light, AEM Wideband A/F Meter, Dark Walnut Woodgrain Dash Kit, Clutchmasters Stage 3 Clutch, Kicker 8" Sub/Alpine 6.5"/Blaupunkt 3.5" Speakers, MSD DashHawk, etc.
I doesn't look difficult. The biggest problem is getting the car high enough to drop the tranny out. This may be the deciding factor if it can be done in your own garage.
Clay
Location: None shall pass. 'Cept you guys with the turbos...
Here's the rack I went with. Raises the car 22 inches and will fit in a standard garage. Comes with a low rise tranny jack. If you're interested, PM me for the vendor info since they aren't supporting.
Can you post larger pictures and PM me with the vendor?
Thanks,
This is only hearsay, but I think you have to drop the diff to get the driveshalf out.
NOT WAITING ANY MORE!
You do not have to drop the diff. There is a large bolt on the front of the diff that holds it in place. You need to support the diff and remove that bolt. This allows you to twist the front of the diff down and remove the drive shaft.
Clay
For information sake, a full four post lift fits in a garage with an 8' ceiling. You bring the car up about 48" and use a creeper chair. It is actually better than standing under a lift. The only problem could be the door rails. The other problem is that a decent lift is about $3,000. I have 9'-6" ceilings and I park the solstice under another car in winter.
