my ls1 ar5 swap build up! - Pontiac Solstice Forum
Old 10-07-2012, 03:25 PM   #1 (permalink)
here is my current project, I bought the car about a year ago, 06 NA 2.4 5-speed.
scored a ls1 from a vette on craigs list and i am bolting it to the stock ar5.
this is my winter project so i will update as i make progress.
motor out!
the new motor
torn down for new bearings, rings, ARP hardware etc..
Z06 cam
ls6 springs
re-assembly
bulszewicz is offline   Reply With Quote
Old 10-07-2012, 03:49 PM   #2 (permalink)
How to connect the transmission!
well after researching forever i couldnt find much info on this setup so i'll try to give as much info as i can.
i am using the bellhousing adapter from advance adapters for a jeep ax-15 to chevy w/ 168tooth flywheel
i had two tabs welded to the lower portion of the bellhousing to allow it to bolt to the motor with more bolts
the bellhousing
tabs i had welded
the trans needs to be spaced 3/8" from the motor so a 3/8" spacer from summit was used. the spacer does not connect the entire circumference of the bellhousing so i cut some steel to extend the spacer the complete 360.
here is the spacer, see how it does not make a complete circle
the bellhousing needs to have a hole made in the side for the internal slave cylinder line to pass thru. *note: the slave from the na solstice will not work it is too tall, i had to order the gxp slave, it is shorter.
also the side of the bellhousing needs to be ground slightly around the starter for clearance
the bellhousing came with a new pilot bearing, however you must use a roller pilot bearing for a 2004 2.8l chevy colorado. it fits in the outer ring of the crankshaft allowing the input shaft to fit perfectly inside it. a needle style pilot bearing will sit too far inside the crank and not come in contact with the input shaft
bearing
the slave cylinder will need some spacers placed behind it, 3/4" for it to be completely compressed when the trans is mated to the engine.
I am using a LUK clutch, pressureplate for a Z06 vette with a 168t flywheel
the two attached
side view
Old 10-07-2012, 04:04 PM   #3 (permalink)
the motor i am using has the batwing style oil pan from a c5 vette, which would come in contact with the factory solstice motor mounts, so rather than buying a new oil pan i just cut the stock mounts completely off and made some new ones
i also notched the frame rails to clear the bellhousing, and spaced the rack and pinion about 5/8" foward to clear the balancer
the c5 exhaust manifolds would not clear the lower crossmember, so i bought a used set of camaro manifolds on ebay
they are very shiny
test fitting
installed!
i test fit the hood the other day, its a tight fit, had to cut the middle rib from the throttlebody, other than that plenty of room!
Old 10-07-2012, 04:09 PM   #4 (permalink)
still a lot of work to do, next on the list is to order a radiator $$$$$$, build an exhaust, do some plumbing etc.
relocated the battery to the trunk today, some allthread and scrap aluminum turned into this
Old 10-07-2012, 04:19 PM   #5 (permalink)
noted000120's Avatar
WOW!!!!!! I admire your vision for the build and will keep a close eye out for any updates. I am looking forward to seeing the finished product. How long would take to complete? Thanks for sharing.
noted000120 is offline   Reply With Quote
Old 10-07-2012, 04:28 PM   #6 (permalink)
thanks, my plan is to have it done before spring next year, the only reason it will even take that long is because i am buying things as money allows, but all to be expected. cant wait to drive it again!
Old 10-07-2012, 05:18 PM   #7 (permalink)
Valhalla's Avatar
looking great so far! let me know how the wiring part of it goes!!
2008 Agressive Red GXP- Auto trans
Magnaflow Exhaust, Dejon CAI, DDMworks IC tubes, Dejon BOV spring, Solo High flow Cat, Trifecta tuned, HAHN Racecraft intercooler, ASAP carbon fiber kit, fog light and backup light covers.
Album of my mod pics
Valhalla is offline   Reply With Quote
Old 10-07-2012, 06:19 PM   #8 (permalink)
cdflint's Avatar
I love to see at home V8 swaps. I'm in.
_
She's an 09 Brazen GXP, Trifecta tune, DDM Race Backbone,OCC, fender trim, center console,coilcover and LVKFCB, Hahn IC, Kappasphere reBar, Dejon lower intake, IC and TBE pipes, Solo HF cat with Magnaflow 3" exh, VDI doors, B&G coilovers, ASAP mesh covers, Norms f430 bumper,fenders,side skirts, GTO CAI hood and rear diffuser, Gravana J2's, ZOK bars, custom projector LED Halo headlights and taillights, custom WR & "Madmods" CF dash, pillar & door sills
Next, a Crazy leather interior...
cdflint is offline   Reply With Quote
Old 10-07-2012, 08:21 PM   #9 (permalink)
Cool. In for updates.
What is your expected power output with that cam? Custom driveshaft?
'07 Mysterious GXP gms1
Adopted w/4,451 miles on 07/14/12
brap is offline   Reply With Quote
Old 10-08-2012, 02:08 AM   #10 (permalink)
llllfly's Avatar
I am copy this to JohnRR we are working on His
73 big block. 454.
Great post.
LLLFLY
08 PW SKY R/L 5-spd,The Wolf
Best of Show in Old Bridge,N.J.
Winner Goodyear Bimp flight 2010 NASSM
Winner best interior 2012 NASSM
DDMWorks:,WindRestrictor
llllfly is offline   Reply With Quote
Old 10-08-2012, 06:31 AM   #11 (permalink)
LowLife1's Avatar
Subscribed (pics?)
Does modified 3/8 bellhousing spacer mean no one offers a complete 3/8 bellhousing spacer?
2006/#482/First 1,000/Triple Blk/2.4 Manual/BCCoilovers/JPM Shifter (classic white w/black 5spd pattern)
2009/#480/GXP of 1266 Targa Coupes/Aggressive/Silver Metallic Stripe/Auto/Optional Polished Split Spokes/GMPP/Solo Mach Shorty/Norms Front GXP Splitter/BCCoilovers/DDM Backbeam & Probeam
LowLife handle simply means likes lowered cars
LowLife1 is offline   Reply With Quote
Old 10-08-2012, 07:02 AM   #12 (permalink)
This is FASCINATING! Thank you for the thread & photos. I'll love to follow along.
Old 10-08-2012, 07:36 AM   #13 (permalink)
wspohn's Avatar
Just curious - are you a V8 fan and just wanted that in there? A tuned LNF would easily equal the LS1 output, otherwise, and would be dead easy to bolt in there. Although I know a lot of guys (self included) enjoy the fabrication exercise.
Anyway, nicely detailed swap thread, always nice to see good pictures and descriptions.
1958 MGA Twin Cam (race car)
1965 Jensen CV8
1969 MGC roadster
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
Old 10-08-2012, 07:43 AM   #14 (permalink)
I am interested in how you are planning on tuning the ECM. Which ECM are you using? One of the bigger challenges others doing swaps have had is getting the ECM to talk with the engine and the BCM. There are still issues with the cruise control for example.
When DDM Works started doing LS swaps, they initially could get the engine to run or the AC to work but not both at the same time. They also had to build a custom cable with specific pinout changes to get the BCM and ECM talking.
Old 10-08-2012, 12:58 PM   #15 (permalink)
Jebsmith's Avatar
How can the engine not run, but the AC work?
V-8 B8
Jebsmith is offline   Reply With Quote
