Originally Posted by
Kanter
Complete cooling-fan assembly 10367894
pressure plate 24233650
Haven't been able to locate these parts - can someone confirm that they are the correct p/ns?
Be careful with the parts. I used the list and bought several parts that were not needed. I also found that several needed parts were not listed.
The LS7 crate engine comes with clutch and pressure plate.
If you use the Corvette fan, you will also need the ~$100 control module to make the multi-speed functionality work. I recommend modifying and using the original fan.
Another piece of incorrect information in the article is the need for a spacer between the engine and bell housing. They had some extra hardware inside the bell that made the spacer necessary, but that was not mentioned in the article.
