Old 09-22-2009, 06:46 PM   #1 (permalink)
Junior Member
LSJ + donor solstice SWAP
so lets say i have a built LSJ out of a wrecked 06 cobalt ss. also lets say i find a solstice that is wrecked or has a blown 2.4 or 2.0. would it be possible to swap my LSJ into a solstice. what things should i be aware of? i need persuation into buying a solstice to do this swap or to buy another cobalt to swap into. Thanks
mhyatt89 is offline   Reply With Quote
Old 09-23-2009, 12:39 AM   #2 (permalink)
Crimson Avenger's Avatar
Maybe just sell the LSJ to another Cobalt enthusiast and get a GXP to amp it's LNF?
There aren't very many Solstices that have blown engines since most are still under warranty for the engine. What's more, GM extended the power train warranty to 100K miles, so few if any Solstices have run out of power train warranty, so that's probably not an option.
Accident damaged solstices have occurred, but I'm not sure where you'd go to get one with a salvaged title. Then too, that's what you had with the Cobalt SS, so this probably isn't a win either. The truth is that when you buy a salvage vehicle, the asking price is darn close to the difference between the blue book and the cost to repair, so that's a wash as well--might as well just get a used Solstice that hasn't been in an accident that totaled it.
Regarding engine re-fits, well, there are numerous Solstice V8 conversions, so this is possible.
I guess the first question to ask is does your LSJ produce more power and torque than the GXP LNF engine? (260 HP / 260 FtLbs). Since the LSJ started at 205 HP / 200 FtLbs, you'd need to have increased it to somewhere north of 300 for this to make sense. If not, then this may be more of a personal quest to help your handywork on the LSJ live again. Nothing wrong with personal quests, but for the amount that you'd spend on the swap, you could easily stage the GXP's 2.0 up to 300 or more HP with torque to match.
One more thing to consider is that the 2.0 LNF had some very substantial re-design work done to strengthen the block, and improve the water jacket capacity over your older LSJ. Basically, the LNF was the next generation, 2 years later than the LSJ, and learned much from racing and experience with the LSJ. So again, the starting platform of an LNF is a better platform for intense modification--there are LNFs getting into the high 300's, and a few that are starting to knock on 400...
So, getting back to your question, perhaps an older Cobalt could be more easily re-fitted with your LSJ, and since they've been around for long enough to exceed their factory warranty on the power train, you might be able to find an older Cobalt with a blown motor. Also, since the Cobalt had a lower initial sticker than a Solstice, you'd be far more likely to find one with a straight body and a blown motor at an asking price that would make your project very much worth while.
If, on the other hand, you like the looks and ride of the Solstice (4 wheel fully independent, rear wheel drive, center mount limited slip differential with 4 wheel double A-Arm coil-over suspension on a hydroformed, fully boxed, ultra rigid frame) versus the Cobalt (front drive MacPherson strut suspension with a stamped beam LIVE AXEL in the back--not independent at all--in a unibody construction platform), then maybe the best solution is to sell the LSJ to a fellow Cobalt enthusiast, pick up a used GXP, and start a quest to amp up the newer, beefier LNF... You might even be able to get close to that magic 400 HP...
Best of luck with your project, and welcome to the forum.
I'm sure that Many Many others here will have vastly differing opinions, so fasten your seat belts--here we go!
Founder & Member at Large,
West Coast Kappa Car Club
Crimson Avenger is offline   Reply With Quote
Old 10-22-2009, 11:16 AM   #3 (permalink)
Junior Member
Well if its a fully built lsj with a tvs or the stock m62 SC running E85 with proper cooling. I say it would be pushing up near 400whp. I cannot comment on solstice mounts though but I think on the cobalt they use the same engine mounts.
summitss is offline   Reply With Quote
Old 10-24-2009, 11:24 AM   #4 (permalink)
compression's Avatar
It wouldnt be a easy swap. But it has been done before. You will need a saems, custom cv shafts because you are going from fwd to rwd, adapter plate for your transmission, motor mounts, and the list can some what go on and on.
I know some one selling this whole swap right now. Fully built motor. The person is willing to swap back to a STOCK LE5 setup for his fully built LSJ set up. And they arent asking tooo much money for it. 5K plus your stock motor and parts needed.
New Paint and wider rear end is done.
Now it is time for a NEW HEART.
compression is offline   Reply With Quote
